Hot Rods Rust Removal - Tools or Parts
Discussion in 'The Hokey Ass Message Board' started by xnology, Aug 23, 2024.
  1. Harv
    Harv
    from Sydney
    Bear with me while I put my tinfoil hat on.
    At low pH, citric acid (C6H8O7) acts like a normal acid. It will eat rust, and make bubbly hydrogen:
    C6H8O7 + Fe2O3 → 2 FeO + 6 CO + 2 H2O + 2 H2
    This is similar to how that stanky vinegar works.
    If you bump the pH up (by adding something like washing soda), then citric acid stops playing like an acid and starts "chelating". Chelating is a fancy word for when stuff (like citric acid) makes LOTS of links to metals. In this case, the citric acid grabs the iron out of the rust and latches on to it, like this:
    C6H8O7 + FeO → Fe(HC6H5O7) + H2O
    3C6H8O7 + Fe2O3 + Feº → 3Fe(HC6H5O7 + 3H2O
    4C6H8O7 + Fe3O4 + Feº → 4Fe(HC6H5O7) + 4H2O
    Cl***, can we go back to burning magnesium ribbon and using the bunsen burner hose to blow frogs up? :D
    Cheers,
    Harv
    Algoma56, vtx1800, 69fury and 5 others like this.
  2. Budget36
    Budget36
    Can you do a “for dummies” version?
    About the only thing I recall from HS Chemistry is the word/phrase “Avagadros number”.
    I think it started with a 6.
    Edit: Google says…. Yes it starts with a 6!
    Dang, Mr Violini would be proud!!
    clem, X-cpe and lostone like this.
  3. lostone
    lostone
    from kansas
    ^^^^ HAHAHA !!! ^^^^
    Budget36 likes this.
  4. Fortunateson
    Fortunateson
    Very interesting and informative. Chemistry was never my bag...Bio and a bit of Physics for me!
  5. xnology
    xnology
    from Idaho
    Washing soda IS ddifferent than baking soda. The ratio of citric acid to soda is this in the BB video:
    100g citric acid to 40g washing soda. 1:0.4
    Or
    100g citric acid to 63g baking soda. 1:1
    Edit corrected baking soda amount.
    I don’t know the difference, but there is one. They are both supposed to work. I don’t know if either is specifically better. I was out of washing soda so in my personal test it has been the 1:1 ratio for baking soda. Works like a champ.
    An old PROTO center punch - not perfect, but I can throw it back in for a day and see if the rest comes off.
  6. xnology
    xnology
    from Idaho
    The solution was mixed 8/22/24.
    I will update with more images and I will note when it “feels” like it starts degrading in performance.
    Snicklefritz65 and 69fury like this.
  7. xnology
    xnology
    from Idaho
    What he said - totally have no idea but it sounds legit!
    LWEL9226 and Budget36 like this.
  8. 1952henry
    1952henry
    Thanks for info
  9. j hansen
    j hansen
    Just ordered washing soda,,,,,time for experimenting!
  10. lostone
    lostone
    from kansas
    I figured baking soda in my numbers above from the point of view of about every household has baking soda or at least all that I could remember vs having washing soda.
    ...BTW The original OP video the formula calls for 40 grams washing soda vs 63 grams baking soda....
  11. xnology
    xnology
    from Idaho
    You are correct. I was mistaken on my baking soda number. It is 63g per 100g of citric acid. Oddly enough, I think I buffed when I mixed up my #1 test solution and it still works fine. My next batch will be at 63g or I will have purchased more washing soda. I will let you know how it goes!
    hate it when I mess up the numbers…
    lostone and Budget36 like this.
  12. xnology
    xnology
    from Idaho
    Screenshot from the video.
  13. Harv
    Harv
    from Sydney
    That video advice is good science. There is nothing magic about "baking" or "washing" sodas. They are just a means of raising pH without the citric acid making any nasty byproducts. They each have different strengths, so you use more or less of them. Caustic soda does the same, again with a different strength.
    Cheers,
    Harv
    Snicklefritz65, -Brent- and xnology like this.
  14. Does this goop wear out or do you have to top up the chemicals after a while? Does the rust settle down the bottom?
  15. xnology
    xnology
    from Idaho
    I am still on my first run of the stuff so I can’t answer yet.
  16. inthweedz
    inthweedz
    I've had good results with vinegar, but as mentioned, the smell.. I have heard thru the g****vine that oxalic acid (wood bleach) works well, has anybody tried that??
    -Brent- likes this.
