Hot Rods Big Daddy's 55 2 door wagon gasser
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 1, 2024.
  1. fastcar1953
    fastcar1953
    Nice try . Cut your first mounts off and make your new ones now that it's in the right place.
    Sorry It's not looking like I will make the party next weekend.
  2. Nah, it'll have nice floors in it now that I'm done with the crossmember. Just took them back out to make things easier.
  3. All good man.
  4. chevy57dude
    chevy57dude
    It's going to look amazing with headers!
  5. Yeah I didn't feel good so I quit and came home. I don't know if it's the outlet on my radiator or what, but it's pretty much running into the mount. It's gonna be simple to make the brackets for the side mounts now.
  6. At first glance at this photo it looked to me the outlet was to far inboard also.
    I have a 1955 factory-built V-8 Rad so I went and took a measurement from the edge of the Core to center of outlet. Looks to be exactly 4".
  7. Guess I just need to see a stock bottom radiator hose. I'm gonna pull the front mounts after I weld the side mounts anyway.
  8. lumpy 63
    lumpy 63
    The stock 55-57 lower hose is one of the shortest , tightest turn hoses there is. works *****in in early ford sbc swaps too.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I used factory lower hose and it all fit well.
  10. That is one good looking engine.
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Now that I’m more awake. I should have mentioned that I picked up a 57 air cleaner (type shown) (56 unit are too tall for my liking) for Carina’s car and have since painted the radiator tank black. IMG_3018.jpeg
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    Really hard to get a good picture, it looks like the outlet on your water pump tips down more and mine comes almost straight out
  14. Opinions wanted. This car has 7 leaves in the rear bundles, and I bought a 8.5 10 bolt with a 4.10 posi. If you were me, would you leave the parallel leaf springs, or put the ladder bars and coilovers in it?
  15. I would leave the leaf springs in it. I would probably pull two leaves out to hopefully soften the ride.
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Leave the wagon leafs in.
    Back in the day trick was to add another main leaf (cut both bushing ends off) to reduce/stop axel wrap.
    VANDENPLAS, ffr1222k, brigrat and 8 others like this.
  17. Moriarity
    Moriarity
    SUPER MODERATOR
  18. Sounds good (easier) anybody wanna buy some adjustable ladder bars? They'll be in my swap meet at Lloydfest lol
  19. snoc653
    snoc653
    from Iowa
    post pictures. If I don't go Caltracs on the 9", I'll need something to help it hook up. The parts pile is starting to take on a get it built look. But, always room for more of the right parts. I might be heading to Michigan and since you are on the way if things work out, hopefully I can at least swing by for a bit.
  20. 427 sleeper
    427 sleeper
    I'd leave the leafs in and maybe add a spring pocket kit to move them under the frame rails.
  21. lumpy 63
    lumpy 63
    Your gonna have a big cooler full of ice and adult beverages in the back....best leave the wagon springs in place.
  22. SS327
    SS327
    If you have a problem with wheel hop a set of cal tracks will fix that right up.
  23. I've not looked close, but they're not the factory springs, he put them under the car 50 years ago.
  24. They're still in the box. $299 new. I'm not gonna open the box but this is them from Jegs. 555-64670.jpg
  25. Moriarity
    Moriarity
    SUPER MODERATOR
    just my opinion but moving the springs under the frame for tire clearance? tires need to stick out or be right at the wheel lip. straight axle cars with the tires under the fenders (ala pro street style) look dumb, two different eras fighting each other....
    VANDENPLAS, brigrat, Outback and 11 others like this.
  26. The rear end in using is 62.5" wide. Effectively moving my rear tires out a little over an inch on each side. Which is why I wanted a 62" axle. I have no limits coming further out with the radiused wheel openings. 20240801_150820.jpg
  27. Moriarity
    Moriarity
    SUPER MODERATOR
    all the more reason to not go through the extra work of moving the springs...
  28. 427 sleeper
    427 sleeper
    I wasn't trying to imply that Lloyd should keep the tires within the body, just suggesting that he could possibly get bigger tires and still have enough poke past the quarter's to make it look right. :cool:
  29. lumpy 63
    lumpy 63
    I'm pretty sure it was talked about but you are going to bridge the core support , correct?
    ffr1222k, Outback, porkshop and 5 others like this.
