Technical replace all my oil pump cover bolts?
Discussion in 'The Hokey Ass Message Board' started by Joshua O'Rourke, Sep 14, 2024.
  1. Joshua O'Rourke
    Joshua O'Rourke
    so I was tightening up my oil pump bolts and one of the heads cracked off luckily i was able to easily remove the rest of the bolt but my question now is do I replace all 4 bolts or just the broken one (which I have already done in the photo) , I only asking because I just want to do the correct thing since once the pans on its done. I'm using zinc plated bolts is that ok as well? Thanks, Joshua 20240914_123332.jpg
    Tow Truck Tom and Sharpone like this.
  2. jimmy six
    jimmy six
    Those are grade 2 … replace with grade 5 although 2 is plenty. I would use star washers. 8 psi torque for grade 2 and 13 psi using grade 5; they are 5/16” co**** ….ACE hardware.
  3. Joshua O'Rourke
    Joshua O'Rourke
    how do I tell which grade it is?
    Sharpone likes this.
  4. BJR
    BJR
  5. Joshua O'Rourke
    Joshua O'Rourke
    thank you! now my last question would be should I just replace all 4 of the bolts?
  6. gimpyshotrods
    gimpyshotrods
    Yes, replace all 4.
  7. BJR
    BJR
    And make sure none of them bottom out in a blind hole before they get tight.
  8. A tiny drop of Blue Loc***e would not hurt either.
    gimpyshotrods and Sharpone like this.
  9. Joshua O'Rourke
    Joshua O'Rourke
    thank you all for the suggestions, I went to ace and bought 4 new grade 5 screws, and then used blue loc***e on all of them.
  10. Beanscoot
    Beanscoot
    On my first car I did similar, but only replaced the bolt that I broke, overtightening.
    No problems.
    Joshua O'Rourke and Sharpone like this.
  11. Budget36
    Budget36
    Ya did it properly. If I didn’t have a bolt that would work, I’d have done all 4 as well.
    Joshua O'Rourke likes this.
