Technical Is there anyone still dropping axles?
Discussion in 'The Hokey Ass Message Board' started by speedcity, Aug 27, 2024.
  1. speedcity
    speedcity
    I have tried Nostalgia Sids and Okey Joe. Okey Joe said they don't do 37 axles and referred me to Sid's. I have sent a couple emails to them and a few calls, but no response. Today on Facebook I found an older post that says they are not taking in any more axles. Does anyone have a source for dropping a 37 axle. I want to use the stock wishbone. Thanks.
  2. theHIGHLANDER
    theHIGHLANDER
    There was somebody in MI doing it. As I recall he was going to take a break from it but not quit. Sorry, the name escapes me...
    speedcity likes this.
  3. Paul
    Paul
    Editor
    Anson Axles comes up in searches, ansonaxles on IG
  4. A Boner
    A Boner
  5. porkshop
    porkshop
    from Clovis Ca
    I will second Anson Axles. He used to be on here but cannot remember his user name
  6. Budget36
    Budget36
    Another fella in Southern California also, he showed his work in a thread a few months back. I hope I saved the link
    Edit: Looks like my phone only holds messages for about 30 days or so.
    abe lugo, gimpyshotrods and speedcity like this.
  7. 51504bat
    51504bat
  8. krylon32
    krylon32
    from Nebraska
    I've used Anson Axles for years. In my opinion the best in the business. Give Greg a call.
  9. lake_harley
    lake_harley
    I would second calling Andy Kohler (Koehler?). A few years ago when I talked to him he was willing to drop even a 48 axle so I would guess he would be able to do a 37 axle. His price was definitely in line if not a little cheaper than okie Joe and seemed like a really nice guy on the phone.
    Lynn
  10. alchemy
    alchemy
    Andy Kohler is a nice guy, does good work, but I believe he is taking a break from dropping axles for a while. You could try calling though.
  11. Just Gary
    Just Gary
  12. Lone Star Mopar
    Lone Star Mopar
    Okie Joes in Ponca Ciy.
    You can look up his reputation here.
    porkshop and uncle buck like this.
  13. swifty
    swifty
    Read the OP's post #1
  14. -Brent-
    -Brent-
    speedcity, jet996 and porkshop like this.
  15. Another vote for Greg at Anson Axles.
    speedcity and porkshop like this.
  16. Hitchhiker
    Hitchhiker
    I've had Anson, Andy Kohler, okie Joe, and Trevor Dewitt drop axles for me.
    Anson is the best but most expensive
    Andy was the easiest and best to deal with, super happy all around with the transaction.
    Trevor does great work As well. But I think he's not doing them right now?
    And okie Joe's was by far the worst axle I've paid for. Paid to have the steering arms dropped on that one too. They were uneven and 1 of the kingpin holes was loose. I wouldn't waste my time
  17. Lone Star Mopar
    Lone Star Mopar
    My bad, long day. Not sure how I missed that.
  18. jackandeuces
    jackandeuces
    Yes I still do Axles ...Thanks Gary...Fuller Frame & Axle, Hampton Va
  19. seabeecmc
    seabeecmc
    And does them quite well! Ron
  20. Just Gary
    Just Gary
    Jack did a beautiful job on my '33-'36 axle. See how smooth the curves are?:cool:
    Afterwards, I drilled and chromed it.
  21. krylon32
    krylon32
    from Nebraska
    I ***ume your wanting the tube 37 axle dropped. Anson dropped the one that was on the Brizio built 27 Roadster that won the AMBR a few years ago. If you go to Anson Axles on Instagram he has a few pictures of dropped 37 axles.
    Just Gary and alanp561 like this.
  22. Lättähattu
    Lättähattu
    from Finland
    I do drop them. But 37-41 axles only to 3" drop. More than 3" drop will bring king pin too close to perch bolt IMO.
    I even have one in stock ready to ship. Only sad thing is that i live long way from your place....
  23. -Brent-
    -Brent-
    If Andy is still dropping them, I recommend him, too. I love the 32 axle he dropped for me.
    Kohler Kustom Dropped 32 Heavy 2 Inch Over.jpeg Kohler Kustom Dropped 32 2 Inch Over.jpeg Kohler Dropped 32  Heavy Installed Under Model A.jpeg
  24. speedcity
    speedcity
    Thanks for all the suggestions! I'm on it.
    lothiandon1940 and -Brent- like this.
  25. speedcity
    speedcity
    Ok, thanks. I will look you up.
    lothiandon1940 likes this.
  26. ClutchDumpinDan
    ClutchDumpinDan
    @jackandeuces has dropped a couple axles for me. Great work, highly recommend to anyone needing an axle dropped.
  27. jackandeuces
    jackandeuces
    Im not a propoant of dropping a 37/40 axle because the distance between the Perch pin and king pin is short and after the dropping process the steering radius is comprised... I suggest using a 35/36 axle and wishbone which is longer between perch pin and king pin . With this combination your steering radius will be about the same as the original 37/40 radius.. 35/36 wishbone is dimensionally the same as 37/40 wishbone and will bolt up in same place.. I just recently did this one for a 40 Ford..
    teach'm, porkshop, Algoma56 and 7 others like this.
  28. 1946caddy
    1946caddy
    from washington
    If you stretch the axle when dropping it, you don't lose any length.
    Factory drop is 2 1/8" so a 4 inch drop only gives you an additional 1 7/8" drop total.
    Top axle: 4" Total Drop not stretched 46 1/2" KP to KP
    Middle Dropped Axle: Stock original Axle 48 1/2" KP to KP
    Bottom Dropped Axle: 4" Total Drop stretched 48 1/2" KP to KP
    porkshop and guthriesmith like this.
  29. lostone
    lostone
    from kansas
    To stretch the axle boss at the same time presents its own set of problems.
    You would need a different setup and tooling to do it. With the current way of doing it you only need a jig setup the holds the axle static or a hold the boss static and move the axle, its a simple (used the word loosely) up down motion.
    Stretching the axle while dropping it adds an all new dynamic to the mix. Now you can no longer do a "simple" motion of up/down to drop the axle now you have to stretch lengthen while moving the boss up/down at the same time. It is no longer a simple pull but becomes a compound pull on the axle boss...
