Hot Rods BChrismer's Survivor '40 Ford Convertible
Discussion in 'The Hokey Ass Message Board' started by bchrismer, Aug 9, 2024.
  1. bchrismer
    bchrismer
    Yup. Bought those and his 38-41 distributor with a 12v pertronix conversion.
  2. MO_JUNK
    MO_JUNK
    from Rolla, Mo.
    Anxious to see it Bret. Should you decide to go with the snap-in style hub caps(40-41 truck style) I have a couple 15” mid- fifties stock F-100 steel wheels I could donate. I also have a set of 16x4”.
    Okie Pete, VF-1 and bchrismer like this.
  3. VF-1
    VF-1
    She’s the BOMB, Bret! Dibs when you get tired of the old gal.
    Okie Pete and bchrismer like this.
  4. ronzmtrwrx
    ronzmtrwrx
    Nice, man.
    bchrismer likes this.
  5. atch
    atch
    I'm happy for you Brett.
    I love the Oklahoma folks but they can have the gravyfied french fries at Murphy's.
  6. bchrismer
    bchrismer
    Thanks. I don't know how I missed your '39 'vert build thread. It's definitely bookmarked.
    ronzmtrwrx likes this.
  7. VF-1
    VF-1
    Where you parking all these ‘40s, Brother? If your getting a little top heavy, I’m sure I can help ya out… :rolleyes:
  8. MMM1693
    MMM1693
    I'm sure you will enjoy your convert as much as I am mine. Stock 40 converts rock!
    Okie Pete, guthriesmith and bchrismer like this.
  9. bchrismer
    bchrismer
    This is the old '40 MO plate that I ran on the back of the panel truck. Because it had a lot of weathering, I had decided to drop it in a pan of vinegar to help kill the rust stained paint. Well...the vinegar decided to just eat all the paint off the plate.
    Because I am cheap and didn't feel like buying a spray bomb of Wimbledon White, I found the can of Rustoleum Canvas White and applied a coat to the back, to see how it was going to work. Looks like two coats will handle it, then break out the black 1Shot for the letters and border.
    I am somewhat kicking myself for not registering the plate for the panel, back in 2020, when I had gotten the confirmation the number was available. I'm hoping it comes back clean again, so I can send in the appropriate paperwork once my ***le comes back.
    winduptoy, drdave, RodStRace and 6 others like this.
  10. bchrismer
    bchrismer
    Thanks, Ed! I'm planning on driving it up for the StL Hot Rod Hundred Sept 14. It got one of the OLD Roarin' 30's stickers in the windshield and one of the over sanded tag toppers on the back now. If I ever sell it, it has a LONG line of local guys who've called dibs you'll have to fight.
    Uh, yeah...about that. My wife is not real happy right now, as the convertible kicked her car out of the garage. I'm currently working through the list of widowed church ladies to see if any of them happen to have some garage space I can rent to rotate '40s into.
    winduptoy, Outback, VF-1 and 4 others like this.
  11. 19Fordy
    19Fordy
    Keep in mind that with a "raked" stance the gear oil, from your differential will drain out and run down the interior of you torque tube and eventually dissolve the rubber encasing the torque tube center bearing. There is a replacement bearing available from Skip Haney on Fordbarn. Plus, I recall seeing a thread where a fellow in FL actually recast the rubber around the OEM bearing so it can be reused. OEM Ford center bearings are no longer available and are very expensive and rare. You can tell the bearings "bad" when you feel and hear the solid driveshaft vibrate as it whips inside the torque tube.
    winduptoy, lazydog40, VF-1 and 3 others like this.
  12. Dan Hay
    Dan Hay
    @hotrodpro Danny Burroughs at Bruce’s Hot Rods makes a torque tube seal to keep the gear oil in the diff. I used on of those on mine and then greased the center bearing at the zert and hoped for the best. I think it’s still going strong as far as I know.
    winduptoy, Okie Pete and Tim like this.
  13. 19Fordy
    19Fordy
    lazydog40, VF-1, Okie Pete and 2 others like this.
  14. bchrismer
    bchrismer
    Road tripping in a '40 convertible with 6v electrical is going to be a new experience. When I got the stake truck on the road, I rewired it all 12v with a Chevy internally regulated alternator, just to make "power" related failures a fairly easy roadside fix. I haven't thought through that process yet, with the convertible, but one of my other concerns is that I have an older cell phone that doesn't hold charge very well, and I will need to somehow be able to charge it.
