Hot Rods 32 Highboy roadster 16" tire size....?
Discussion in 'The Hokey Ass Message Board' started by wildwest, Sep 9, 2024.
  1. wildwest
    wildwest
    I need some profile pictures of 1932 Ford highboy roadsters with a couple different tire sizes..... Please ?
    I want to run whitewalls on my car, I have 16"x 5" wheels, and I cant decide between 5.50-16 and 6.00-16. In the tire I plan on running, those are the two choices I have.
    I plan on going 7.50-16 in the rear
    anyone have any pictures of cars with known tire sizes ?
  2. No offense @wildwest , but umm, pictures would help give us an idea of what you’re working with.
  3. Dino 64
    Dino 64
    from Virginia
  4. Malcolm
    Malcolm
    from Nebraska
    I'd probably go with 16x5.00 or 16x5.50 up front.
    teach'm, lothiandon1940 and Tim like this.
  5. krylon32
    krylon32
    from Nebraska
    I like 500-16's on the front and either 750/16 or 700/18's on the back.
    lothiandon1940, Tim and 38Chevy454 like this.
  6. alchemy
    alchemy
    I think a 6.00 tire is too big for the front. 5.50 at the largest. Prefer a 5.00.
    RICH B, lilCowboy, clem and 1 other person like this.
  7. ALLDONE
    ALLDONE
    I did 7.50's and 5.00 , but thought they were too small in the front so went to 5.50's,
    Just Gary likes this.
  8. ALLDONE
    ALLDONE
    wwhen I did the 500's on the full fendered A without a drop axel they looked way too small... but thats the size I allways go to, but this is a first for me to have a stock axel..
  9. 4.50/4.75-16" is perfect match to the 7.50-16's in Firestones
    Just Gary and 38Chevy454 like this.
  10. clem
    clem
    5.50 would be my choice as I think that 6.00 looks too large as @alchemy says.
    for anyone else reading this thread , if you drop below 5.00 you might like to check the load ratings. It may surprise you.
    Plenty of threads about all of this.
  11. rusty rocket
    rusty rocket
    If your going to run bias look radials 5.50 is the smallest they make. 796F43CE-5C01-4617-B917-92D913097FB1.jpeg These are diamond back cl***ic auburn deluxe 5.50 16” and 7.50 16
    Just Gary and Kiwi 4d like this.
  12. wildwest
    wildwest
    I will take a picture of the car as it is tomorrow when I go back to my shop. Thanks for all the pictures so far.
    The one reason I wanted to go with a 6.00-16, was the whitewall itself is an inch bigger than the 5.50-16, and the amount of white looks more in-proportion to the rear. but it does make a pretty tall tire.
    A 6.00-16 and 7.50-16 are 3" different in total diameter
  13. wildwest
    wildwest
    Here is the car as it looks now, I have some other changes planned. The 5 spokes and blackwall tires that are on it now might be an alternate set to steel wheels & whitewalls. I already had them, and needed something to put it on for awhile. I kind of like a taller tire than some on the front of 32 highboys, the ones on it now are 6.70-15.
    deuceman32 likes this.
  14. Duke
    Duke
    • 600x16 on 4” rims and 750x16 on 5” rims Diamond back auburns. Stock front axle. IMG_3975.jpeg
    deuceman32 and catdad49 like this.
  15. catdad49
    catdad49
    Just Gary and lothiandon1940 like this.
  16. wildwest
    wildwest
    Thanks for all the replies so far. Years ago, when I was a teenager, I had a picture on the wall of my bedroom, probably the center out of a Rod & Custom ? that was a dark green roadster, it might have even been a 29. It had big whitewalls front and rear, on black wheels, and it looked awesome. I wish I could remember more about it, but that was 25 years ago...
    Here is a roadster I saw at Puyallup this year, it had 6.00-16 and 7.50-16. I think a whitewall would make it look a bit lighter ? not sure.
    lucky and catdad49 like this.
  17. DDDenny
    I dig the five spokes!
    clem and Bentrodder like this.
  18. wildwest
    wildwest
    Thanks ! I love the 5 spokes too ! I have ran that set on a few different cars, the front wheels I have had almost 20 years and they have been on at least 6 cars that I can think of. I am going to sand down the sidewall on the rear tires. straight spoke 5 spokes are probably my favorite wheel of all time, but its kind of fun to have a couple sets of wheels/tires.
    I searched around today and actually found the poster I had on my wall as a teenager ! The magazine is long gone. I wish I could see the tire size, I looked with a magnifying gl***, but no luck. Anyone know this car, or what the tire size is? I'm guessing 6.00-16, and 7.50-16 but ?? It was in American Rodder some time in the later 90's ?
  19. teach'm
    teach'm
    from Tucson, AZ
    Hello @wildwest,
    We ran 5.50/16 and 7.50/16 Firestones on original 4.5" wide steel wheels on our old roadster.
    clem, Steve009, rat bastad and 2 others like this.
  20. Bluestreak-PA
    Bluestreak-PA
    from Erie, PA
    These are not white walls but front are 5.50x16 on 4" wide wheels and rear are 7.00x16 on 5" wide wheels.
  21. Steve009
    Steve009
    from Ottawa
  22. chickenridgerods
    chickenridgerods
    from DSM, IA
    They only look too small because your car isn't lowered in the front and you can see a bunch of daylight between the tire and the fender.
    clem likes this.
  23. clem
    clem
    I think the large white walls detract from the car.
    You see the tyres first, as the car is hidden behind them.
    Better balance to @catdad49 coupe in post 15, but his is not a high boy.
    catdad49 likes this.
  24. catdad49
    catdad49
    Yep, the fenders add a little more “meat”.
    clem likes this.
  25. V8 Bob
    V8 Bob
    I'm running Firestone 16" 500/525s on front, 750s on rear. Something to keep in mind are tire load capacities and your car's actual weight, and is why I chose the 500/525s with max load cap. of 1070 lbs, vs the 450/475s with 660 lbs. My '32, with hood, top, trip tools and 1/2 tank (9 gal) of gas weighs just under 2600 lbs, with 1240 lbs on the fronts. Add two people and you're easily pushing 3000 lbs GVW.
    HemiDeuce likes this.
