Projects 55 Chevy Bel Air Resurrection
Discussion in 'The Hokey Ass Message Board' started by jsxtreme, Sep 3, 2024.
  1. jsxtreme
    jsxtreme
    from Michigan
    This will be a long one, most likely with multiple posts to get it up to speed.
    Some important (to me at least) back history on this car. My Uncle purchased it in out of Missouri back in 1979. From there he pulled the old, worn out stock motor and dropped in a 327 out of a 64 Chevelle, with a 4 speed Saginaw gear box. Here is a photo of it in 1979.
    He drove it for many years, and ended up parking it around 1997 outside, under a car cover. There it sat until 2020, and well Michigan winters + trapped moisture under a car cover was not kind to it. Here is the day I dragged it home when he asked me to take it and get it running. This is from 2020 when I picked it up.
    At some point he attempted to primer the drivers side, unfortunately, in an attempt to stop the rust. Kind of a bummer, as I like the patina on the rest of the car. Plan is to strip the primer. Outside of the drivers side floor and rocker, the car is surprisingly solid. It was in great condition back in 1997 when it was parked.
    August 9th 2024:
    For the first time in over 30 years, it runs.
    https://imgur.com/ujJagg0
    August 12th, 2024:
    Moves under its own power for the first time in 30 plus years:
    https://imgur.com/a/Jaywr0i
    August 16th 2024:
    Drove it to work for the first time, really one of its first voyages.
    Fast forward to today, here is a list of new parts that are installed. I still need to settle on wheels and tires. Been waiting to get it lowered to do that.
    '55 Chevy disc brake conversion Kit
    New Aluminum Radiator
    New Gas Tank
    New Gas Tank Straps
    Intake Gaskets
    Holley Renew kit for the carb
    Moroso Advance Curve Kit
    Starter
    Water pump
    Fuel filler neck
    Battery
    Rear brake union
    Rear brake drums kit, pads, brake cylinders
    Package shelf tray
    Hoses
    Belt
    Floor Pans
    Sending unit
    Hood latch repair kit
    Factory Battery Hold Down
    Rear leaf spring bushings
    2" drop coil springs
    Beltech 0-2" drop shocks
    The interior is going to be pretty decent once I get new carpet in it, the body really took the majority of the ****.
  2. jsxtreme
    jsxtreme
    from Michigan
    So, getting started on some body work, or I guess you'd call it primer removal. My Uncle had sprayed one side of the car with primer in an effort to keep the paint from shrinking. That didn't work, and well the primer, to me, was covering up some cool patina.
    Here is a before and after of the hood. Just took it real slow with some 320 grit, trying to not blast through to the metal or remove all the patina, but trying to remove enough primer to reval what's underneath.
  3. greybeard360
    greybeard360
    You had me hooked until the word patina came into play.
  4. jsxtreme
    jsxtreme
    from Michigan
    Some more photos from the last month or so:
    As it sits as of this weekend, lowered 2.5" in the front and 2" out back.
  5. Jalopy Joker
    Jalopy Joker
    lots of fun ahead
    Tow Truck Tom and jsxtreme like this.
  6. DDDenny
    Another one saved!:D
  7. fastcar1953
    fastcar1953
    I really hope you will paint back like it was. Good for getting it back on the road.
  8. jsxtreme
    jsxtreme
    from Michigan
    So, after 3 or 4 different tries, I found a paint color that's pretty close. I hope to one day, but to be honest that has been pretty low down the priority list at the moment. Getting the primer off, embracing the patina will be the short term look. Long term, yeah I hope to restore the body work one day. As you can see, I've soaked quite a bit into it already this year, and I'm just glad to have it on the road at the moment.
    Thanks for the warm welcome, everyone. Been lurking here for a lot of years!
  9. jsxtreme
    jsxtreme
    from Michigan
    One more photo, thought it was cool with the American Flag.
  10. rusty1
    rusty1
    I like it and the truck beside it (any pics of it?() don't paint the 55.
  11. jcrapola
    jcrapola
  12. rusty1
    rusty1
    ^^^ thanx,...cool truck.
  13. bschwoeble
    bschwoeble
    Agreed. I had hoped the whole "patina" thing had run its course.
  14. Squablow
    Squablow
    Great work getting it back on the road and driveable again. I have no issue with old paint, that's pretty much how my '57 looks, maybe with a few more layers on it than yours, but similar. I don't see any harm in it, as long as a guy doesn't slop oil/special sauce on it or clearcoat it, as that's going to make it an extra layer of BS to strip off if you do paint it later, and looks ****y to me. (Doesn't sound like you were gonna anyway, but just wanted to throw that in there.)
    Do you have side trim for it? If so, any plans to put it back on?
  15. jsxtreme
    jsxtreme
    from Michigan
    I mean, for what it's worth at least its not fake patina. And I'm not sure what you guy's expect, I literally just got it running, and I like the patina it currently has. Well, half of it.
    Yep, I have every piece of trim. I'll put it back on after I figure out what I'm doing with the primer on the drivers side. It's in similar condition to the rest of the car.
  16. DDDenny
    If I may be so bold.........DO NOT CLEAR COAT IT!!!
