Faux/Fake valve covers
Discussion in 'Off Topic Hot Rods & Customs' started by foolthrottle, Aug 18, 2024.
  1. gene-koning
    gene-koning
    I believe a guy has the right to do anything he wants to do to his car. Your opinion of what he does doesn't really matter. If fake valve covers and a fake blower are what he wants, and you don't like it, its your problem not his.
    My coupe is a fake dirt track race car. I really don't care if you don't like the idea that its fake or not. In its original form, it was pretty hard to tell if it was real or not. The roll cage was pulled out after I banged my head on it one time too many. The first car show I attended with it was at a dirt track, and if you preregistered, you could make laps on the track. I took a few laps as hard as I wanted to push the old motor. After that, when anyone asked me, I told them I pulled the cage out of it after I banged my head on it, and it has been run hard on a dirt track before, both true. They could decide if they thought it was real or not. At this point, we have put 100,000 miles on the old coupe, fake or not, its been fun.
    I just don't get where you guys think you have the right to complain about someone else's car. Grow up.
    mad mikey, winr, jimmy six and 4 others like this.
  2. J. A. Miller
    J. A. Miller
    from Central NY
    Remember, strap on spelled backwards is no parts. :rolleyes::confused::eek:
    Deuces, 6sally6, Bandit Billy and 7 others like this.
  3. Illustrious Hector
    Illustrious Hector
    Clever! In my early days of the Motorcycle scene, an expression that was used in describing the bravado
    or "abilities", determination, Character, etc. of an individual, was " He ain't got the parts"
  4. swade41
    swade41
    from Buffalo,NY
    A Facebook friend had these and thought they were the cat's *** and I agree I've never seen this done before or know exactly how it was done.
    I explained to him it was just a stamped steel big block valve cover flipped upside down, somehow attached to the sbc valve cover then another big block cover bolted on top.
    49ratfink, mad mikey, winr and 4 others like this.
  5. Illustrious Hector
    Illustrious Hector
    A good way to run those cool Wei-and covers without spending BBC big buck$. Although the ARP fasteners, Intake, and aluminum heads belie that big bucks have been spent internally.
  6. 19Eddy30
    19Eddy30
    from VA
    Thats thinking Out side box !!!!
    I like to make Other says
    What Hell Is /Was He Thinking !!!!
    I use Real , Fake &' Not what its Appears to be..
    Pic I posted Bent up stock Valve covers ,
    Under , their are /was Jesel Shaft rockers with 2.8 ***anium valves, end of heads where ground off to make look like BS Heads ,, In past I have used JB weld to add Gm makings ,
    One of the Machine shop and engine builder,One of I would used , He was asked Why does that nutty guy's 283 , 307. 327 keep busting So many & My 406 !!
    Gl*** or Steel ??
    My cousin did this body back in 1991 long before five window bodies were made.& Drip rails
  7. 19Eddy30
    19Eddy30
    from VA
    I am also thinking of pulling the Straight Axle out of my 32 & adding IFS
    with running my fender ,
    I noticed going back threw Brians @racer-x thread I noticed how Brain set up on "front axle" is , I also street drive & aways making pulls on street , 1/8 only
    I know shake your Head ,
    What a Dum A$$ !! , Im out in Country
    Worried about hitting a cow that's escaped out of the fence!! Deer ,
    I think for me a better safer set up
    When some us can do 100 plus
    in 660 feet ,
    Just Gary, mad mikey and winr like this.
  8. deathrowdave
    deathrowdave
    from NKy
    I was thinkin 406
  9. blue 49
    blue 49
    from Iowa
    So I suppose my staggered hole Cal Custom valve covers will be considered fake when I put them on the 60's SBC I'm putting together now, with adaptors.
    Gary
  10. 19Eddy30
    19Eddy30
    from VA
    Just a heads Up !
    Im thinking you are using a center bolt head,
    If so , The adapters I used was bigger on inside , witch made a ledge that oil would lay On top & Leak ,
    I tried Glueing gasket to Valve cover ,
    Cork, Rubber ,
    Leaked .
    So started thinking ,
    To solve the Issue /Problem was to Ball mill a Chanel / Grove down each side Front & Back & across Bottom , then on bottom drill holes about every
    1/2 inch letting Oil drain into head from Channel/Groove
    mad mikey likes this.
  11. noboD
    noboD
    For all you haters out there, are the covers on Isky's roadster making him a poser?
    winr likes this.
  12. blue 49
    blue 49
    from Iowa
    It' a 60's engine that I'll either be using Power Pack or Double Hump heads on. I have ran these adapters on Power Pack heads before.
