Projects what caused these holes?
Discussion in 'The Hokey Ass Message Board' started by turbo84gn, Sep 17, 2024.
  1. Budget36
    Budget36
    IMG_1001.png IMG_1002.png IMG_1002.png Let’s look at Google and spread patterns. For both buckshot and (most likely) a standard shell.
    Squablow likes this.
  2. ALLDONE
    ALLDONE
    as a professional painter and auto refinisher... those hole will grip the bondo to where it will never be a problem, kinda like how rivets work... ive seen cars loaded with bondo that get hit... hunks fall off.... except where the slide hammer holes are....
    do you ever want to get the truck done.... or is it just a hunk of metal that you are gonna self teach yourself how to do all the differant trades?? some youtube videos re better than going to school... if you don't get it you can watch again and again till you do..
  3. fuzzface
    fuzzface
    Buckshot? I would rather hear the story about the wild wife the farmer had that wore stiletto heels. I think that would make a better fascinating story.
  4. Mr48chev
    My experience says that rust will develop around the holes behind the bondo and continue to rust. Yes the quick and nasty rebuild shops left the holes from the slide hammer dent puller saying that they gave the bondo more adhesion and I heard that bull **** times over back in the70's.
    HSF, Hutkikz, X-cpe and 1 other person like this.
  5. 05snopro440
    05snopro440
    Funny you mention 65 Mustangs, because Mustang forums seem to agree that lead was used, not Bondo/plastic filler. Filling seams with lead was common for cars in that era.
    Comparing a rivet gripping a hole to plastic filler gripping a hole just shows that you have no idea what you're saying, sorry.
    427 sleeper and HSF like this.
  6. ALLDONE
    ALLDONE
    I could see that happening, when I lived on the coast, my tools would rust over night if I left them in back of the truck... for me... i'd probley spot weld the holes and skim it with mud, **** brick it and finish block it.. and prime it...
  7. ALLDONE
    ALLDONE
    probley did a 100 of them... had to get to the brazing rod... lol sorry your life is so miserable....and yes... you are sorry...
  8. alchemy
    alchemy
    Usually the problem with bondo filling holes is not the adhesion. It’s that the bondo is basically a talc sponge and will allow moisture to soak through it and rust the nice freshly ground steel you slathered it onto. Works fine if you paint all sides. Not so much if you only paint one side.
    I’m not seeing how the OP is gonna get a good coat of paint on the back side of this panel.
  9. ALLDONE
    ALLDONE
    same as here, mustang forums don't agree on any thing....lol
    this is copy paste from the mustang forum...
    Nope, Factory Bondo is not a myth. It happened and it still happens. I have one friend who did a professional restoration of an original owner car and found bondo under the factory paint. My friend, Chuck, also was visiting a factory of the dark side (GM) and saw them slap a bunch of bondo on a car going down the line a few years ago. They had a big bucket of the stuff and weren't very neat with its application. ::
  10. ALLDONE
    ALLDONE
    make sense to me.... I was kinda thinking it was like the lid on a jar type deal.... I personaly don't use a slide hammer.... nor would I leave the holes.... another thing... i'm in vegas...you can leave raw metal outside for months and it don't rust....
  11. ALLDONE
    ALLDONE
    just to be clear here.... duragl*** is water proof... I had to go make sure cause i'm old and forget stuff... and duragl*** will grip the holes like a rivet..
    Duraglas Fibergl*** Reinforced Auto Body Filler | Rust & Waterproof Single Short-Strand Fibergl*** Body Filler, Base Color of Dark Green | 1 Gallon
  12. swade41
    swade41
    from Buffalo,NY
    I'd paint yellow triangles around some of the holes and say the truck was a company truck for the Swiss Cheese company, maybe dress up in a mouse costume.
    427 sleeper likes this.
  13. 05snopro440
    05snopro440
    That's funny, I read that same thread. You picked the one post that agreed with your opinion. That's the definition of confirmation bias. Consensus on several forums was that bondo was not used on Mustangs in 1965.
    427 sleeper, NoSurf and gimpyshotrods like this.
  14. 05snopro440
    05snopro440
    Lol.
  15. rusty1
    rusty1
    I'd just leave them alone.
    anthony myrick likes this.
  16. Bandit Billy
    Bandit Billy
    I imagine that panel is spotwelded in? If so, I would cut the spots, remove the panel, weld it up proper (and "in position", not over your head) and then weld it back in.
    Or, remove the pointy bits, add dyno mat for sound and temperature control and have the upholsterer do a nice headliner with bows. No one need ever know, other than the HAMB. Hell, at our age WE won't even remember in a year.
    warhorseracing and Budget36 like this.
  17. ALLDONE
    ALLDONE
    so you are say'n I should believe what you read over what I seen with my own eyes????? there's probley a long word for that.....LOL
  18. ALLDONE
    ALLDONE
    I won't remember by morning, but im not a gob.... yet
  19. 57 Fargo
    57 Fargo
    I too would drill spot welds or even cut the panel or to fix the holes but I also don’t charge me.
  20. Rusty O'Toole
    Rusty O'Toole
    You worry too much over **** all. If you put a headliner in the truck no one will ever see them, and they are not structural, that is, they don't weaken the body.
    If you are not going to put in a headliner you can smooth them over with body filler and sand smooth, being inside out of the weather, the filler will last longer than you will.
  21. Uh.... the rust around the pinchweld would concern me a lot more that the holes. 20240917_200141.jpg
  22. ALLDONE
    ALLDONE
    thank you.....
  23. 57 Fargo
    57 Fargo
    Depending on climate, mine don’t have a climate controlled environment, things continue to rust even inside a building.
    deathrowdave and 05snopro440 like this.
  24. ALLDONE
    ALLDONE
    may be have to z bart the whole truck
  25. I’d drill out the spot welds holding the inner panel in place.
    Hammer and dolly the holes shut. Then weld.
    Fabricate a new piece to fix that rotted area
    Reinstall the inner panel.
    have a c10 I will have to do similar
  26. I have a C10 in my shop that had rust on the inside of the roof... so I cut the top off and flipped it upside down on the horses to fix it :D
  27. ALLDONE
    ALLDONE
    this is how extreme this thread is....making a big deal out of a few hole inside the cab of an old truck, and those that say they would tear the truck apart to fix them... all the while they are good with the thousands of holes every else drilled screwed and penetrating all the other panels and frame.... so one has to step back and say... you mean to tell me in order to put speakers in my truck I need to cut all the spot welds in the kick panel and package tray... mount the speaker.... through bolt it . weld the back side of the screw.. seal it then put the panel back????? really..???? even at the factory they screwd the dome light in... screwed the dash ,kick panels, door panels, window moldings.. absolutly nothing more is going to happen to those holes that are 50 years old any more than what has happened... what do you think happens to all the exterior trim screws???
  28. ALLDONE
    ALLDONE
    2 of my horses rusted... and my tractors IMG_1760[8559].jpg IMG_1762[8561].jpg IMG_1766[8562].jpg IMG_1767[8563].jpg
  29. Specking out doing a big back window swap in a c10. Got a big window parts truck. Can swap over the inner and cut out the gl*** opening or swap the entire top and rear of the cab
    Who knows what we will do
  30. ALLDONE
    ALLDONE
    LOL, I have 2 sxs turbos that I will have to take out and ride around while you do that