  17. Normally I groan on patina. But majority of the time it's some car the builder found and they have no history with the car. Then they commonly slap some goofy late model engine in in and some ridiculous wheels and go on about preserving the history of the car. Looks to me like you made an effort to preserve or repair what was there already with a few small improvements. So while I'm not a fan of the patina you won't get any hate from me for it. Out of curiosity did he have the paint done back then? Or was it on the car when he got it?
  18. jsxtreme
    jsxtreme
    from Michigan
    It was blue when he bought it in 1979. It was originally neptune green and shoreline beige. Other than the roof, I do not see any of the original color. There is a fair amount of mud in the drivers rear quarter, I ***ume it was hit and that's probably when it got its color change.
    For what its worth, I do not intend to clear coat it.
  19. Then if he didn't do it or have it painted I'd stress even less about painting it. Like I said you get a free p*** from this anti patina guy ;)
    chryslerfan55, 61Cruiser and jsxtreme like this.
  20. Left in patina, or blown apart for a mile deep paint job, the best part is it’s headed back down the road. Congrats on your efforts.
  21. jnaki
    jnaki
    One of my favorite 55 Chevy Bel Air Hardtop Sedans from 1959-60 time period.
    Hello,
    Nice 55 Chevy Bel Air Hardtop… it looks like a fun time to be had while driving down the highways.
    My brother and I always had favorites in the Gas Coupe and Sedan cl***es. They were street coupes and sedans with a little modification here and there to make it go faster on the street. But, at the drags, unless your old car was stock, those “hot rods” got put into the Gas Coupe and Sedan cl***es.
    My brother’s favorite was Doug Cook’s Tahitian Red 37 Chevy Coupe in B/gas and C/Gas cl***es. Mine was the Junior Thompson B/Gas 41 Studebaker Sedan. One or the other was the champion in either cl*** during our participation days.
    But, in 1959, a rumbling was read about a Midwest 55 Chevy Bel Air running in B/gas that was winning everything at every dragstrip entered. No one had a Bel Air Hardtop Sedan modified to race at Lion’s Dragstrip at the time. Several 55-56-57 post models were in the stock cl***es and in the gas coupe cl***es. We were impressed at those stories and record achievement from the 55 Bel Air Hardtop. YRMV
    Jnaki
    Then in March 1960, we actually saw the 55 Bel Air Hardtop sitting in the pits during the 2ndBakersfield Smokers March Meet.
    Since my infatuation with the overall build and records, I made a video clip that includes what that champion record setting 55 Chevy Bel Air Hardtop sounds like at the drags. It is the real sounds of Mike Marinoff’s 55 Chevy Bel Air Hardtop off of an LP album I have.
  22. jsxtreme
    jsxtreme
    from Michigan
    What I'm calling "round 2" is done. Don't hate me for the headlights, I don't care for them much at all. But at least I can see to safely drive at night. I am going to explore other options.
    I dig the slicks on it. It has that drove it home from work, swapped to my slicks to head out to Woodward for the night look to it.
    Lowered 2.5" via coils in the front and beltech drop shocks
    Lowered 2" rear
    Hoosier 26.5" x 8" hoosier slicks
    New Headlights
    Front turn signal sockets and harness - new amber lens covers
    Relocated radiator to behind the core support for hood clearance
    New fan
    Electric Choke replaced and rewired
    Removed excess wiring, and replaced much of the front harness
    Replaced rear emblem
    Trunk lock
    Glove Box Lock
    Replaced GT steering wheel with original '55 wheel
    Remove the primer from the hood, emblems cleaned up and reinstalled
    Last things I will probably do this winter are:
    Replace front and drivers side floor
    Replace drivers rocker
    Remove primer from drivers side
    Mount trim
    Carpet
    Exhaust (smithys of course)
  23. Motorwrxs
    Motorwrxs
    Like where it’s going…very cool.
    chevy57dude likes this.
  24. chevy57dude
    chevy57dude
    Dang, I just love the shape of a '55 hardtop! You can't even hide it with ''rough'' paint. I was really hoping you would choose wheels other than rallys. Man, they were popular for a while, if it wasn't pro street, Rallys with all kinds of caps, painted body color, you name it. Now they scream '80s on a tri 5. Great to see you've saved your uncle's car. Has he seen it lately?
  25. Looks great !!!
  26. jsxtreme
    jsxtreme
    from Michigan
    He p***ed July 2nd of this year, unfortunately. That his name on the side gl***. Been getting it running in his memory.
    Thanks for the kind words, everyone. Its been a lot of fun.
  27. jsxtreme
    jsxtreme
    from Michigan
  28. rusty valley
    rusty valley
    It is incredible what wrapping the car in a plastic tarp can do. As you stated "holding moisture", and yet I still see it all the time, cars wrapped up like a mummy...to die
  29. jsxtreme
    jsxtreme
    from Michigan
    It 's literally a humidity chamber. Then it gets a rip or tear in it somewhere water can get it, and well, this is the result.
  30. chevy57dude
    chevy57dude
    What does the interior look like? I can see some kind of bucket seats.
    lothiandon1940 likes this.
