Projects Chevy 265 small block uses
Discussion in 'Traditional Hot Rods' started by 62Fleetside, Sep 13, 2024.
  1. amodel25
    amodel25
    Yeah but it's cool ( and traditional) !!!!
    Outback and Sharpone like this.
  2. Mr48chev
    A Hurst style front mount such as this one from speedway is a simple way to mount a small block V8 in an early ch***is. This one comes with the Ford biscuit motor mounts. They can often be found at swap meets for a friendly price when rodders decide they don't need them anymore because they use side mounts.
    A cast iron V8 truck (or car) bellhousing from 55-59 (car 55/57) will let you use rear mounts on the bellhousing but you do have to run a manual transmission.
    There is no free lunch on body ch***is for something to build any more though unless you just get real lucky. mid/late 30's through mid 50's pickups would be your best bet for simple and easy to work on.
    As a university student in Canada you are going to have to do some serious shopping to find a budget friendly vehicle to put the engine in. Not only has the buy in price have to fit the budget parts for the build have to be budget friendly.
    The first thing to do is sit down and draw up a plan on what you want and what you don't really want. Then what is within your skill and available resources level. Meaning what can you do that you don't have to pay for or get a buddy to do? Do you have the space to build a car or truck. Tools and equipment that you have or have access to? Your ability to bargain hunt and know what you are looking at?
    Outback, Sharpone and tractorguy like this.
  3. Made it to page 2 before a 350 was mentioned.
    we’re getting better
  4. Isn't it possible to safely bore some 55/56 265s to stock 283 bore? I remember reading people doing it
    Sharpone and 427 sleeper like this.
  5. snoc653
    snoc653
    from Iowa
    Yes. They could go 125 over.
  6. Budget36
    Budget36
    @62Fleetside , maybe mention your budget for a vehicle. @VANDENPLAS has responded in this thread, seems to be in tune with the market around you, he can say what may fit your budget.
    VANDENPLAS likes this.
  7. My bad.
    I stopped reading that post after the manifesto about how bad a choice it was and some 55-57 only bell housing nonsense :)
    I’ll do better next time
  8. Rusty O'Toole
    Rusty O'Toole
    You can have a lot of fun with a 265 in a light weight car. Years ago I saw a magazine article on an early fifties Austin A40 Devon that someone put a 265 in. But I doubt you have one of those in the back yard ha ha.
    Possibly the cheapest way to go, would be to put together a T bucket style roadster.
    Sharpone and tubman like this.
  9. 62Fleetside
    62Fleetside
    maybe i should clarify a bit more. this is a stock motor only to make something more compatible with modern road speeds and to show what would be considered closer today to a street rod. As far as the suggestion of a 350 sbc goes they grow off trees! I am researching my options to make an informed plan. Also i have no interest in mopar. and please refrain from opinionated comments that are of no ***istance i simply want to know what a 265 would bolt into that doesn’t cost 10 grand for a s**** heap
  10. It’s fits in anything you want it to fit. Probably 99.9% of the cars allowed in this forum.
    It’s an sbc those are even in aircraft
    Modern road speeds? No problem
  11. Sharpone
    Sharpone
    ^^^^^^^^ What Anthony says. The 265 is a cool motor and is no harder and probably easier to adapt to just about any 4 wheeled vehicle. A 2 bbl 265 makes 162 hp and the power pack made 180 with a 4 bbl, that’s enough hp to move a light roadster along fairly briskly. There are a few 265 build articles for the 265 on HAMB
    Dan
    Truckdoctor Andy likes this.
  12. Rusty O'Toole
    Rusty O'Toole
    Sharpone and VANDENPLAS like this.
  13. @62Fleetside the 265 won’t “ bolt in” to anything that did not come with a small block or provisions for a small block from the factory .
    if your on a budget , which you haven’t let us know , or where you are located .
    a cheap car to stick this in would be pretty much any Chevy or Canadian Pontiac from 40-60 whatever . Or a mid 40’s and later ford
    ( there are a bunch of “ barnfind” 4 doors of all kinds fords , Chevy , Pontiac ) varieties on Kijiji and facefart market place right now for decent money .
    ( obviously tri-fives , 2 door impalas , 40’s coupes) . And most other 2 doors will have a premium price tag on them . 4 doors are cool , Biscaynes can be dressed up to make sweet customs , later 40 4 door fords and mercs come with suicide doors and can be dressed up real nice and have a much lower cost of entry then their 2 door counterparts .
    in Ontario there are a bunch of 4 door cars for sale right now that could easily fit the bill for a low budget rod/custom.
    anthony myrick and Sharpone like this.