    Gary
  13. BJR
    BJR
    I don't see a problem with using same make valve covers on the same make engine. Where I have an issue is like putting Olds Rocket valve covers on a SBC or Ford engine. Or any other combination of different make covers on a different make engine. Just saying be proud of what brand of engine you have, don't disguise it. The only people you fool are the young people who didn't grow up with this stuff and non car guys. OK now tear me a new one. :D
  14. What is that a Jag? We were talking about clones and fakes and then this picture pops up. Is this a fake? If so it looks cool and you got my approval.
  15. foolthrottle
    foolthrottle
    Isky roadster heads are aftermarket truck heads and the covers are for exhaust rockers only, someone on here knows more
    SS327 likes this.
  16. j hansen
    j hansen
  17. Once again opinions vary. :) In hot rodding cosmetics are up to the builder. I read recently some where the following about fake breasts: makes no difference what's inside, the outside is real. LOL.
    Illustrious Hector and Deuces like this.
  18. Bandit Billy
    Bandit Billy
    Here is one I took a picture of at a local car show this summer.
    It's not my gl*** o' bourbon but I try not to judge. I was on-line on FB the other night and there were pictures of very pretty girls that kept popping up, my wife would say "those are fake", "those aren't real", "that's photoshopped"... Meanwhile all I was thinking was "schwing!" :)
    Meanwhile my wife and I attend car shows and she wouldn't know a fake blower or fuel injection from the real thing, or fake valve covers, or fake QC...I just keep my mouth shut and let her enjoy what she is looking at. I wish she would do the same when I am ogling the pretty girls. :cool:
  19. Deuces
    Deuces
    Oh, yeah! Beautiful girls... I need'em, I love'em.....:D:rolleyes:
  20. Bandit Billy
    Bandit Billy
    I miss Eddie.
  21. 19Eddy30
    19Eddy30
    from VA
    Im thinking of who Eddie Is ?
    I'm thinking a Woman but do not Know of , Maybe I'm not old enough
  22. Rodney Dangercar
    Rodney Dangercar
    I'm thinkin' EVH himself with David Lee Roth on vocals. I've seen Iron Maiden and their pal Eddie in concert twice, VH once but as Van Hagar at the Monster's of Rock 1988 in Spokane.
    mad mikey and Bandit Billy like this.
  23. Illustrious Hector
    Illustrious Hector
    Some of us Oldsmobile guys are mildly amused by this chicanery. The SBC can easily be built to produce tons more power than our 'Rockets' and yet OUR engines are the objects of emulation. The first I saw of this were the early Olds/ SBC versions.
    As BJR pointed out, the only ones fooled are the unwashed and the younger crowd. As one of whom,
    with what appeared to be a valve seat inserted in his ear lobe, proclaimed to his girlfriend at a car show, " Those Offenhauser V-8s are a super rare engine"
    Imitation, whether poorly, or extremely well done , is the sincerest form of flattery.
    Just Gary, firstinsteele and BJR like this.
  24. natrlgas49
    natrlgas49
    My Pent Roof Valve covers on my Ford small block. They didn't pop like on an FE block. I think it was cause of the small engine space compared to a Big block engine compartment. So now they are wall art. 65 mustang.JPG
  25. winr
    winr
    from Texas
    The car shows and cruise ins I attend could give 2 ****es about what anyone thinks about their vehicles
    They build what pleases them, the jerks eventually leave as everyone gets to know them and shun them
    Our car shows allows Asian cars, raised 4 wheel drive, rat rods and such
    Build what ya want ( safe of course ) .. I see stuff that is odd to me as I am almost 70
    But they are built by 20 or 30 year olds who see things in the now, I ask them questions as to why this or that..... They react positive and I make a Friend .... There are some insanely smart Folks out there
    Some of the builds are way off topic, if you would take the time to look at the skill of these young Folks you would be amazed..... I compliment them and have learned from them as well
    Most are eager and appreciate old Folks complimenting them on their craftmanship
    They are the future when we all croak..... mentor them or lift them up
    Ricky
  26. j hansen likes this.
  27. '29 Gizmo
    '29 Gizmo
    from UK
    About a wrong as it gets.... but then there's always faux quick change covers, faux drum brakes, dummy carbs etc, so lots of dress up trends.
  28. foolthrottle
    foolthrottle
  29. scrap metal 48
    scrap metal 48
    Are not 32 fibergl*** Fords FAKE???
    Deuces, 29A-V8 and Anderson like this.
  30. RmK57
    RmK57
    Yes, but there not trying to masquerade as something their not.
    29A-V8 and j hansen like this.