    I also remember that when I rewired the stake truck, my Uncle Bob had an AM radio out of a late model hung under the dash and used a 6v to 12v power inverter to power it. I searched high and low in the garage trying to find it, since my pack rat nature tends to never throw stuff away. Unfortunately, I had no success finding it, so I resorted to Amazon, where I bought one of these.
    https://www.amazon.com/DROK-Converter-Waterproof-Stabilizer-Automotive/dp/B0BQJ4G77B
    as well as one of these:
    https://www.amazon.com/dp/B0B1V92QBR?th=1
    And since I was blowing money like a sailor on leave, I went ahead and grabbed one of these for future use.
    https://www.amazon.com/dp/B08R3Y5WXH?th=1
    Just trying to figure out where I can hide that power inverter and fuse box, but as long as I run my power and grounds from the 12v items to the fuse box/bus bar combo, I should be able to wire up an accessory outlet to plug a USB cord into to charge the phone. The bluetooth amp will be saved for a later date when I can figure out how to mount a 5x7 dual channel speaker behind the speaker grille, so it remains out of sight.
  15. RodStRace
    RodStRace
    Outback and VF-1 like this.
  16. Zax
    Zax
    I have that same mini fuse panel in my '40. So far I am happy with it
    VF-1, guthriesmith and bchrismer like this.
  17. bchrismer
    bchrismer
  18. RodStRace
    RodStRace
    Nice work! We have all seen the various details of the exterior picked out. What stood out to me in his selection are the interior shots. That resonated with me as what the driver interacts with when going down the road.
    Outback and bchrismer like this.
  19. guthriesmith
    guthriesmith
    That’s too cool Bret!
    winduptoy and bchrismer like this.
  20. bangngears
    bangngears
    from ofallon mo
    Exhaust hangar is cool .
  21. bchrismer
    bchrismer
    Jerry, this is why I didn't buy your convertible. I've been eyeballing this one since 2020. When it came up for sale last fall, I didn't have the funds, so Jim Pike wound up buying it. I told him to give me 6 months, but he made me wait 11.
    Outback likes this.
  22. bchrismer
    bchrismer
    Drove the convertible out to Mike Meeker's shop last night to finish up the clutch/transmission shop in my coupe. Once we got the coupe ****oned up, I pulled the convertible up onto the lift so we could adjust toe-in.
    On the 35 mile drive out to Mike's, I got p***ed by a guy snapping a photo. I was very surprised to find the photo posted on my FB page when I got home.
    Earlier in the week, I bought some 6v LED 53 style light bulbs on Amazon to use in my gauge panel. I didn't realize I was going to get to test them out on the ride home.
  23. Outback
    Outback
    from NE Vic, Oz
    What a cool 'vert a great collection of photos too
  24. MERCURYGUY
    MERCURYGUY
  25. bchrismer
    bchrismer
    Headed out to the St Louis Hot Rod Hundred, keeping a close eye on the oil pressure gauge. Had some sprinkles from the remnants of Hurricane Francine, but things seemed to be going great.
    Then I lost all oil pressure but at least made it to Redmon's Candy Factory, 50ish miles from home. I finally put the top up for the very first time.
    Got a ride on a rollback over to Mike Meeker's shop, threw all my **** into the coupe, and got back on the road.
    It's not a trip to St Louis unless you make a stop to inspect Ur****.
    Got to Washington, MO and had to make a stop for dinner. If you've byp***ed Lion's Choice on your way through the StL area, you're missing out on some great roast beef sandwiches.
    Side note:
    Apparently this little frog decided to run away from home and he stowed away in the coupe. I felt something cold drop on my toe, only to look down to see him. He wandered through the car until we got to Washington, where I let him go in the gr*** by Lion's Choice. He thanked me by ******* all over my hand. What a jerk!
    woodz, Baumi, Okie Pete and 7 others like this.
  26. bchrismer
    bchrismer
    After a few calls with known flathead guys who build engines, I was encouraged to have them tell me if it's not knocking, I can more than likely pull the pan off of it, s****e all the **** out of the oil pan, clean up the oil pump screen, and probably squeeze some additional miles out of it before requiring a rebuild. That process will commence Friday evening, so hopefully I'll be back in bid'ness before the Midwest Forty Ford Gathering and for the Gathering at the Roc.
  27. The 39 guy
    The 39 guy
    Sorry to hear of your loss of oil pressure. I hope cleaning the screen solves your problem. Flatheads still providing us fun and adventures for 90 years!
    i.rant and Kelly Burns like this.
  28. bchrismer
    bchrismer
    Well, things seem to be taking a different direction, and that's a good thing. While the current flatty will be coming out, the oil pan/pickup screen cleaning will be postponed for a later date, but their is a high probability that the convertible will be back on the road next week sometime.
  29. The 39 guy
    The 39 guy
    Motor swapping! How Fun is That?! you must have a spare available?
  30. bchrismer
    bchrismer
    I haven't seen it yet, but I will be picking up a '46 59a that was rebuilt by Jerry Livingston, over near Wichita. It was intended to go into a '36 sedan but never did, so it should still be clean as a whistle on the inside. It just requires a stack of cash and about a 600 mile round trip to pick it up.
