Show me you Custom dash in your Model A
Discussion in 'The Hokey Ass Message Board' started by luckypots, Jul 1, 2011.
  1. pprather
    pprather
    I cut the entire front off an old tank. Hung it from the windshield valance.
    Stock gas tank. Site gl*** fuel gauge, with jeweler's lupe glued to back side to magnify tank mounted site gauge. Modern instruments with stock speedo.
    Fabricated sub dash to house switches on left end and 1din audio on the right end.
    skooch, CSPIDY, deadbeat and 4 others like this.
  2. 41blueoval
    41blueoval
    Speccie, CSPIDY, dana barlow and 2 others like this.
  3. fourspd2quad
    fourspd2quad
  4. Russ B
    Russ B
    1928 Chrysler
    alchemy, hotrodjack33, jet996 and 6 others like this.
  5. This one caught my eye at the Detroit Autorama. Created and executed by the owner. 7ED96CDE-CB28-4343-AC97-15490175510F.jpeg
  6. '29 Gizmo
    '29 Gizmo
    from UK
    Modified stock dash for me. Just the basics for a 4 banger. 20240913_110711.jpg
    dana barlow likes this.
  8. dana barlow
    dana barlow
    from Miami Fla.
    Old Thread,but a good one.
    I kept it on the simple side,oil/water temp/speed-O stock 28A hooked into 57 Ford ******, light switch n key, did ad some wood as a new upper dash rail,,on last rebuild.
    I had stored a few parts badly,so rust set in hard. Had to do some fix's.
    The topper dash rail layed on garage floor near leaky window=rusted out bad.
    After hunting replacements,I just made one out of wood to match other wood in ****pit. 009.JPG
    hotrodjack33, jet996, CSPIDY and 2 others like this.
  9. Stu
    Stu
  10. fourspd2quad
    fourspd2quad
    It is a military wheel. I don’t know what for. You can see in the unfinished pic the drab green color.
  11. Blue Moon Garage
    Blue Moon Garage
  12. shortypu
    shortypu
    Jkmar73, X-cpe, dana barlow and 2 others like this.
  13. redzula
    redzula
    33 chevy dash modified to fit and attach to a model a upper dash. With a basic stainless gauge panel. Speedo, Tach, volts, oil press, water temp.
    Will eventually get a 40s ford starter ****on and headlight switch. Rebuilt a 39 ignition lock switch so the key will be in that.
  14. flynbrian48
    flynbrian48
    Never too late to jump in a 12 year old thread. :rolleyes: Here's the '52 DeSoto dash in my '29. 5F6B6490-087F-4690-843A-5906EF2B43E5.jpeg
  15. Dino 64
    Dino 64
    from Virginia
  16. Just Gary
    Just Gary
    Viewed from the p***enger seat::)
    osage orange, Speccie, X-cpe and 4 others like this.
  17. Dino 64
    Dino 64
    from Virginia
    Thanks Gary ! Couldn’t find a good pic ! :)
    Just Gary likes this.
  18. hotrodjack33
    hotrodjack33
    "32 truck dash in a "31 Slantwindow.
    osage orange, X-cpe and Just Gary like this.
  19. Jkmar73
    Jkmar73
    from Tulare, CA
    32 dash in a 31 coupe.
  20. Russ B
    Russ B
    There are many instrument panels from older vehicles that would work nicely in an A. The Es*** ’pinecone’ panel is a particularly attractive one, shown in the middle. They all can be upgraded with new gauges.
    osage orange, 40 Olds, CSPIDY and 5 others like this.
  21. '32 style dash off epay. Painted to look like wood. 17267496676164153218406744562048.jpg
  22. X-cpe
    X-cpe
    I'll finish it someday.
  23. mad mikey
    mad mikey
    1940 dash, real 1940. Ash trays , radio hole , speaker hole, all filled. And filled with lead not bondo, was done in the early 60's. This is a picture from years back. WIN_20141109_163349.JPG
    osage orange, deadbeat, X-cpe and 3 others like this.
  24. lostone
    lostone
    from kansas
    1938'ford, lots of mod work...
  25. Stan Back
    Stan Back
    60 years ago . . .
    alchemy, X-cpe and Just Gary like this.
  26. wheeldog57
    wheeldog57
    deadbeat, X-cpe and sidevalve8ba like this.
  27. Russ B
    Russ B
    Back in the sixties I built an A/SR 29 A roadster. This photo shows the wood dash and instruments while I was converting it to streetable use.
