Technical Who makes a 35-40 ford side mount motor mounts?
Discussion in 'The Hokey Ass Message Board' started by Budget36, Aug 31, 2024.
  1. Budget36
    Budget36
    For a SBC. Looks like the mounts (quick eyeball) would be where the front of the frame is angled.
    Thanks
    ps I’d prefer bolt in.
  2. Ch***is Engineering, I believe still makes them
  3. dodge35
    dodge35
    from kentucky
    Ch***is engineering had them. Speedway motors bought them out, they might still sell them. They were bolt ons.
    chryslerfan55 and Budget36 like this.
  4. Budget36
    Budget36
    Thanks gents, will check speedways site.
  5. dodge35
    dodge35
    from kentucky
    Summit has ch***is engineering kit for the swap. Inclues bolt on frame mounts, engine mounts and the (good) bushings. $208.00
  6. krylon32
    krylon32
    from Nebraska
    If you want mounts that put the motor in the right place, at the right height and bolt in go to Pete & Jake's for the #5005 35-40 Ford SBC motor mounts for a straight axle car. I've used them several times in customers original frames. Top quality. Made in the USA. Also Heidt's bought the rites for most of the CE parts, P&J's bought some also.
  7. TerrytheK
    TerrytheK
  8. Budget36
    Budget36
    As I check this thread, more thanks to all. Google just popped up generic stuff in the explanations.
    Thanks again
  9. Budget36 likes this.
  10. Dooley
    Dooley
    from Buffalo NY
    I have the ch***is engineering ones worked great
  11. okiedokie
    okiedokie
    from Ok
    Speedway did not buy out CE. Heidts took them over and sells that product.
  12. There is a pair of TCI ones listed in the HAMB cl***ifieds.
