Technical Looking for something kinda like a Cleco, but uses flat thin metal.
Discussion in 'The Hokey Ass Message Board' started by Budget36, Aug 25, 2024.
  1. Budget36
    Budget36
    I can’t recall what the name of those things are. Instead of a round piece setup, they used thin flat stock. In between the pieces to weld.
    Thanks.
  2. lake_harley
    lake_harley
  3. Unkl Ian
    Unkl Ian
    HF has them, same deal as Eastwood, but less money.
    hrm2k and Budget36 like this.
  4. tomcat11
    tomcat11
  5. Budget36
    Budget36
    Thanks all, just what I was looking for!
    lumpy 63, Unkl Ian and Just Gary like this.
  6. Hutkikz
    Hutkikz
    I highly DO NOT recommend them for anything. YMMV
    Unkl Ian and Budget36 like this.
  7. Budget36
    Budget36
    Why not? I have a pin hole in a roof. Plan is to use a hole saw, the use a larger hole saw on sheet metal, turn it down to fit the first hole. I just need 3 probably to get an even surface for some tack welds.
    I hate welding sheet metal corners and making “square” patches.
    Hutkikz likes this.
  8. rockable
    rockable
    I use those occasionally but prefer rare earth magnets. The problem witth these is that if you make your patch fit tight enough, when you tack the patch the weld shrinks and they are hard to get out. Plus, they are made for straight cuts, so a circular cut would require a larger gap. Use magnets.
  9. Budget36
    Budget36
    I planned to open them wide, and grind them narrower, last time I tried magnets welding a patch, I had to be far away from them, really messed with the wire welder.
    No clue what type of magnets I have, but will look into finding rare earth ones.
    Thanks.
    lake_harley and Unkl Ian like this.
  10. rockable
    rockable
  11. rockable
    rockable
    Just use the magnetic to hold it in place until you get 1 or 2 tacks. You do have to be an inch or so away from the magnets. How big is your patch?
  12. Budget36
    Budget36
    I don’t know yet until I drop the headliner. Hoping for 1.5 inches or so.
  13. In_The_Pink
    In_The_Pink
    I'll second this. ^ Bought the Eastwood version long ago, used them once, and never again.
    In a perfect world with no expansion and shrinkage, they would be great, but things move, sometimes access to both sides is neither simple nor easy, they are a bit finicky to set up...as suggested, a strong magnet (those 90* angle holder magnets are fine) would be easier in just about every way.
    Budget36 and Hutkikz like this.
  14. Hutkikz
    Hutkikz
    @rockable got it.
    Too big a gap, only work decent on completely flat metal even worse on a curve cut etc.
    use the weakest magnets you can find for small patches. I like refrigerator magnets.
    Start the weld on solid metal and pull to the patch.
    Unkl Ian, Budget36 and rockable like this.
  15. rockable
    rockable
    Yes, if the patch is that small, small ceramic craft magnets, about 1/2" diameter work well.
    Budget36 likes this.
  16. Budget36
    Budget36
    Hoping the patch is that small, but you probably know about rust on the other side of what you can see. ;)
    Thanks again for the advice.
    Hutkikz and rockable like this.
  17. I also found them very hard to get out and will not use them again.
  18. larry k
    larry k
    If your patch is not heavy, I use masking tape !!!
    winduptoy, Bugguts, vtx1800 and 4 others like this.
  19. rockable
    rockable
    I do this occasionally, as well.
  20. Hutkikz
    Hutkikz
    Totally agree with this. Never more than a 45 deg angle.
    Another trick I use for small plugs like this I'll often start with a strip of metal slightly wider than the hole and scribe the shape on it.
    Cut it out leaving a small tab which can be bent up to make a handle to hold onto while I do the first tack or 2 then trim it off.
    rattlecanrods and Budget36 like this.
  21. Hutkikz
    Hutkikz
    One more trick.
    Drill a pinhole out with like a 1/2" drill. Then stick a carbide burr in there and spin it up.
    It will naturally go to any weak metal in the area and it is easy to tell when your into good steel.
    vtx1800, Paulz and Budget36 like this.
  22. Budget36
    Budget36
    But tough to make a perfect circle with a die grinder. I’ll use a hole saw (after I drop the headliner) and make a hole. Then an adapter in the next larger hole saw I have for an 1/8th bit, be a quick burp to fill the 1/8th hole in the new piece.
    I have to see what up on the underside before doing anything.
    winduptoy likes this.
  23. bobss396
    bobss396
    That's what SHE didn't say.... I'll see myself out... :D
    theHIGHLANDER and Budget36 like this.
  24. Budget36
    Budget36
    Badaboom!
  25. Hutkikz
    Hutkikz
    No advantage to making a perfect circle but if that is your preference go for it.
    Budget36 and Paulz like this.
  26. ALLDONE
    ALLDONE
    got a pic of what you are doing... am I understanding that you have a pin hole... and so you are going to cut a big round hole??? why not just weld the pin hole???
  27. rattlecanrods
    rattlecanrods
    Round corners are key for keeping even heat on sheet patches. If possible drill your corners first using a step drill bit or sheet metal hole auger (I'll remember the bit name in a sec). Or use a hand nibbler and file to round the corners. After that the patch is just a trace and cut.
    As said above magnets work much better than the clamps. Weird of caution though if you are running Mig. The arc will start to get screwy as you get closer to the magnets. So don't forget to pull them off after you tack.
  28. theHIGHLANDER
    theHIGHLANDER
    Gotta drop the headliner anyways? Solder. Roofs are usually under a **** ton (official measure BTW) of surface tension. Once welding occurs it can become a sink hole or get pregnant real fast. You could tin it well and solder it up, a lot less heat. It'll outlast yours and probably your grandkids lives.
  29. I've seen some clamps in online videos that look like a threaded bolt that is split in half long ways and has thin L-shaped end pieces that slip under the two sheet metal panels. Then they tighten a nut on the threads and it grips the two panels and pulls them up together and levels them out. Not sure what they're called or where to get them, but the thin ends look much thinner than the popular **** weld clamps with the wing nut, so it should have a much thinner gap between the two panels.
    I ground down my HF **** weld clamps to have a thinner gap between the panels. It helps a lot, but they don't last long.
  30. ALLDONE
    ALLDONE
    the way I do it... total wrong... I use a knock out from a elec. box ,..magnet, gorilla
    tape to the back side... then mig it with added coat hanger , grind smooth and done...
    TexasHardcore likes this.
