History ANYONE KNOW WHAT THESE ARE???????????
Discussion in 'The Hokey Ass Message Board' started by 2FORCEFULL, Aug 27, 2024.
  1. ALLDONE
    ALLDONE
  2. J. A. Miller
    J. A. Miller
    from Central NY
  3. ALLDONE
    ALLDONE
  4. patsurf
    patsurf
    you could use them like vise grip clecos!!-don't need the wrench!
  5. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Never seen that,, but,, I should like to try them for mounting tires on the clincher rim.
    Would make it easy to get the bead onto ( into ) the rim.
    '29 Gizmo and lothiandon1940 like this.
  6. J. A. Miller
    J. A. Miller
    from Central NY
    They are used in manufacturing/machining fixtures for clamping things for repeatable operations.
    lothiandon1940 likes this.
  7. ALLDONE
    ALLDONE
    probley what they were using them for....
  8. Petejoe
    Petejoe
    from Zoar, Ohio
    I’ve used these during my welding fabrication years. Welding clamps.
  9. LWEL9226
    LWEL9226
    from So. Oregon
    DE-STA-CO clamps.... As 2FORSEFULL, said missing the bolt.... Bolt had a swivel foot and a jam nut on it....
    I still have a few of them.... use one every so often....
    LynnW
  10. ALLDONE
    ALLDONE
    probley better than getting welding splatter on all your vise grips
  11. deucemac
    deucemac
    I have several and use them for Welding and sheet metal development. Very handy you have!
  12. '29 Gizmo
    '29 Gizmo
    from UK
    Looks like tools for changing a tire at the roadside (not the wheel, the tire)
  13. stuart in mn
    stuart in mn
    They've been making them since 1936, this style is called a 'squeeze action clamp'. https://www.destaco.com/clamping/manual/squeeze-action-clamps.html
    LWEL9226 likes this.
  14. JD Miller
    JD Miller
    The lower one has some cool handle extensions for more griping power
  15. bangngears
    bangngears
    from ofallon mo
    Im thinking cleco plyers
  16. 31Apickup
    31Apickup
