Hot Rods The ALTERED thread
Discussion in 'The Hokey Ass Message Board' started by loudbang, Mar 3, 2016.
  1. Sky Six
    Sky Six
    from Arizona
  2. Sky Six
    Sky Six
    from Arizona
  3. Sky Six
    Sky Six
    from Arizona
  4. Sky Six
    Sky Six
    from Arizona
  5. Sky Six
    Sky Six
    from Arizona
    The correct way to leave the bleach box.
  6. Sky Six
    Sky Six
    from Arizona
  7. Mike VV
    Mike VV
    from SoCal
    NOT...a rare picture at all. It's ALL over the net where Fuel Altereds are shown.
    BUT...it is, one of the best, and most often shown,.
    Mike
  8. 31 Coupe
    31 Coupe
    This is MY favorite .....
    Willie going through the RIVERSIDE traps with the front wheels in the air and on full lock ..... rear tires almost pulling off the rims.
    If that's NOT Fuel Altered perfection then what is.
  9. mohr hp
    mohr hp
    from Georgia
    Absolutely!!! Had a poster of this one long ago. Looking closer, Willie's running off the edge of the track and has no sign of letting off. Steve Reyes claimed Willie was over 200 here. Ultimate Bad-***ery!
    GasserTodd, Deuces, bchctybob and 3 others like this.
  10. AmishMike
    AmishMike
    Even the moon eyes on Willie’s fuel tank look scared
    49ratfink, GasserTodd, Deuces and 6 others like this.
  11. Mike VV
    Mike VV
    from SoCal
    Looks like the slicks are a little concerned too ! Pulling themselves up tight.
    Mike
  12. AmishMike
    AmishMike
    Actually that normal for newer design slicks with low air pressure. As diameter changes ( larger ) gives more top speed.
    Deuces and chryslerfan55 like this.
  13. Mike VV
    Mike VV
    from SoCal
    No..."newer" (as you say) slicks bead, will NOT pull away from the rim as shown in Willys car above.
    Why, all current cars use beadlock wheels/rims where the tire bead is secured to the rim of the wheel with an extra ring bolted to the rim of the wheel, with many cap screws.
    The current design tires still do grow at speed, the tread still gets skinny and round also from the speed (or rpm), but the bead stays firmly secured in place.
    They also do not normally use inner tubes.
    Mike
  14. 31 Coupe
    31 Coupe
    In the old days before Beadlocks became available they ran "Inner Liners" which were inflated separately to the slick, they also served to hold the tire bead against the rim flanges to help avoid what was trying to happen in the above photo.
    bchctybob likes this.
  15. Mike VV
    Mike VV
    from SoCal
    And before that they ran just tubes.
    But I'm betting that Willys picture above is only tubes. The heavy liners didn't come along until later.
    Mike
  16. 40ragtopdown
    40ragtopdown
  17. Sky Six
    Sky Six
    from Arizona
  18. Dave G in Gansevoort
    from Upstate NY
    Thanks for that! Just spent the last couple of days going thru this 10 to 15 pages a night. Great cars, big br*** ones to drive them...
    49ratfink, mohr hp and Sky Six like this.
  19. Sky Six
    Sky Six
    from Arizona
  20. tommyd
    tommyd
    from South Indy
  21. Sky Six
    Sky Six
    from Arizona
  22. Mike VV
    Mike VV
    from SoCal
    From above -
    Interesting shot. On one hand, the rear tires are wrinkled well, the front tire is off the ground, The car appears to be in a mostly straight line with the track, and the wheelie bars are on the ground.
    BUT...the injector ****erflies are closed, or mostly closed ?
    Mike
  23. Fordors
    Fordors
    Or are the blades horizontal and we’re just seeing the throttle rod and the gray cast aluminum in the injector hat?
    lurker mick and Sky Six like this.
  24. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    That's what I think - if you blow it up it appears the plates are below the shaft and the plate screws are on top...
    Fordors and Sky Six like this.
  25. Sky Six
    Sky Six
    from Arizona
    Excellent question, but in the original version of the picture, the blades are wide open. Just a split-second photo catch.
    Fordors likes this.
  26. tommyd
    tommyd
    from South Indy
    I didn't realize I had posted this in the altered thread. Must have been half asleep.
  27. Sky Six
    Sky Six
    from Arizona
    At least you have an excuse. Me on the other hand...:)
  28. Mike VV
    Mike VV
    from SoCal
    Nope, pretty clear on my computer screen.
    Mike
  29. mohr hp
    mohr hp
    from Georgia
    Robbed from Slayer in the Comp Coupe Thread.
    49ratfink, 300racr, rod1 and 11 others like this.
  30. slayer
    slayer
    These were on display at the Romin Cariots car ckub show in Blue Island ILon 9/28. You missed one ;).
    I just realized i had loaded all the pics and info to post here, but never hit POST. :rolleyes: IMG_20240928_132323167_HDR.jpg