  17. Beanscoot
    Beanscoot
    Washing soda is Sodium Carbonate. Much bubbling as the carbon dioxide from the carbonate is released on reacting with the acid.
    Baking soda is Sodium Bicarbonate. Beaucoup bubbling because there's even more carbonate than in Sodium Carbonate.
    Lye is Sodium Hydroxide. Mixing it with the Citric acid should make no bubbling since there's no carbonate in its makeup.
  18. jfreakofkorn
    jfreakofkorn
    how about electrolysis ?
    some thing better than a 9V battery
  19. gimpyshotrods
    gimpyshotrods
    I have been using citric acid for years, with nothing but city water.
    A chemical plant that I designed and built uses it in bulk, but won't touch a damaged 50lb bag. I get those for free.
    I put my barrel in the truck and head over whenever the have a few for me.
    Algoma56, Lone Star Mopar and xnology like this.
  20. 69fury
    69fury
    from Topeka
    Oh I'm not worried about the connections or the voltage. been doing it for years. I'm just saying if you use a carbon anode instead of steel, you dont have hardly any cleanup and practically never have to replace the water. I used to use castoff carbon motor brushes before i bought the gouging rods from McMastercarr. None of that orange s*** to clean up. I was just commenting that the chelation method means not having to wire up all 65 pieces that I want derusted when I do a batch of small parts.
    -rick
  21. 69fury
    69fury
    from Topeka
    Oxalic acid and Vinegar do eat rust. But they do it so slowly that the acid also attacks and pits the base metal. This whole thread is about the process of chelation- you take an acid that likes to bond with rust (citric acid), then you neutralize the ph a bit with a base like washing soda, baking soda, or soda ash, then you are left with a less strong acid that still really likes to bond to rust so the good metal underneath isn't harmed.
    -rick
    lostone, Algoma56 and Budget36 like this.
  22. TA DAD
    TA DAD
    from NC
    This was a heavily rusted rotor submerised in 16 ozs of vinegar and enough water to cover it, IMG_1519.JPG IMG_1517.JPG soaked for 24 hrs with a couple light wire brush scrubs along the way.
    Lone Star Mopar and Algoma56 like this.
  23. Lone Star Mopar
    Lone Star Mopar
    Here are a couple pics from the tech thread I did a few years back. Just Citric Acid & Water. No special tricks, just soak and rinse. Great thing is I can just pour it in the side yard or gravel drive when Im done. It Doesnt even kill the gr***. To me it's much easier to tolerate the smell over vinegar or putrid Mol***es & much easier to dispose of. I use a batch until it weakens up then mix up a fresh one. It's so cheap you'll likely buy one big bag that will last for years. Screenshot_20240828_083242_Chrome.jpg Screenshot_20240828_083341_Chrome.jpg Screenshot_20240828_083402_Chrome.jpg
  24. 69fury
    69fury
    from Topeka
    I use the washing soda (sodium carbonate) in my solution for electrolysis rust removing. Last night we found a bottle at walmart that someone put down after carrying around the store. It caught our eye because it was a pool supply marked PH-UP to be used to adjust ph of swimming pools.
    I checked the bottle- 100% sodium cabonate (washing soda). Marked down from clearance aisle to 50cents. I went to clearance aisle and got all the rest of them-9 bottles-50 cents each. Score!
    Also, the reason we noticed pool chemicals, is because our side gig is running a church group retreat center (basically a summer camp) and we have a pool to take care of that's 40foot by 80foot- 135,000 gallons. And let me tell you something- now that the time to close the pool is near, I've been thinking long and hard about dropping the whole car in it and wiring up my welder power supply....
    It's been done, I know-I'm waiting for an email back from a guy that can share his experience. But maybe If I can use the chelation method to do easy batches of parts then doing the carc*** itself without the pool will help keep me employed there a little longer, lol.
    -rick
    Algoma56 likes this.
  25. xnology
    xnology
    from Idaho
    Working on an 04 VW - definitely not HAMB worthy, but my kid needs the car… put a corroded shock top in and added some lug and brake bolts. For once I can win at hide and seek!
    After an hour or so, the edges getting worked on showed up in the top of the soup!
  26. patman
    patman
    Just ran across this same video, and came here to share...but it's already here. Trying this out soon...
  27. patman
    patman
    24 hours in the bath. Zero prep, just rinsed off with the hose afterwards. 3 liters of water, 300g citric acid, 120g washing soda, and a healthy squirt of dish soap.
    atch and -Brent- like this.
