Hot Rods Self Adjusting Lincoln Drum Brakes
Discussion in 'The Hokey Ass Message Board' started by krylon32, Sep 17, 2024.
  1. krylon32
    krylon32
    from Nebraska
    Sold lots of Lincoln drum brakes over the last few years and used quite a few sets. Seems like on a long trip you need to adjust them after a 1000 miles or so. I asked Boling Bros but can't remember what they said? Anyone on here develop a way to add self adjusting hardware to these drum brakes?
    Tow Truck Tom likes this.
  2. squirrel
    Get all the self adjusting parts for a 1969 Buick LeSabre, and install them?
    ( I looked up the Boling Bros. kit, picture shows the number 340 on a shoe, looked up 340 Shoe, application is 60s Buicks)
    Tow Truck Tom, brigrat and Malcolm like this.
  3. krylon32
    krylon32
    from Nebraska
    Your idea is sound but finding all the parts in usable condition from a 55 year old car might be a challenge?
  4. dirt car
    dirt car
    from nebraska
    Equally as challenging, but I believe Cadilliac may be the same, I used trimmed Buick backing plates on the rear of my avatar but without the self-adjusters.
    31 B'ville likes this.
  5. squirrel
    yeah, it might not be easy to find used parts, but it is a way to get where you want to go.
    Cadillac used 12" brakes on the later cars with self adjusters, but they're wider, and have a different hole layout on the shoe web
  6. JohnLewis
    JohnLewis
    If Dorman still makes them and you can find them. They had a line of completion kits, they usually came with the adjusters, extra pieces and levers you don't usually get in a regular brake kit.
    Tow Truck Tom, Tim and silent rick like this.
  7. Hitchhiker
    Hitchhiker
    You should be able to buy ALL the Bendix self adjusting hardware through multiple manufacturing sources.
    Let me do some digging
    Tim, Tow Truck Tom and 302GMC like this.
  8. squirrel
    I looked in some older Bendix and Wagner catalogs, they didn't have self adjusting hardware available for them back then.
  9. Rice n Beans Garage
    Rice n Beans Garage
    57 Lincoln hardware, still available.
    jet996 and squirrel like this.
  10. squirrel
    Where? and does it fit Buick shoes?
  11. Rusty O'Toole
    Rusty O'Toole
    You need to contour the shoes to fit the drums. Old time brake shops had a brake lathe to do this. You may have to do it by hand.
    Put the brakes together and adjust, you will probably have to adjust again after a week or 2, but once they are bedded in should hold their adjustment for 10,000 to 20,000 miles, maybe more depending on traffic conditions and how hard you use them.
  12. squirrel
    having got only 20k miles out of set of brake shoes, I think that might be optimistic? But a few thousand miles once they're "worn in" sound reasonable.
  13. Weedburner 40
    Weedburner 40
    I just sourced practically all the hardware for a set of original Lincoln braked through Raybestos. You have to do some searching in the older catalogs for the various parts but they are available. I started with Ford pickup parts from the 60's.
  14. Any chance you could give us the part numbers of the parts you used.
  15. gimpyshotrods
    gimpyshotrods
    I found everything online but spreader bars.
    Someone has to have those, somewhere.
  16. gimpyshotrods
    gimpyshotrods
  17. Rusty O'Toole
    Rusty O'Toole
    Your mileage may vary. But 20,000 miles on a set of brake shoes, suggests you do a lot of driving in city traffic. In that case you may need to adjust brakes every 5000 miles or so.
    firstinsteele likes this.
  18. birdman1
    birdman1
    Get the self adjusting hardware for the 1958 Mercury
  19. manyolcars
    manyolcars
  20. RICH B
    RICH B
    These are the parts I've used for adding self-adjusting stuff to 12" Ford Bendix brakes.
    There being a difference in anchor pin center to axle center between GM Bendix and Ford Bendix, but since 12" GM self-adjuster parts are a little hard to locate, I really don't see why the Ford/Dodge/IHC/Jeep style parts wouldn't work.
    The cable guide on the right side of the shoe is sitting in the wrong place in the picture should fit three holes up where the retract spring goes.
    The purple spring in the picture is included in H-7139 kit I use for the retract springs & hold stuff.
    self adjuster parts 12 inch Bendix.jpeg 8163d0b476679df45c5b8b88da968fb7.jpg
  21. Mr48chev
    I did some searching and can't find the correct 69 Buick adjuster arms/levers. Those kits that rich B showed works, is simple and years of doing brakes say that parts are pretty easy to find. 12.50 for each side from Amazon for the kits. I can't remember if odd or even means left or right but you need one of each. You might be able to get them locally though.
  22. bobss396
    bobss396
    Try Inline Tube. They seem to have a good offering of odd brake parts.
  23. silent rick
    silent rick
    back to the top for part numbers and application that work
  24. silent rick
    silent rick
    even number is driver side, part numbers say both fit 12 inch x 2 inch front brake.
    do you think they will work on the rears too?
    i have lincoln style brakes on all four corners.