  14. Direct bolt in would be a Chevy that used front mounts. Or a ride born with a 265 or a 283 that uses the front mounts. That’s a narrow field.
    I guess “bolt in” is where the confusion comes in. We build stuff. So “bolt in” is kinda of a strange concept here.
    Guys already posted some mount options
    if ya want a manual, that’s EZ if you don’t have one of these with your 265. Truck bells for c10s 60-72 have the mid mounts on the bell
    there’s a couple different versions. One with a hydraulic clutch that mounts on the p***enger side. Saves some clutch linkage fab issues. But that’s EZ to convert one of these to hydraulic if you need to. The large center hole is important. There’s a couple different sizes and needs to match the trans you use. Saginaw and Muncie 3 speeds are not expensive and simple to rebuilt if needed. An s10 5speed would work with minor mods. Lots of info here. For an auto, side mounts for the auto bell needs fabricated.
    If you pick up a beater that used a flathead ford, that 265 is easily adapted to the ford trans.
    here’s a 283 mated to a flathead ford trans with a cheap swap meet adapter.
    Your 265 will fit anywhere a flat head used to reside. If you have the original 265 exhaust manifolds you have an advantage all ready for that
    those 265 manifolds clear the steering on lots of older ch***is.
    under 10k? I don’t know the Canadian old car market but this ugly Merc will be cruising for way under 10k including purchase price
    Here’s an example of building a “bolt in” mount. We didn’t use the front mounts because we’re mounting the trans on the tail shaft.
    here are some examples of beaters near me
    This one is perfect for that 265
    I’m just posting examples. I understand you live far north from central Bama.
    friend of mine picked up a good 31 model A 2 door sedan shell for under 3k. The ch***is for those are super simple.
    They’re out there you just have to find em
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
  16. 265 in a budget beater.
    Nothing fancy. No expensive speed parts
    Old beater body and leftover ch***is parts
  17. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    My neighbor's Hilborn injected 265 (268) powered Willys g***er from the '60s. It still exists. Ran 11s at the drags in the '60s. In D/Gas trim. Shifted at 9-grand +.
    Good choice for a replica car.
  18. 29Sleeper
    29Sleeper
    from SoCal
    I had a homebuilt 15' Crackerbox boat that was built in 1957 with a 265.
    lumpy 63, anthony myrick and Sharpone like this.
  19. Budget36
    Budget36
    After the suggestions and replies. I kinda think @62Fleetside is looking for a tri5 or 35/6 ford, that is affordable for him, and in good shape.
    That may be a tall order to ask for, or maybe he’ll let all know what he is actually after?
    Sharpone likes this.
  20. Sharpone
    Sharpone
    My dad had a similar boat, 1st a flat head then a 4 bbl 265, the 265 was given to me in the mid seventies and I sold it, dummy me.
    Dan
    IMG_1681.jpeg Sorry for the poor photo of picture
  21. 6sally6
    6sally6
    I vote for a 350 and sell the 265 to collectors......(
    Kerrynzl likes this.
  22. Beanscoot
    Beanscoot
    What the heck is that ducting(?) behind the air cleaners that goes down below the exhaust manifolds?
    Algoma56 and Sharpone like this.
  23. 427 sleeper
    427 sleeper
    That's stainless steel shielding for the plug wires to cut back on radio interference.
  24. Sharpone
    Sharpone
    Was the shielding only available on the Corvette?
    Algoma56 and chevy57dude like this.
  25. 427 sleeper
    427 sleeper
    Yes. They were used because the fibergl*** body doesn't shield like a metal body.
  26. 52lomofo
    52lomofo
    I'm ***uming University Student ?you know it takes so much effort to say the whole word these days
    Johnny Gee, CSPIDY and Budget36 like this.
  27. Johnny Gee
    Johnny Gee
    from Downey, Ca
  28. lumpy 63
    lumpy 63
    According to my dyed in the wool Mopar buddy " a small block chevy isn't even a good starter motor for a big block Mopar" not my words , his. He's a member here BTW:p
  29. GlassThamesDoug
    GlassThamesDoug
    I know where a nice 30 Chevy is, fit right in. Hot rod material. Has sbc in it currently.
  30. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Years ago, someone came to me asking if I knew where there was a '55 265 for the Nomad he was restoring, and I told him what junkyard had one. He told me that he'd already been there and that there were no 265s in that yard. I said, "You didn't open the right hood. It's in a '49 Jeep pickup".
    Outback, 427 sleeper, RICH B and 4 others like this.
