Projects 32 5W Build - The $4K Swapmeet Body / The Old Chrome Coupe
Discussion in 'Traditional Hot Rods' started by NealinCA, Feb 2, 2023.
  1. krylon32
    krylon32
    from Nebraska
    Thanks. I should have known.
    31chevymike and porkshop like this.
  2. alchemy
    alchemy
    You’re not gonna use oil and grease in that car are you? It’ll get everything dirty!
  3. dirt car
    dirt car
    from nebraska
    Only a few over the counter amenities like heads, intake & other related pieces & parts, otherwise the Neil/Ford stuff with a shine throw in !
    31chevymike likes this.
  4. Hitchhiker
    Hitchhiker
    If time travel is ever invented, hot rodders wouldn't go back in time and stop WWII...
    we'd just stock up on goodies for future builds :D
  5. NealinCA
    NealinCA
    Josh got the steel roof insert installed. It's held in by an original style tack strip. The metal skin will eventually be covered in off-white upholstery...but for now the bare metal matches the rest of the car
  6. krylon32
    krylon32
    from Nebraska
    It just keeps getting better.
  7. lcfman
    lcfman
    from tn
    That engine is beautiful!
    Greenblade, 31chevymike and porkshop like this.
  8. 61cad
    61cad
    Are those plug wires, and plug covers from Noble Speed?
  9. NealinCA
    NealinCA
    The plug covers are from Noble, plug wires were a bulk roll from Ton's Performance. I think Noble has similar wire.
  10. Anderson
    Anderson
    I'm excited for the hood sides...
  11. -Brent-
    -Brent-
    Man, there doesn't look to be a wave, ding, or dent on that body. Great work to those guys. I respect that.
  12. heavydumper
    heavydumper
  13. Mart
    Mart
    You might be able to get that roof insert chromed, Neal. Just sayin'.
    31chevymike, RICH B, clem and 11 others like this.
  14. NealinCA
    NealinCA
    Along with the rear fenders??? Haha
  15. DDDenny
    Might as well throw in the grìll shell too!
  16. NealinCA
    NealinCA
    I think the only sheet metal getting chromed will be the rear frame horn covers. I've always liked that look.
    31chevymike, brEad, Darkhorse and 4 others like this.
  17. NealinCA
    NealinCA
    I picked up the car from Josh Carrillo (Carrillo Customs) tonight, so now the thrash begins. Hoping for a shakedown run to RPM Nationals before heading g to the Gathering at the Roc. 32 days left
  18. Fogger
    Fogger
    Neal, That's quite a transformation of the old 4K body. Josh is a metal master and your vision is coming together. Great progress! Ron
    31chevymike, rod1, Uncle Ronn and 3 others like this.
  19. NealinCA
    NealinCA
    I wired up the ignition and charging system on the test stand and will then transfer it to the car. Just seemed easier to do it out on the open.
    Also working on brakes. Hoping to get hubs and drums on tomorrow, then start on brake lines
    Wheels are painted and trim rings polished, so had to see how that combo looks. I think they will look good with crisp white walls.
  20. krylon32
    krylon32
    from Nebraska
    While the chop is a little less, the bobbed rear fenders and the stance bring back memories of Mark Morton's Jive Five.
    31chevymike, Tim, jet996 and 5 others like this.
  21. Anderson
    Anderson
    Praise be to trim rings!!! Might be one of two cars at the show with them :D
  22. NealinCA
    NealinCA
    Sad story. The fancy lavender engine developed a nasty oil leak from the front seal, plus some valve noise. All fixable, but not in the current time schedule. Plan B engine came off the bench to save the game. It's nearly the same build internally, except it has an Isky 400 JR rather than a Potvin 3/8. I couldn't put a green engine and red transmission in a car with purple accents, so I painted the combo cast iron gray as a somewhat neutral background. I transfered over as much chrome as I easily could. Onward with the build.
    20240901_160845.jpg 20240901_161800.jpg 20240901_182845.jpg 20240902_155324.jpg 20240902_180413.jpg 20240902_180427.jpg
  23. pprather
    pprather
    Good to keep focused on the end goal.
    Glad you had a Plan B handy.
    I'm pulling for you to make debut schedule.
    31chevymike and rod1 like this.
  24. NealinCA
    NealinCA
    We got the car back in my shop, and pulled out the roller axles. There is no real good way to get stands under the frame of a 32 with running boards. We cut some short pieces of 1-1/2" square tube and bolted them in with the 2 rear most running board bolts. It makes a solid jack stand point and can stay on the car permanently.
    I then started in on brake lines and did the rear end while it was upside down out of the car. I used 1/4" stainless and polished it before final install.
    This is where I started off this morning.
    There are still a lot of pieces to bolt together, but hopefully not too many more bumps in the road
  25. Outback
    Outback
    from NE Vic, Oz
    Nice work, pity about the oil leak, but good you had that option. Those stand mounts are a great idea!
    I am really enjoying watching your build!
  26. Anderson
    Anderson
    Bummer about the engine…but yeah. The ‘33 we put the SCOT blower on originally had a not so great 59a…so we got a second hand older H&H 8BA…it produced a milkshake that turned out to be a porous cylinder wall. So now we have Flathead #3 in it that we’re chasing a lifter issue on.
    Can’t wait to see the whole shebang all together, and brilliant idea on the jack spot.
    31chevymike, brEad, Tim and 3 others like this.
  27. NealinCA
    NealinCA
    More parts going together
    20240908_192132.jpg 20240908_174635.jpg 20240908_175337.jpg 20240908_191750.jpg 20240908_191929.jpg 20240908_190521.jpg
  28. krylon32
    krylon32
    from Nebraska
    About 30 days!
    31chevymike and deuceman32 like this.
  29. NealinCA
    NealinCA
    29 until we are scheduled to leave!
  30. Mikko_
    Mikko_
    from Sweden
    Every time I check in on this thread I'm just amazed at the level of workmanship and attention to details.
    Bummer about the purple engine but hopefully you get that fixed further down the road.
    31chevymike, rod1, HemiDeuce and 5 others like this.
