Technical ***August 2024 Banger Meet Thread - Hot/cold August Nights***
Discussion in 'Traditional Hot Rods' started by Jiminy, Aug 1, 2024.
  1. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    Thanks guys! I know FSI makes a great product, I just honestly think points are simple and easy to carry spares of.
    Did some further digging and found some chatter on those old Mallory 011-series distributors. Is there any real advantage to those vs. the typical B centrifugal advance distributor, or should I just look for the nicest example I can find of either? Might be splitting hairs/overthinking here, too...
  2. Dan thank you so much! I’ve never seen that article, so it was a great read! I sent a message to Kem, thanks for the recommendation!
    I’m hoping I can meet up with Seth Hammond, he’s local and has a DOHC on a B block.
    Outback likes this.
  3. Ask Seth about another HAL he has too
    J
    Outback likes this.
  4. jim1932
    jim1932
    Now that the new motor is in and the car actually moves, can someone point me to a good reference for fine tuning the carbs and timing? It is a Brierley winfield grind cam (IR), burns dual intake with 81's, stock distributor, simmons Power head, w16Y plugs, stock B fuel pump. Starts up fine but tends to fall flat when you punch it. pops a bi when you let off the gas, but it is open header right now. Always smells of gas when you park it. I have only run it a couple of miles. Plugs are dark brown but not fouled or wet when I pull them. Looking to learn. I have heard of tuning with a vacuum guage or adding an O2 sensor?
    lothiandon1940 likes this.
  5. burl
    burl
    from Minnesota
    I modified one of these and it works pretty good Mallory Type YS 701 AVC, think original application was for fork truck. Trick is there getting harder to find.
  6. Dan from Oakland
    Dan from Oakland
  7. Dan
    Ouch that’s expensive
    I bought a handful some years ago and had pretty good results with them
    As you mentioned the spring setup needs attention for a model A application
    It has a pretty good advance range just by making adjustments without cutting or hacking on the mechanism
    IMHO better to start with a new ***embly than worn out one
    J
    was just looking in the pile and I found a MG distributor that I have used also
    jet996, winduptoy and Outback like this.
  8. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    I did about ten minutes of DuckDuckGo-ing on how to fiddle with the curve on these things and it doesn't look to ornery. Snagged that one. Thanks Dan! You are a lifesaver.
    With the OHV setup I am sure it would need the curve tweaked anyway compared to the standard high-compression flathead setup.
    jet996 likes this.
  9. burl
    burl
    from Minnesota
    We just kept trying springs for sbc Distibutor till we found some that worked. Somebody with a distributor machine could make quick work of it.
    jet996, johnneilson and Tumblin' Dice like this.
  10. With this being my first week back to work after recovering from a broken arm and wrist, I decided to celebrate with a little wrench turning. Still babying my wrist, but it felt good to get out and work a little.
    Should be firing this up in the next few days, now stopping? That’s a whole other story…
  11. Savage Coupe
    Savage Coupe
    from Washington
    Running a Brierley head, Brierley cam, FSI dist, 14yc plugs and 3 97’s. O2 sensors are priceless when tuning. Sync carbs then fine tune idle mixture screws. I got mine to idle at 13.5:1. It’s crisp and doesn’t bog or stumble when I punch it, it just takes off!
  12. jim1932
    jim1932
    Does it matter if it is a 6 volt system?
    Savage Coupe and Outback like this.
  13. Savage Coupe
    Savage Coupe
    from Washington
    I would ditch the stock distributor and get a FSI or equivalent. Convert to 12volt. I also run a MSD box which made a world of difference.
    jet996, Outback and winduptoy like this.
  14. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    How do O2 sensors work on HAMB-friendly cars? Is it like an OBD connection and you hide the wiring somewhere? I have some interest in that to help with tuning.
    winduptoy and Savage Coupe like this.
  15. Outback
    Outback
    from NE Vic, Oz
    Sounds well sorted, have you a hp estimate? What bottom end are you running?
    Savage Coupe likes this.
  16. Savage Coupe
    Savage Coupe
    from Washington
    winduptoy likes this.
  17. Savage Coupe
    Savage Coupe
    from Washington
    A little more HP than stock. A block, counterbalanced crank, insert bearings.
    G Baese, winduptoy and Outback like this.
  18. Outback
    Outback
    from NE Vic, Oz
    A 'little more than stock' seems a little understated if it's being fed by 3 97's :D
    GuyW and jet996 like this.
  19. 5280A2
    5280A2
    skip65 and Outback like this.
  20. Jiminy
    Jiminy
