Street Rod, Model A, Chevy & Dodge Parts
Discussion in 'Parts For Sale' started by FatFndr, Sep 8, 2024.
  1. FatFndr
    FatFndr
    City: The Villages
    State: Florida
    Price: $650
    Cleaning the attic, selling the last of my parts. Bulk price on all of it, will not separate. You pick up, cash preferred, you pay any shipping costs. Additional picture available upon request.
    Street Rod Parts:
    Pair of Rams Head exhaust manifolds believe to be from a Corvette around 1965, $200 for the pair:
    GM #3846559 Drivers Side
    GM #3832461 P***enger Side
    Cal Custom Valve Covers - SBC
    2 Sets Mr. Roadster Peep Mirrors – new - #925-50745
    AudioVox AM to FM Converter
    1960’s Mustang pedal ***embly
    Sun Super Tach
    Throttle Rod 1960’s Chevrolet
    Audiovox AM to FM Converter
    Steering Column Bracket
    350 Transmission kick down cable
    Fuel Filter TD Performance with 4 extra filters
    Vacuum Brake Switch
    Mechanical Fuel Pressure switch
    G FLEX Radiator Hose
    ‘39-’40 Ford Door Hinge Mirrors
    Rear View Mirrors External
    Stewart/Warner Batt/Gen Gauge
    Fuel Pressure Regulator w/***orted hose & Clamps
    Pro Fuel Carb Pressure Regulator with fittings
    Bulbs 2057 & 1157NA
    Murphy Switch Gauge
    Oil Pressure Gauge – electrical
    Ignition Resistor (new) SBC
    2 Each Amp Gauges -60-+60
    Model A, Chevy &Dodge Car Parts
    Model A Auto Lite Heater
    Model A Jack with handle
    Jack from a 1937 Dodge
    Temp Gauge 1937 Dodge
    Hood Props 1937 Dodge
    Ford Script Tools 1930’s
    Lower Radiator Water Pipe
    Model A Tools
    Flathead Bell Housing
    Flathead Generator to Alternator Converter Bracket
    Heater Cover – Model A
    Under hood Troubleshooting Lamp
    Floor Plates – Model A
    4 Blade Radiator Fan with hub
    4 Each Vacuum Wipers
    2 Each Generator Cut Outs
    12 Volt to 6 Volt Stepdown Pot
    Stromberg Carburetor Jet Wrench
    Lower Steering Arm to hold Wire Harness
    Windshield Brackets
    Windshield Wipers
    Starter Bendix
    Fuel Bowl for Flathead Fuel Pump
    6 Volt Fan
    ’36 Ford Fuel Line
    ’32-’41 Ford Distributor Gasket Set
    Fuel Pump Gasket for Flathead
    ’35-’36 Ford Brake Pedal Return Spring
    ’28-’40 Ford Radius Ball Cap Bushing
    Front Radius Rod Spacer
    Window Cranks
    Door Escutions
    50’s Ford Hood Emblem
    ’37 Chevy Truck Temp Gauge
    ’37 Chev Truck Dash Switches
    ’38 Chevy Truck Tail Light
    ’37 Dodge Dome Lamp Gl***
    ’37 Dodge Turn Signal Lamps (rare)
    ’37 Dodge Hood Ornaments
  2. FatFndr
    FatFndr
