Technical Front Shackles Question
Discussion in 'Traditional Hot Rods' started by dmar836, Sep 13, 2024.
  1. dmar836
    dmar836
    Maybe a dumb question but how are these three-hole shackles set up? Appears the top holes act as the lower shock mount. If so, are there pros and cons to this? If not shock mounts, what are the top holes bolted to?
    Can't remember where or who posted this one but it's a perfect RPU, IMO!
    D
    dana barlow likes this.
  2. Unkl Ian
    Unkl Ian
    It appears you are correct.
  3. TCTND
    TCTND
    That setup looks easy to build but mechanically iffy.
  4. BJR
    BJR
    I built a car like that with the top hole as the shock mount. Drove and road great. If you think about it it dampens the up and down movement of the axle, plus it dampens the spring getting longer and shorter with bounce. 32 ford fr shock.jpeg
    alanp561, bschwoeble, MMM1693 and 5 others like this.
  5. swade41
    swade41
    from Buffalo,NY
    2OLD2FAST and dmar836 like this.
  6. dmar836
    dmar836
    I'm no engineer but at first I thought the arm would be reduced making the ride more firm or making the shock work more or something. Now I'm thinking the shock might more quickly dampen smaller movements caused by the spring expanding. Then, continue absorption when the axle moves upward.
    Thanks for the quick responses.
    D
    alanp561 and 2OLD2FAST like this.
  7. 2OLD2FAST
    2OLD2FAST
    from illinois
    Why is that ?
  8. jimmy six
    jimmy six
    I see no reason NOT use it. Have you ever jumped up and down on a reversed eye short cross spring straight with no shocks? There may be an 1” or so of travel and probably not even needed.
    alanp561, vtx1800 and jet996 like this.
  9. TCTND
    TCTND
    If you don't understand the geometry involved there's not much point trying to explain it
  10. BJR
    BJR
    Why not try? We all have open minds and can always learn something new.
  11. twenty8
    twenty8
    I would like to hear the reasoning for this not working well. I can't see how the setup would have a negative effect on the ability of the shocks to work. Only thing I am not sure about is if the shock absorbing motion causes any reversed reaction back through the shackle to the spring/axle ???
    One advantage I see is that as the axle moves up, the spring lengthens and moves the bottom shock mount inwards. This would move the shock more towards vertical. So, in theory, the farther the axle moves upwards (bounce), the stiffer the damping would become, making it a somewhat "progressive" setup.
    I see that @TCTND is a retired mechanical engineer, and I am genuinely interested to hear his thoughts.
  12. 302GMC
    302GMC
    from Idaho
    Andy Southard's T pickup ...
  13. 2OLD2FAST
    2OLD2FAST
    from illinois
    A bit condescending don't you think ?
  14. X-cpe
    X-cpe
    If someone doesn't understand the geometry involved, there is every point in trying to explain it.
  15. TCTND
    TCTND
    OK, here's my reasoning. When one wheel hits a bump the axle rises, the spring straightens, and the shackle swings to allow for the increased spring length. With this arrangement the shock is opposing that motion and the resultant force tries to shove the axle sideways. I described it as "iffy" not fatal. Can you drive a car like this? Sure, It's just not a very good way to do it. Apologies to anyone I've offended, none intended.
  16. lostone
    lostone
    from kansas
    What I don't like is that it reverses the action of the shock, many shocks have proportional valving. As in 40/60, they have 60% down and 40% up. Look at gas charged shocks, which was discussed at length in a previous thread, they "push" up against the weight of the vehicle, in this case installed they would do the opposite.
    I too am not saying it won't work, just saying it will reverse the operation of the shock. Also if this design is that good way doesn't auto makers still use it?
    There are many, perhaps millions of designs auto makers used since the beginning of the industry only to come along with a better design, safer operation and designs that did not work out as planned.
    Also just because a show car built a suspension comparable to this setup doesn't mean it was a good idea or even a workable one. But I have seen guys see something in a magazine on a vehicle that looked cool or different and copy it only to be disappointed especially in the 4x4 arena....
    Like I said there is a reason NO auto maker uses this design....
  17. 2OLD2FAST
    2OLD2FAST
    from illinois
    You can compress/ extend a shock with your hands , I don't think that's enough resistance to shift the axle in the ch***is , especially if the spring is properly installed in tension and or the car is equipped with a panhard bar . Plus the shock is supposed to control the action of the spring/ axle . The biggest problem with most shock mounts on straight axles is they are mounted too far inboard , away from the unsprung m*** and the front of the car is not rigid or heavy enough to oppose the movement , similar to holding a sledge hammer by the end of the handle with one hand & expecting completely to control the movement of the head. Feel free to hash this out on your own , I'll watch .
    Ned Ludd likes this.
  18. twenty8
    twenty8
    I can't see how this would reverse the action of the shock. During spring compression the whole axle ***embly is forced upwards as a complete unit (axle, perch and shackles). The shock will still get compressed in a jounce situation.
  19. BJR
    BJR
    No auto maker still uses a transverse front spring either.
  20. lostone
    lostone
    from kansas
    Exactly!! And there is a good reason why.
  21. 2OLD2FAST
    2OLD2FAST
    from illinois
    If you've never used something a factory didn't produce or an engineer didn't approve of , you aren't much of a hotrodder IMO .
  22. gimpyshotrods
    gimpyshotrods
    I don't like that it forces the lower shock bushing into a far greater degree of rotation than conventional mounting.
    This will shorten bushing life.
    How short is hard to say
  23. twenty8
    twenty8
    This thread poses valid questions about the shackle-mounted shock setup, and has the potential to be an interesting and educational discussion.......... unless some can't get to the end of the very first page without getting confrontational because of differing opinions. Can you give us some relevent insight into the actual mechanics of the setup, and any real world pros or cons it may have? It's ok to learn new things, and that comes from discussion, not **** swinging.:rolleyes:;)
  24. 2OLD2FAST
    2OLD2FAST
    from illinois
    I saw this setup . I liked the looks & simplicity . I fabbed my version of it . I have been very pleased with the way it looks & works . I have put in the neighborhood of 40,000 miles on the car without any hint of a problem .
  25. lothiandon1940
    lothiandon1940
    Very interesting thread. Keep it friendly and upbeat everyone.
    Ned Ludd and Kelly Burns like this.
  26. swade41
    swade41
    from Buffalo,NY
    I remember when the cry babies got my thread locked about my t-bucket having no front shocks.
    Even with 2 different driving videos people couldn't see past their own opinion on how it couldn't possibly work.
    This thread probably has the same people replying to it.
  27. Gimpy beat me to it, it would shorten the life in the shackle bushings if the urethane ones were in place. That’s the only negative this non trained mind can see.
    X-cpe and twenty8 like this.
  28. Happydaze
    Happydaze
    It would be very cool if someone could create an animation of this in action. Way above my skillset / pay grade!
    See what I did there? Idea for YouTube content for someone. We've had cowl steering, why not this?
    Chris
    X-cpe and Kelly Burns like this.
  29. Ned Ludd
    Ned Ludd
    In other words, the lower shock bushing fastening detail needs to be designed as a hinge, rather than a rotationally compliant solid attachment?
    alanp561 likes this.
  30. 2OLD2FAST
    2OLD2FAST
    from illinois
    Have not shown any appreciable wear of the lower shock bushings in 15+years & 40k miles , I believe this is a non issue .
