Technical Speedway Motors 9 inch housings, axles & 3rd member?
Discussion in 'Traditional Hot Rods' started by prodjbm, Sep 13, 2024.
  1. prodjbm
    prodjbm
    Looking for a complete 9 inch and Speedway Motors has a housing the exact size I need.
    Then I was looking at their axles and third members as well.
    All seem to be a good price, wondering if anyone here had any experiences with their stuff.
    Application will be a street / strip car.
    Thank you
  2. daleeric
    daleeric
    from Omak
    I used one, 62" with 3.71 posi, cadillac disc brakes. I has worked great so far. Biggest problem I had was installing the bolts in the rear end housing and making sure they sealed. Axles are 9+
  3. Happy with the quality and pricing of Quick Performance.
  4. FrozenMerc
    FrozenMerc
    2nd vote for Quick Performance.
    Just had one of their 9" show up on my door step yesterday.
    Butler 32 and Just.dale like this.
  5. brigrat
    brigrat
    from Wa.St.
    Speedway for street SO SO, Strip no way, unless your running in the 13-14!
    mad mikey likes this.
  6. JalopyJimbo
    JalopyJimbo
    from NE Alabama
    3rd for Quick Performance
  7. TwistedMetal
    TwistedMetal
    from Wisconsin
    I bought speedway housing and axles for my 34. They use 31 spline Currie axles. No issues
    brigrat likes this.
  8. brigrat
    brigrat
    from Wa.St.
    ^^^^^^^^^^^ Guess it depends on how much horse power your running & how much rubber on the rear^^^^^^^^
  9. TwistedMetal
    TwistedMetal
    from Wisconsin
    440 hp, traction lock. Bigger tires. Kind of streetroddy so I won't post a photo.
    brigrat likes this.
  10. TwistedMetal
    TwistedMetal
    from Wisconsin
    depending on price Quick performance would be better option probably
    lumpy 63 and brigrat like this.
  11. prodjbm
    prodjbm
    Thanks for all the quick responses already!
    I am probably at about 450HP in this car
    Thinking maybe speedway fabricated housing and axle package and QP third member.
    Want to save a buck but not spend 2 later on lol
    Desoto291Hemi likes this.
  12. brigrat
    brigrat
    from Wa.St.
    No body, including me never asked what car/truck & how heavy?
  13. prodjbm
    prodjbm
    Good point....a big ole 1964 Fairlane
  14. brigrat
    brigrat
    from Wa.St.
    Before I responded, and if its true, I didn't know Speedway's housings & axles were Currie's axles. I would go with the Speedway housing & axles BUT a Quick Performance 3rd. member. Your not "heavy" and didn't mention tubbing out the rear so you should be good to go.
  15. swade41
    swade41
    from Buffalo,NY
    Speedway housings are made in the USA and have internal bracing, I know plenty of high horsepower cars using the housings, me included.
  16. brigrat
    brigrat
    from Wa.St.
    Internal bracing what will they think of next! Love it!
  17. brigrat
    brigrat
    from Wa.St.
    After looking at your pic is that the only "internal" bracing? That's not in the area of "twisting". I am not doubting your claim of " lots of high HP using them" at just trying to learn along with the rest of us!
  18. prodjbm
    prodjbm
    swade41
    That looks pretty nice.
    I'm finding that all the speedway housings that I have been looking at, are tapered bearings, is that what you have?
    Searching online, tapered vs sealed bearings sems to be the big debate. I can see the h***le of an oil seal change. Speaking of oil seal, does that housing in the pic accept the inner seal?
    Thanks for the help
  19. swade41
    swade41
    from Buffalo,NY
    I use 35 spline Moser axles with sealed bearings, torino ends on the housing
    Desoto291Hemi, mad mikey and lumpy 63 like this.
  20. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Mee Too
    They worked with me to get me axles for a somewhat oddball 9".
  21. deathrowdave
    deathrowdave
    from NKy
    Nothing is made so strong that a right foot to the headlight can not destroy . Kinda like rolling down the window and tossing dollars out the window . Man your the winner !
  22. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    http://www.quickperformance.com/
    Just call them , discuss your specifics and they will fix you up.
    They specialize in rear ends / components.
    Ala-Cart this or that to save a buck..... just cost you more trying to marry supplier/ mfg's as there is always something that seems to just not jive.
    X-cpe, rattlecanrods, brigrat and 2 others like this.
  23. old school rodder
    old school rodder
    Not only does Quick Performance have quality parts, but they have great pricing and customer service. To me, I'll pay up for good customer service these days. I've been to their shop to pick up stuff, nice place to visit. They walked me through a 10 bolt set-up when I knew very little and asked a lot of dumb questions. Very patient knowledgeable people.
    JalopyJimbo likes this.
  24. Which ever way you go pick up a Lube locker gasket. Clean no leak install. Those 3/8 studs for the center? I put a dab of old style Permatex non hardening sealer around them before I install.Use the copper washers under the nuts,and you should have a dry clean 9 inch.
    swade41 likes this.
  25. prodjbm
    prodjbm
    Thanks everyone! I have used QP before for my 9 inch in GM A body. Ended up getting what I needed for my 64 Fairlane from QP because of the customer service. Delt with Sam from QP and he was patient and great.
