Technical Whose engine is this?
Discussion in 'The Hokey Ass Message Board' started by Jibs, Sep 8, 2024.
  1. Jibs
    Jibs
    Whose engine is this? I saved this photo from a thread on here, but did not save the thread, anyone know who owns this engine? Thanks
    atch, okiedokie, Spooky and 1 other person like this.
  2. squirrel
  3. Jibs
    Jibs
    Thanks Squirrel.
  4. fastcar1953
    fastcar1953
    Tow Truck Tom and Weedburner 40 like this.
  5. Jibs
    Jibs
    It is his, I didn't know his HAMB name.
    Tow Truck Tom and chryslerfan55 like this.
  6. southpaw-customs
    southpaw-customs
    Yes, that's mine.
  7. 51504bat
    51504bat
    Love the red and cream color combo. Custom colors or ? Thanks
  8. ALLDONE
    ALLDONE
  9. Hot Rods Ta Hell
    Hot Rods Ta Hell
  10. southpaw-customs
    southpaw-customs
    I have a dupont can that says Dale Jarrett Ford Motor Credit Red from 1998. The cream is off of a 1960 Edsel. The red just makes it look creamier.
    PoTaToTrUcK and 48stude like this.
  11. 51504bat
    51504bat
  12. MOONRNR
    MOONRNR
    Those look like FE rocker covers - BIRD raised letters?).
    How did you do that?
    BEAUTIFUL WORK!
  13. Oneball
    Oneball
    Looks like there’s an adapter between the covers and the head.
  14. southpaw-customs
    southpaw-customs
    Adapter plate.
    48stude likes this.
  15. Jibs
    Jibs
    Did you make the adapter plates?
  16. southpaw-customs
    southpaw-customs
    A friend of mine helped me with them. A lot of trial and error, but that's to be expected. We used valve cover gaskets for a pattern. 1/2" thick aluminum is what we had laying around. The top center hole is a little tricky. Had to grind down a allen screw to fit it. Used permatex ultra black between the adapter and the head and a FE valve cover gasket on the top side. Word of CAUTION, do not use the Right Stuff. It's a good way to ruin a set of valve covers.
    I see where you can buy adapters for about anything now.
  17. tjm73
    tjm73
    Hey I was looking at your set up and I see you have the alternator mounted high and to the drivers side. Is that a mix of a stock upper mount and a custom lower mount, or a stock alt mount system re-positioned or an all custom setup?
    I've been looking for a simple stock-like high mount that tucks the alternator in close to the engine. Yours is the best I've seen yet.
    southpaw-customs likes this.
  18. southpaw-customs
    southpaw-customs
    I used a CJ Pony ALTB4 upper bracket and wanted a beefer lower and made it. For harware CJ Pony ALTM1133 mounting hardware. Made a new lower spacer out of aluminum. The steel one was too long for my application.
  19. southpaw-customs
    southpaw-customs
    Those are stock 61 Thunderbird Valve Covers. Already have the raised letters in them. Thank you for the kind words.
    winduptoy and alanp561 like this.
