Projects 62 409 20 Day to Great Bend KS
Discussion in 'The Hokey Ass Message Board' started by saltflats, Sep 6, 2014.
  1. saltflats
    saltflats
    from Missouri
    Rocker is fully welded and the roll bar bent. Man it got hot today.
  2. saltflats
    saltflats
    from Missouri
    Holiday is over. It was back to work today. Made some progress fitting the floor pans to so that I can mount the seat to figure the main hoop cross bar height.
  3. saltflats
    saltflats
    from Missouri
    Main hoop, cross bar and rear down bars welded in today.
    Time for a beer.
  4. saltflats
    saltflats
    from Missouri
    Got the trunk dropdowns welded in and first layer of reinforced filler over the seam. Then loaded up and brought it home. This will save me a 2 mile trip to work on it but my shop is a fare weather shop. I'll work on finishing the body and paint to protect the outside then finish the inside.
    This is the welder I got as a raffle prize at the MeltDown drags.
  5. Nice progress. I hope you like that Hobart welder as much as I do my Hobart 190 Handler.
    mad mikey and saltflats like this.
  6. saltflats
    saltflats
    from Missouri
    That thing works great. I only thought it fitting I use it to repair the car I won it with.
  7. Stock Racer
    Stock Racer
    Nice work! Moving right along
    saltflats likes this.
  8. saltflats
    saltflats
    from Missouri
    Looks like it wants to come out of hiding.
    mad mikey, Deuces, Okie Pete and 7 others like this.
  9. saltflats
    saltflats
    from Missouri
    Making a little headway on my least favorite part. Getting closer every layer. :)
    The swing out door bar fitting's did show up today.
  10. saltflats
    saltflats
    from Missouri
    Finished up my third round of the fibergl*** reinforced filler and started on my first round of rage ultra. Man I hate this body work.
  11. saltflats
    saltflats
    from Missouri
    I'm calling this side primer ready.
    Sad part I have to rinse and repeat on the other side. :(
  12. saltflats
    saltflats
    from Missouri
    First coat of epoxy primer, sure hope the rain holds off for this stuff to skin over.
    mad mikey, Tickety Boo, SS327 and 6 others like this.
  13. saltflats
    saltflats
    from Missouri
    Getting there slow but sure.
  14. saltflats
    saltflats
    from Missouri
  15. saltflats
    saltflats
    from Missouri
    Well today was a good start then had to go load up the rest of my equipment at my buddy's shop. Then had a pop up rain shower that I was not ready for. :mad: I did get one layer of rage on and worked down, hope one more round of it and be ready for primer.
  16. saltflats
    saltflats
    from Missouri
    After a few more rounds of rage I got primer on the p***enger side today. I think it's time for a beer.
    20240916_111031.jpg 20240916_135618.jpg 20240916_135628.jpg 20240916_153641.jpg 20240916_153710.jpg
  17. Tickety Boo
    Tickety Boo
    from Wisconsin
    I was hoping you would have it ready for the Fall Out Drags this coming weekend, they advertise a muscle car 348-409 section this year :cool:
    The Shaker would have even had a chance to get even, running against the little 327 64 Chevelle this year :oops: lol
    mad mikey, slayer, Chucky and 2 others like this.
  18. flynbrian48
    flynbrian48
    Nice job with the quarter repair, and the floor/rocker repair is first rate. I used Panel-Bond on my '62 right rear quarter wheel opening panel, despite people saying there'd be a witness line visible. Nothing so far, looks great. I'm swapping the 4.11 posi center section currently in mine for a 3.36 open one tomorrow, I find it terrible to drive. I'm not racing it, so I don't need the gear, and I don't really care for a posi. My car has a later 454 in it with a TH400. Totally dig your car, I like the lettering and they way you're going with the whole thing. (edit) I wonder how accurate you found the lower quarter panels to be? The wheel opening on the panel I bought looked fine until I looked VERY closely, it's not as crisp as original, it looked like it done with a bead roller. I finessed it with some short strand gl*** filler to m make the "roundness" more crisp. I considered getting the same panels you used but my car wasn't as rusty, so I didn't want to replace as much. 17276B31-91AE-4113-80A2-3B82E497B07C.jpeg D57A260F-9773-4B64-8445-65E12AAFD757.jpeg E633CAA7-6A72-4EBB-84C0-F012FA2D5B87.jpeg
  19. saltflats
    saltflats
    from Missouri
    What filler did you use over the seam?
    I used the reinforced filler over the seam and did my blend work with rage ultra.
    mad mikey and flynbrian48 like this.
  20. saltflats
    saltflats
    from Missouri
    I sure would have liked to of made this event, maybe next year.
    The last time this car was on track was that event. I made it to quick for no roll bar and my better sense said this car wasn't safe so here I am now.
  21. saltflats
    saltflats
    from Missouri
    On another note on this car, I always had an overheating problem with the stopped up radiator. I think the problem is solved now.
  22. saltflats
    saltflats
    from Missouri
    Test fitted some 28x10.5 slicks. They fit but are a little close on the inside. The M/T wheels have .5 less backspace so this should make for a nice fit.
  23. saltflats
    saltflats
    from Missouri
    I have to say it felt good to have oil and antifreeze on my hand instead of body filler and primer.
  24. Tickety Boo
    Tickety Boo
    from Wisconsin
    Also lots lighter than the rally wheel ;)
    mad mikey likes this.
  25. saltflats
    saltflats
    from Missouri
    Be interesting to see what the difference is. These M/T wheels feel heavy to me.
    mad mikey and SS327 like this.
  26. flynbrian48
    flynbrian48
    Same. Short strand 'gl*** filler first then high end filler to finish. Similar to Rage Gold, may have been PPG. The difficult part of my repair was finding that some 45+ year old body work following what must have been some pretty serious collision damage. Surface rusted metal on the tops of the quarter panels at the leading edge of the deck lid covered by up to 3/4" filler over stress buckles and ball peen hammer marks. Typical early 70's used car bodywork. Can't complain too much, it lasted almost half a century, my repair should be good for that long, although I won't. ;)
    mad mikey, loudbang and saltflats like this.
  27. saltflats
    saltflats
    from Missouri
    Got the slicks mounted. I'm liking the new look.
  28. 427 sleeper
    427 sleeper
  29. saltflats
    saltflats
    from Missouri
    Debating whether to paint the spoke black to match the fronts.
  30. saltflats
    saltflats
    from Missouri
    Enough playing with wheels got to get back to rust repair.
