Hot Rods 1940 Ford Pickup Bed assembly question
Discussion in 'The Hokey Ass Message Board' started by golferforpar, Sep 10, 2024.
  1. golferforpar
    golferforpar
    from Wisc
    I purchased a 1940 Ford pickup box from Midwest Early Ford, I have ***embled it and have a question. There are 2 pickup "bed side filler panels" that fill the gap between the top of the running board and the bed side. There are no holes to indicate the filler panel gets bolted in place to the box, should it be welded to the box? I hesitate to weld it permanently to the box as it looks like it would make handling the complete box ***embly allot more ***bersome with them just hanging in mid air. The instructions don't indicate what to do, what have you done with these panels? Any reason I should not bolt them on?
    Thank You
    Bandit Billy likes this.
  2. Doublepumper
    Doublepumper
    from OR-WA, USA
    My '46 has the panels bolted on from the factory. I installed them after the bed was in place and before installing the running boards.
  3. hotrodA
    hotrodA
    My originals are bolted on.
  4. Bandit Billy
    Bandit Billy
    You talking about these panels?
    I used aluminum pop rivets. Easy enough to drill out if I have to dis***emble the bed. Much easier than nuts and bolts.
  5. Racerex
    Racerex
    I fastened each side together with four 10-32 machine screws. Nylock nuts are best for these so they don't vibrate loose.
  6. HK 40
    HK 40
    Have done 3 beds bolted all 3 can even be done after boards are on if you pre drill holes
  7. TwistedMetal
    TwistedMetal
    from Wisconsin
    Big question Billy is what is this creepy animal thing in the background? :eek:
    Fortunateson and Bandit Billy like this.
  8. Bandit Billy
    Bandit Billy
    Looks to be a pterodactyl making off with my Crown! I knew I have been going through too much.
    TwistedMetal likes this.
  9. golferforpar
    golferforpar
    from Wisc
    That is the panel,
  10. Bandit Billy
    Bandit Billy
    They aren't something that is going to be R&R'd often if ever. I left them off until the bed was permanently mounted (my lift arms go under the bed right there) and attached them simply and quickly before mounting the hardwood.
  11. joel
    joel
    There is a hole in the rear fender on my '41 that I thought might also attach the panel to the fender. I don't know as I'm not there yet.
  12. Bandit Billy
    Bandit Billy
    I don't think so Joel. If there was, I welded it up when I was doing my body work.
