Technical 53-54 Bel Air Gauge install
Discussion in 'Traditional Customs' started by Clifford Sukeforth, Aug 30, 2024.
  1. Clifford Sukeforth
    Clifford Sukeforth
    I have a set of Dolphin gauges for my 53 bel air. I tried installing them from behind the dash ( Bezel - dash - gauges) and then in between the bezel and the dash ( Bezel - gauges - dash) both don't fit well and have big gaps. Do i need to modify the dash? Not sure what I'm missing but any help would be appreciated.
  2. Any pics of what you're working with?
  3. fastcar1953
    fastcar1953
    If their in a panel then they should go between dash and bezel.
    The Chevy Pope likes this.
  4. fastcar1953
    fastcar1953
    Is the panel also the bezel? Pictures will help a lot.
  5. Clifford Sukeforth
    Clifford Sukeforth
    PXL_20240901_154649761.jpg PXL_20240901_154837432.jpg PXL_20240901_154853403.jpg Sorry for the delay in photos. Not sure what the sequence is in parts. Ie..bezel-gauges-dash or bezel-dash-gauges. Do I need to modify the dash?
  6. fastcar1953
    fastcar1953
  7. flux capacitor
    flux capacitor
    IMG_1430.jpeg IMG_0039.png I recently did theirs & yes you’ll need to cut off wheel a little of the top portion & speedo area as I did your dash in “green” leaving the shape of holes for attachment . & work the reinforced area of spot weld off by wiggling with pliers & it’ll come off leaving a flat smooth surface “flush mounting” the bezel
  8. Clifford Sukeforth
    Clifford Sukeforth
    Thank you for all the responses and the help.
    flux capacitor likes this.
  9. 54FISH
    54FISH
    Yes ,like flux capacitor said . I had to trim my dash to install the bosses aluminum insert with Cl***ic instrument gauges .Not much ,and then it just fit .But I went slow with little cuts to make sure it was still a tight fit .
  10. 325w
    325w
    Used an air hacksaw on the 54 I did that dash.
    Clifford Sukeforth likes this.
  11. 54FISH
    54FISH
    NICE!! That's what I used also , a small Sawzall, like ****er . Turned out good!? Mine was harder to wire gauges than put the gauge cluster in . I would wire all gauges first if I did again .
