Projects 1946 GMC Bonneville build
Discussion in 'The Hokey Ass Message Board' started by Marcia, Aug 26, 2020.
  1. Marcia
    Marcia
    PXL_20240522_004702959.jpg The gas gauge is installed.
  2. Marcia
    Marcia
    PXL_20240610_204710545.jpg PXL_20240610_204441046.jpg The cover is two interchangeable pieces o aluminum. I used a roller to paint them.
    Okie Pete, LAROKE, bobss396 and 11 others like this.
  3. thebearded1!
    thebearded1!
    from Maryland
    Looks great! That way you don't have to remember which is the front and which is the rear
  4. Needs a pair of Cherry Bombs. Hehe.
    Six Ball likes this.
  5. Six Ball
    Six Ball
    from Nevada
    Step by step it just gets better!
    Marcia and chryslerfan55 like this.
  6. Marcia
    Marcia
    No mufflers on this one!
  7. Bearing Burner
    Bearing Burner
    from W. MA
    Only a little more than a month to Loring.
    41 GMC K-18 and Six Ball like this.
  8. Marcia
    Marcia
    PXL_20240710_210555787.jpg PXL_20240710_210519037.jpg PXL_20240710_210541334.jpg We got the fuel line run up to the firewall. The electrical shut off is beside the battery.
    swade41, Okie Pete, LAROKE and 7 others like this.
  9. 41 GMC K-18
    41 GMC K-18
    Most impressive indeed!
    "Money has no real value, unless it's spent"
    @Marcia
    You have spent your money, very well!
  10. Six Ball
    Six Ball
    from Nevada
    And more importantly your time.
  11. Toms Dogs
    Toms Dogs
    from NJ
  12. Marcia
    Marcia
    PXL_20240816_150129815.jpg Building the lateral head support.
    I can easily get the helmet off and get out of the truck.
    I thought we might have to build something that would move out of the way. PXL_20240816_150118086.jpg
  13. Six Ball
    Six Ball
    from Nevada
    Looks great! I can't "easily" get out of anything. :rolleyes:
  14. Marcia
    Marcia
    It's my only motivation to stay fit!
  15. 05snopro440
    05snopro440
    Can you do the bail-out without taking the helmet off?
    41 GMC K-18 likes this.
  16. Marcia
    Marcia
    Yes, but it's easier without the helmet.
  17. 05snopro440
    05snopro440
    As long as you're safe while in it and can get out safely and quickly if needed.
  18. Marcia
    Marcia
    Right!
    I exited a few times and I'll practice more before next July. That will be testing at Loring.
  19. 51504bat
    51504bat
    Some time ago I asked a Bonneville/El Mirage tech about bail out requirements. Her response was that it didn't have to be pretty just as long as you can exit the car in an emergency.
  20. Marcia
    Marcia
    You have to know what you're doing and not panic.
  21. Marcia
    Marcia
    I'm looking for Deist arm restraints. Who carries them?
  22. thebearded1!
    thebearded1!
    from Maryland
    It's weird it looks like you can buy stuff directly from Deist but the link for arm restraints doesn't load on their website. Did you try calling them directly?
    lothiandon1940 likes this.
  23. Marcia
    Marcia
    Yes, I did.
  24. Marcia
    Marcia
  25. ronnieroadster
    ronnieroadster
    Hi Marcia
    The best arm restraints to use are made by Auto Power since the SCTA rule changed outlawing the welded style many of us have purchased the ones offered by Auto Power. An added bonus Auto Power runs a Land Speed so buying their stuff helps support another racer.
    Ronnieroadster
  26. Marcia
    Marcia
    Ok, thanks Ronnie
  27. Marcia
    Marcia
    PXL_20240911_131825089.jpg Bars are welded in, getting ready for fire bottle brackets.
  28. Marcia
    Marcia
  29. Marcia
    Marcia
    PXL_20240924_205709918.jpg Running some electrical cable.
  30. thebearded1!
    thebearded1!
    from Maryland
    The battery was even made in August! It was destined to be at Bonneville!
