Projects Belly Tank Build, NZ.
Discussion in 'The Hokey Ass Message Board' started by 26 T Ford RPU, May 3, 2021.
  1. Harv
    Harv
    from Sydney
    Apologies for not commenting. Normally keep an eye out for your thread, but it must have scrolled through and I missed it.
    Must not have been an easy call to cur the holes in the upper body section. Can always gl*** them back up, but still a big "now we are committed" call.
    The photo down the body with the top on is cool. At first thought it looks like there is heaps or room around the engine. Then you imagine everything hot and angry and fuelly and sparky, and that room doesn't feel so big anymore.
    Cheers,
    Harv
    Stogy and 26 T Ford RPU like this.
  2. Cheers, Harv, there is more room in the back than there is for me up front. The reason for all the cut outs in the top is so i can gl*** the fairing on to the body from both sides to make it more ridged for taking it on and off. More to show soon. JW
    Stogy and brEad like this.
  3. A small update of sorts, i tried my hand at gl***ing a brace in the upper rear body section and that turned to **** so i may go out to the shop tonight and have another go as i feel more confidant and maybe i will have learned from what didn't work before.....fingers crossed. JW
    Dean Lowe, brEad, saltflats and 4 others like this.
  4. Tim_with_a_T
    Tim_with_a_T
    I’ve been doing the same- first try was pretty bad. Don’t give up!
    brEad, saltflats and 26 T Ford RPU like this.
  5. No giving up here, will be back at it tonight with an adjusted plan.....it will not beat me!:D JW
  6. Made a good attempt on the gl***ing of the braces today. I cut the mat wider, got some smaller brushes and a roller, it turned out how i expected it too....moving forward again. JW
    Stogy, The37Kid, The 39 guy and 6 others like this.
  7. Harv
    Harv
    from Sydney
    Neat job.
    I've got moulds at home to make FB/EK Holden doors, bonnet and bootlid. I'd really love to learn how to 'gl*** and have a go at it... just need to find some time.
    Cheers,
    Harv
    26 T Ford RPU likes this.
  8. I go by, ''If it was easy everyone would be doing it''. I believe a good tutor would be great but it's kinda fun working it out and doing an ''OK'' job of it. JW
  9. coreythompsonhm
    coreythompsonhm
    Great build so far! After reading through your build a couple of times, as well as others builds and the rule books, I think it’s time I have a go at building one myself.
    AndersF and 26 T Ford RPU like this.
  10. Thanks for stopping by and building your own sounds like a good plan. What body will you use? The Cl***gl*** fibergl*** ones are the biggest you can get, mine was molded off one of there plus 20 inch bodies but they also have stock length. These were copied from the Famous Scotty's Mufflers Tank. JW
    Stogy, coreythompsonhm and AndersF like this.
  11. coreythompsonhm
    coreythompsonhm
    I will probably buy one from Cl***gl***. I have a spare Flathead block in my stash, a banjo rear, and a seat. I need to mock it up to see if I need the 20” longer version. Otherwise, I would probably fabricate my own from aluminum to fit. However, I do like the idea of not needing to build a body from scratch.
    Stogy, AndersF and 26 T Ford RPU like this.
  12. Tried a small fibergl*** job i needed to do tonight and thought about how i was going to tackle it and i ended up being rather disappointed so i have put the f-gl***ing stuff away and will now pull it apart finish a few jobs on the frame and lower firewall and paint the frame and all the parts, then put it back together for ''Chrome and Custom Show'', if i have any time left i may try some f-gl***ing. I have to have it on the trailer by Friday night (Oct 4th), drive 2 1/2 hour on the 5th for show setup for the show on the 6th. Stay tuned.:D JW
    Stogy, saltflats, AndersF and 3 others like this.
  13. Took it off the stands in preparation to pull it apart, finish any small welding jobs, finish the lower section of the firewall and seal flange. Then clean all the frame, paint it and lots of parts and brackets the put it back together in time for Oct 4th. JW
    Stogy, 41 GMC K-18, Dean Lowe and 8 others like this.
  14. About half the parts. JW
    Stogy, 41 GMC K-18, Dean Lowe and 7 others like this.
  15. Took everything off the ch***is except lower body, axles and gas tank. Will be in the shop every night this (and next) week getting the ch***is prep'd for paint and painting. JW
    Stogy, brEad, 41 GMC K-18 and 6 others like this.
  16. The parts jigsaw got a lot bigger too. JW[​IMG]
    Stogy, brEad, Rehpotsirhcj and 8 others like this.
  17. saltflats
    saltflats
    from Missouri
    That looks like quite the mess you have going there.
  18. I know where it all goes..... I think. I have started painting brackets today. More soon! JW
    Stogy, brEad, 41 GMC K-18 and 3 others like this.
  19. AndersF
    AndersF
    There are no lazy days ahead for you, thats for sure.
  20. I have had too many, running out of time but i want it done so this is giving me a good push. JW
  21. Kiwi 4d
    Kiwi 4d
    Part 56 attaches to part 78 . Of course you know where they go you made them all.
  22. Thanks Bryan, i did take lots of photos of the hydraulic lines but that's about it and being an ex mechanic from many years ago helps a bit.:rolleyes::D JW
    Stogy and loudbang like this.
  23. saltflats
    saltflats
    from Missouri
    I find out being a mechanic I never have time for my own stuff.
  24. That's very true but since i'm an EX mechanic i only work on my stuff... problem solved.:cool:;):D JW
  25. The frame is now down to the rear axle and gas tank with most of the brackets painted, have tacked in the four pieced on the firewall. The axle and gas tank come off tomorrow and the weekend will be going over the frame, cleaning it then start painting it. JW
    Stogy, Dean Lowe, brEad and 4 others like this.
  26. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I am at a similar stage on my champ car build - dis***embly for final weld and ch***is paint. As the parts I removed piled up I was thankful for doing a detalied build thread on the HAMB so I can now go back and follow my build to help me remember where everything goes.
    Stogy, brEad, AndersF and 2 others like this.
  27. I,m at a good point there as it will be back together in two week from today and the longer it's apart the harder it is. Good luck. JW
    Stogy, brEad and saltflats like this.
  28. Got the frame down to nothing more can come off stage and got out my make shift rotisserie and went over it all. JW
    Stogy, Dean Lowe, brEad and 5 others like this.
  29. A different angle. Gave it a good clean and made a move on starting the paint process. JW
  30. The primer is being brushed on as i don't have a spray system and i don't wont everything else getting painted as well, there will be brush marks but that's the vintage look:rolleyes:. The top coat is to be machinery grey via rattle cans. JW
