Projects 32 5W Build - The $4K Swapmeet Body / The Old Chrome Coupe
Discussion in 'Traditional Hot Rods' started by NealinCA, Feb 2, 2023.
  1. Pete Eastwood
    Pete Eastwood
    from california
    Neal, for the brakes, do you do inverted flair on the stainless tubing ?
    31chevymike, rod1, HemiDeuce and 2 others like this.
  2. NealinCA
    NealinCA
    Yes, they seemed to form nicely using an Eastwood flaring tool, as well as my old Imperial Br*** flaring tool. Stainless tube is from Inline Tube. Anything I should be worried about?
    31chevymike, rod1, Tim and 3 others like this.
  3. Pete Eastwood
    Pete Eastwood
    from california
    I'm still learning things. This is the first time I've heard of inverted flairing stainless.
    Of course I'm a dinosaur, so there's things being done I know nothing about !
    Keep up the fine work!
    31chevymike, brEad, NoSurf and 8 others like this.
  4. tick tok mr jenings tick tok. :)
    31chevymike, RMcCulley and porkshop like this.
  5. hotcoupe
    hotcoupe
    Regarding flaring S S. tube, I was always advised to use a 37° flare, never use a 45° inverted flare.
    In addition, always cut the tubing with a hack saw, never use a tubing cutter. The tubing cutter work hardens the tube right where you need to expand it. Details, details, details.
    Hope this helps.
    Tom
  6. NealinCA
    NealinCA
    Info from Inline Tube:
    Can I double flare stainless steel tube by hand?
    Yes, you can double flare stainless steel lines bought from Inline Tube. Our tube is fully annealed and is very easy to work with. We recommend and offer several good flaring tools: Rigid, Imperial Eastman or Blue Point. Carefully follow all the instructions that come with the tool and the tubing, and the flare will be perfect every time.
    Inline Tube bends hundreds of miles of long-lasting stainless-steel brake line every year. Our stainless-steel lines are more resistant to corrosion, deterioration, and damage than our standard OE steel lines. They are double annealed for supreme workability in bending, straightening, and flaring. All coils have a .028” wall thickness.
    This Inline Tube professional-grade flare kit will form 45° double flares as well as metric bubble flares on OE steel, automotive grade annealed stainless, and any soft metal tube.
    Please note: All Inline Tube bending and flaring hand tools are designed to be used with fully annealed automotive grade tubing with a wall thickness of .028”. As such, we cannot guarantee results or tool performance using these tools with any other grades or wall thickness.
    The annealed stainless tubing seems to be the key here and not what we have heard about in the past with stainless tubing cracking when double flared.
  7. 05snopro440
    05snopro440
    Yep annealed will be easier to flare as it's softer. However it will still work-harden, so you still need to be careful with how you cut and flare it.
    31chevymike and Ken Smith like this.
  8. hotcoupe
    hotcoupe
    Always follow the manufacturer's recommendations.
    Tom
    31chevymike likes this.
  9. Fogger
    Fogger
    42 years ago when I plumbed my 3W with stainless and AN fittings the annealed stainless was not available locally. Great that you can use standard br*** fittings especially on the correct built that is going together. I gave my 37 degree flaring tools to a friend, doing one car was enough for me. The 4K 5W continues to amaze!
    31chevymike and porkshop like this.
  10. deuceman32
    deuceman32
    So it starts off fully annealed and then it gets fully Neal'd, and then it's perfect. Man, you do inspirational stuff. And Pete's back, too. It just gets better and better.
  11. Pete welcome back, your expertise has been missed.
    31chevymike, C69A, Fogger and 3 others like this.
  12. Body looks incredible. ****s about the oil leak good to see you have a good spare engine. This is easily one of the best build threads on the HAMB (tied with Cody Wall's Ardun Killer thread).
    Really inspiring stuff, you are doing an incredible job Neal.
  13. The37Kid
    The37Kid
    I know you can buff finished stainless brake lines to look like chrome, just be careful.
  14. tim troutman
    tim troutman
    wow car is looking great. I vote for the chrome wheels in the last photo
  15. banjorear
    banjorear
    Sorry to hear about the 1st engine, but glad you had a spare. Onward and upward!
  16. NealinCA
    NealinCA
    Progress today. Brake lines done. Seat mounted. Dash installed. Hopefully the engine goes in tomorrow.
    20240914_174327.jpg 20240914_174541.jpg 20240914_175220.jpg 20240914_175622.jpg 20240914_184247.jpg 20240914_190538.jpg
  17. atch
    atch
    You're gonna have to wear sungl***es even at night driving that thing.
  18. RMcCulley
    RMcCulley
    They will probably have to pause the RPM Nationals because everyone will be too busy checking out your car; what a work of art.
    31chevymike, brEad, porkshop and 2 others like this.
  19. NealinCA
    NealinCA
    We got the brakes bled, engine in and made it out of the shop under it's own power. I have some ignition issue, as we made it to the end of the block and it died. Fuel, but no spark. Gonna swap out the coil and then condenser and see if either fix the issue. 20240915_154737.jpg 20240915_154725.jpg 20240915_155942.jpg 20240915_183347.jpg 20240915_204102.jpg IMG_20240915_200536.jpg
  20. Outback
    Outback
    from NE Vic, Oz
    Getting closer! & Looking good. I would have said that engine looks amazing, (& it does) but knowing what the lavender one looks like when it's all dolled up & ready to go causes a pause as I know what's coming.
    It looks great, but..... I wish I could see this one in person...
    31chevymike, NealinCA and porkshop like this.
  21. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    Obviously the car is already amazing, but I'm really just envious of the amount of skill required to put something together that looks like that in such a short amount of time...
  22. NealinCA
    NealinCA
    I replaced the coil and made a successful lap around the neighborhood. Lot's of little things to finish up now.
    20240916_104559.jpg 20240916_104628.jpg 20240916_104613.jpg 20240916_104648.jpg
  23. Fantastic progress!
  24. pprather
    pprather
    Congratulations on first neighborhood cruise.
  25. Tim
    Tim
    from KCMO
    Saw the videos on IG looks and sounds fantastic! Congrats
  26. heavydumper
    heavydumper
  27. NealinCA
    NealinCA
    Got the polished stainless scavenger pipes installed this afternoon.
    20240916_165226.jpg 20240916_181639.jpg 20240916_184940.jpg 20240916_184834.jpg 20240916_185259.jpg
  28. Hitchhiker
    Hitchhiker
    She looks incredible. Good job Neal!
  29. Roothawg
    Roothawg
  30. Roothawg
    Roothawg
    What's his name on IG? I need to follow this.
