home made tools and equipment...
Discussion in 'The Hokey Ass Message Board' started by kustombuilder, Jan 16, 2008.
  1. Is this IT tech board now???
  2. Naw, just a normal HAMB thread; skews left and right with comments on some one else's comment on an issue, then back on course.
  3. atch
    atch
    ...so to get this thing back on track here's a specialized saw I made several years ago. A big nail (bent as necessary) and a saber saw blade welded together. I don't even remember now what I made if for but it worked and here it is:
    (if I showed this thing already please just ignore this time)
    b-t-w; the "5" marked on the bench is 5' from the left end of the bench. I marked it every 6" with a Sharpie ages ago. It's plenty good enough for rough measurements/guesstimates.
    alanp561, Okie Pete, whtbaron and 8 others like this.
  4. @atch further to your adap ted tool idea. Made the drill bit 40 years ago, when it was easier and cheaper to build than buy, especially on weekends. Welded a bolt to end of 5//16 drill bit, to extend it. Friend had installed new engine in his 55, then found that it wasn't drilled and threaded for staggered pattern starter. Put the proper starter in place with the outside bolt, then used the starter housing as a jig to drill the block for 3/8-16 thread.
    The other tool shown was a washer cut on one end for nut. Needed it to hold the nut in behind a drip rail, so that I could tighten the bolts holding the homemade trunk hinges on my A roadster.
    just kept them around, because.
    Okie Pete, jet996, alanp561 and 9 others like this.
  5. atch
    atch
    Fixture to make a bend in steel rod. Most of you have or have made something similar. A couple of 1/2" bolts welded together and the welds ground down so it fits in the vise without wobbling.
    20240822_150504.jpg 20240822_150441.jpg 20240822_150724.jpg 20240822_150424.jpg
    alanp561, MMM1693, Okie Pete and 19 others like this.
  6. Dave G in Gansevoort
    from Upstate NY
    A pair of fixtures for beating out new ram tubes last year. 20230926_222059.jpg 20230926_222126.jpg
    The mostly finished tubes. The 1st was to form the bells, and the 2nd was to form the bottom flat flanges.
    MMM1693, Okie Pete, vtx1800 and 22 others like this.
  7. WZ JUNK
    WZ JUNK
    from Neosho, MO
    Very nice work Dave.
    nunattax likes this.
  8. j hansen
    j hansen
    It sure looks homemade!
  9. Fortunateson
    Fortunateson
    I’ve seen those type of “rotisseries” before and they seem to do the trick!
  10. j hansen
    j hansen
    I like this one,,,,
  11. Pav8427
    Pav8427
    A welding table we have at work. Was fabbed up the blanchard ground flat. Risers are 1x3 CRS and tops are 1/2x3 CRS. We had to do some mods and had it reground. At the same time had the risers ground flat. Risers have a 1/2 bolt clamping ends and can be slid into any position for fabbing. IMG_3530.jpeg IMG_3529.jpeg
  12. Dave G in Gansevoort
    from Upstate NY
    Now that's a serious welding bench!
    29A-V8 likes this.
  13. WZ JUNK
    WZ JUNK
    from Neosho, MO
    I built this tool to help me bend radius on sheet metal. I saw photos of something like this, so I made one. I have no idea what they are called. 3 different sizes of pipe and some left over scrap from a treadmill. I like to make things from junk.
  14. Dave G in Gansevoort
    from Upstate NY
    Ooh, I like that! And easy to duplicate. I have a hood and belly pan to make. That'll be just the inexpensive ticket.
  15. ROBRAM
    ROBRAM
    I made one as well. It's called a pipe anvil, which I believe Gene Winfield originally came up with.
    alanp561, whtbaron, loudbang and 4 others like this.
  16. j hansen
    j hansen
  17. Mr48chev
    Gene calls them a Windfield bender.
    URL=https://hosting.photobucket.com/alb.../IMG_3401.jpg?width=960&height=720&fit=bounds][​IMG][/URL]
    I haven't made one yet but they can be handy for sheet metal fab.
    brEad, GuyW, The 39 guy and 2 others like this.
  18. WZ JUNK
    WZ JUNK
    from Neosho, MO
    I watched the video and it looks like I over built again. At least I know it's called a pipe anvil. Mine is 6' long and it is a lot taller than the ones in the photos. I do not like to bend over. Most of my work benches are higher than average. I am working on a way to measure where the bends will be in relation to where I place the metal in the tool. I will be making a one piece tapered hood top.
    brEad, The 39 guy, nunattax and 3 others like this.
  19. j hansen
    j hansen
  20. twenty8
    twenty8
    ....... and then lose your circlip.....:(
    vtx1800 and j hansen like this.
  21. Chgo Sox Fan
    Chgo Sox Fan
    29A-V8 likes this.
  22. ekimneirbo
    ekimneirbo
    The "SECRETs" to finding things in your shop.............
    Plan "A" Tell your wife you can't find something !
    Plan "B" Buy lots of everything instead of just one or a few ! (permanent markers, eye glasses, tape measures)
    If they are laying all over the shop it increases your odds of finding one.
    Plan "C" Do both "A" and "B"................:D
    If you still can't find one, that is a signal; that you don't have enough of them on hand yet.......buy more!
    I've got about 10 tape measures, 8 pairs of glasses, and I buy permanent markers off Amazon by the box (much cheaper). Its better than wasting my time hunting for them.
    alanp561, 38Chevy454, 29A-V8 and 3 others like this.
  23. lostone
    lostone
    from kansas
    Needed special frame brackets for my gas and brake lines. No one made them in the size I needed or in the length.
    So I built a jig to do it myself, I can make one in about 3 minutes....
    As I've stated before, I've about custom built everything on this car !!!
    20240528_135548.jpg 20240528_135926.jpg 20240528_140004.jpg 20240528_141018.jpg 20240529_160844.jpg
  24. 29A-V8
    29A-V8
    from wyoming
    Yeah, what he said.
    Sharpone and jeepsterhemi like this.
  25. Fortunateson
    Fortunateson
    Great idea! So the part being held by your vice grips is what you hammer on to bend the metal strip, correct?
  26. lostone
    lostone
    from kansas
    Yes sir you are correct! The one leg that goes to the center is rounded on the end on both sides to create that nice bow between the 2 lines. The other leg is just rounded on 1 side, the side that goes next to the brake line, the other side of that leg just has the corner knocked off as to not create a sharp edge/mark against the clamp itself...
    Sharpone, jeepsterhemi and RICH B like this.
  27. j hansen
    j hansen
    then,,fjong,bang,,and a cracked window!So it was glue gun time.
    brEad, GuyW, vtx1800 and 4 others like this.
  28. twenty8
    twenty8
    I hope you weld better than you "glue gun"............:D;)
    Cliff Ramsdell, brEad, 29A-V8 and 3 others like this.
  29. j hansen
    j hansen
    Jesus,,,,I am so happy I finished my beer before I read this,,,it would have killed my keyboard!
    I don`t have any good pics of my welds,,lets go with this one.
    clem, Cliff Ramsdell, brEad and 2 others like this.
  30. twenty8
    twenty8
    That weld looks about perfect, so I gotta ask the question. How many beers were finished before the glue gun job?
    Cliff Ramsdell, 29A-V8 and Sharpone like this.
