Technical Recommendations for A dwell meter
Discussion in 'The Hokey Ass Message Board' started by wheeltramp brian, Sep 10, 2024.
  1. wheeltramp brian
    wheeltramp brian
    I'm looking to buy a dwell meter Is that is just that. Dwell and rpm. I like the old style ones with the needle. And I've bought a couple but they're all old and junk. Does somebody make one like it? I've got a dwell meter on my timing light, but it works on 12 volts and a few of my customer's cars and one of mine is 6 V. Any recommendations?
    Sharpone, Algoma56 and chryslerfan55 like this.
  2. All I can say is don’t umm, DWELL on this too much. Hehe.
  3. pprather
    pprather
  4. oldolds
    oldolds
    Try a pawn shop? You might find an older good brand
    Sharpone likes this.
  5. wheeltramp brian
    wheeltramp brian
    I ordered a couple new old stock ones from eBay, but they turned out to not work at all. I just ordered another one new in the box so we shall see.
  6. 6sally6
    6sally6
    IF you're a FoMoCo guy.....throw them in the s---can !
    They are useless.(duraspark/Ford distribs. don't have a window OR the adjustment screw a Shivel-lay does.)
    6sally6
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    I have had great luck with these vintage RAC dwell meters, I have a number of them that I have bought at swap meets some used some NOS and every one of them work IMG_1417.jpeg
  8. ClayMart
    ClayMart
    Is a dwell meter even voltage sensitive?
    Sharpone and 49ratfink like this.
  9. wheeltramp brian
    wheeltramp brian
    Don't think so but my timing light is 12v and has a display and doesn't work on the 6v
    Sharpone and chryslerfan55 like this.
  10. 49ratfink
    49ratfink
    I don't miss points at all. especially on a daily driver
    Truckdoctor Andy and bobss396 like this.
  11. wheeltramp brian
    wheeltramp brian
    2 of my dailys have points.one is dual
    Sharpone, Moriarity and 49ratfink like this.
  12. tubman
    tubman
    The factories seem to have electronic ignition pretty well figured out; the aftermarket, not so much.
    To get back to the original subject, I just bought one off of eBay. It does not need external power and works just fine.
    Sharpone and Budget36 like this.
  13. Budget36
    Budget36
    Share a link?
  14. SS327
    SS327
    Why don’t you just use a 12v battery to power it?
  15. Oneball
    Oneball
    I couldn’t find a new ****og one recently so bought a digital one. Works fine for gapping, whether it is too damped to show any flutter I don’t know.
  16. Mr48chev
    I've got an old ****og that I bought at a church yard sale a few years ago. I'll have to wait until my OT truck gets back from having a pilot bearing and clutch installed ( Pilot bearing froze up and I am not physically able to wrestle with the compound 4 speed) to test it but I just bought it because it was an old dwell meter/tach and don't have a need for it and if it works after I test it you can have it for what ever the cost of the USPD priority mail box is.
    pprather likes this.
  17. Damon777
    Damon777
    I too was looking this week. I considered a vintage Snap-On from ebay, but just grabbed a cheap "automotive" DMM to get me by for the time being. It's gotta be as accurate as a matchbook, right?
    In my research on dwell setting (never done it before, didn't even know what it was), I ran across a youtube video on using dwell to set points on Mopar (and Ford) stuff. He just cranked with no cap and set them that way.
    If you are interested:
    I time my 6V stuff by using an outboard 12V battery to power the light. Works just fine.
    Sharpone and rattlecanrods like this.
  18. bobss396
    bobss396
    I have an OG Sears one, unless it got pitched in a frenzy. I will take a look for it today.
  19. tubman
    tubman
    I meant "merely bought one off eBay", not "recently bought one off eBay". It was several years ago, so sorry, no link. Just a typical old ****og tach/dwell meter (used), unpowered that works on any voltage. I favor old Mallory flattop dual point distributors and it is necessary to set the points.
  20. 50chevytx
    50chevytx
    I have a FoxValley tach-dwell that is just like the one my dad used in the 60’s. It didn’t work when I got it. Usually it the batteries inside are old and leaking. I took it apart cleaned all the battery contacts replaced the batteries works like new. IMG_2823.jpeg IMG_2824.jpeg
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    I kinda collect em. When they are cheap at a swap meet I grab them
  22. 51504bat
    51504bat
  23. 51504bat
    51504bat
    Back in HS I had a 289 Ford and I could never set points with any accuracy with a feeler gauge when checked with a dwell meter. I ended up cranking it over without the cap to check the dwell. I do remember the cranking dwell vs the running dwell was always a bit different. So it took several attempts to dial it in. Not a Chevy guy but I still wished that Ford used a window cap distributor. It certainly would have made it easier to set the dwell.
  24. pecker head
    pecker head
    IMG_3585.jpeg I have a couple, I got them at swap meets. I run points in my coupe & RPU.
  25. jaracer
    jaracer
    I know you want an ****og meter, but most good digital volt/ohm meters will measure duty cycle which is what dwell is.
  26. jaracer
    jaracer
    The Fox Valley meter was the first piece of "electronic" test equipment that I bought around 1969. I still have it.
    Sharpone and 50chevytx like this.
  27. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Turn this into a tech thread.
  28. Johnny Gee
    Johnny Gee
    from Downey, Ca
    @Moriarity your face… IMG_3048.jpeg has served much better then the one I have.
    I’ll go out later and pull the Sun kit down and take a pic of it to show how badly mine is cracking.
  29. TA DAD
    TA DAD
    from NC
    The GM HEI system has a dwell reading when the module is working correctly. I don't remember the numbers at the moment. I think it was around 15 at idle and increased with rpm. So the meter is useful for more than setting points.
  30. I bought mine off E Bay. It was new or used very little. Works like a champ on my 6v and 12 vehicles.
    was $20.00 shipped.
    Vic
