Technical Chevy Truck Front Axle Widths??????
Discussion in 'The Hokey Ass Message Board' started by brigrat, Sep 16, 2024.
  1. brigrat
    brigrat
    from Wa.St.
    Having a hard time getting used to a '57 Chevy truck axle under a '57 Chevy 2dr. g***er, seems a little wide looking to me even if I had 3"-4" wide front wheels which I don't. Thinking of using a '49-'55 first series but don't know the width difference between the two. What is the width diff. between the 1st. series and the '57 front truck axle? Thanks!
  2. squirrel
    3.5" according the Chevy do***ented front tread width being 57 then 60.5" when they made the change. The spindles and hubs and wheels stayed the same, as far as I know
    spring spacing will also change. And the springs were angled on the earlier trucks, I think?
    427 sleeper and brigrat like this.
  3. brigrat
    brigrat
    from Wa.St.
    Yes, they were angled, hoping to "fudge" that a little. An 1 3/4" diff on each side doesn't sound like much but maybe to my eye it will. Than you gotta add disc brake's putting it outboard a bit more. Thanks for the info!
  4. squirrel
    you could use drum brakes, or different disc brakes that don't move it out more
    427 sleeper likes this.
  5. Mr48chev
    Front tread of a 48 Chev or 48/55.1 pickup is 56-9/16 with 16 inch wheels and 57-11/16 with 15 inch wheels. Spring bolt centers are 26-13/16.
    On a 56 3100 stock tread width 60.52 and spring bolt center to center is 30.88
    57 Chevy car front tread width is 58 inches
    All Screenshot (1028).png Screenshot (1027).png Screenshot (1026).png of those per the GM heritage center vehicle information kit pfds. https://www.gm.com/heritage/archive/vehicle-information-kits
    brigrat likes this.
  6. brigrat
    brigrat
    from Wa.St.
    Jim, Thought of that but being a shop rat I lost track of who makes disc that don't move it out. Scarebird? Scarbird? We used to adapt Volvo disc to alot "things"................................
  7. brigrat
    brigrat
    from Wa.St.
    Thank you 48, I will print that out!
  8. squirrel
    I had the move-out discs on my 55 when I built it (almost 30 years ago), and then later got wilwoods, which put it back to stock width. Lighter, look kind of modern, and $$$$ if you can't find a set of used ones
    brigrat likes this.
  9. Mr48chev
    WMS to WMS on the AD truck axle I have out here is 58-1/4.
    brigrat likes this.
  10. brigrat
    brigrat
    from Wa.St.
    Just called Wilwood. they still make a kit Wilwood Disc Brakes - Front Brake Kit Description
    that only moves it out a 1/4" each side, but like you said, modern looking & a grand + to buy!
  11. 57tailgater
    57tailgater
    from Georgia
    I believe too the front springs are angled on AD's.
    brigrat likes this.
  12. brigrat
    brigrat
    from Wa.St.
    ^^^^^^^^ Some say it's not enough to worry about but you need to be aware of it^^^^^^
  13. Mr48chev
    On AD trucks a ball park measurement for spring centers front and rear are 24 front and 28 rear. 26-13/16 on the axle line puts those springs way in from the 57 car frame rails if memory would serve right.
    Springs are 38 inches center of eye to center of eye and 1-3/4 wide. My thought is that it isn't going to fit a 57 frame well at all. It probably wouldn't be a h***le to run the springs straight front to rear but spring centers at 26-13/16 at the rear is going to be inside the 57 frame rails a bit.
    Either way it is a lot of trouble to make a poser car that doesn't ride, drive or handle worth a damn.
    swade41 likes this.
  14. brigrat
    brigrat
    from Wa.St.
    I don't remember saying I was building a "poser" car, just gathering all info before I dive in a direction that fits what I will be doing with the '57.
    427 sleeper and Budget36 like this.
  15. TRAVLR
    TRAVLR
    Just curious... What is a poser car?
    Budget36 likes this.
  16. brigrat
    brigrat
    from Wa.St.
    To me it's a "wanna be" car guy that has a lot of money and can afford to buy whatever he wants without laying a hand on a tool!
  17. squirrel
    To me it's a car that looks like it should be fast, but isn't
    427 sleeper, X-cpe and swade41 like this.
  18. TRAVLR
    TRAVLR
    I agree on both. The term poser to me always referred to being a fraud or fake. Was just wondering why your 57 straight axle g***er build brigrat, would be considered a poser car by someone? Does that mean a 32 Ford with Ardun heads and a blower is a poser car, since it wasn't built from the factory that way?
    Straight axle cars and trucks ride and handle pretty darn well to 99% of the people I know. It won't handle like a new Lexus... But if that is the ride quality your looking for, buy a Lexus.
    427 sleeper, brigrat and Budget36 like this.
  19. swade41
    swade41
    from Buffalo,NY
    I believe the "poser" part is building a g***er drag car looking car that will never actually go down a dragstrip
  20. Budget36
    Budget36
    Every straight axle “g***er” look car doesn’t have to have 600HP to impress.
    It just has to make the owner happy.
  21. brigrat
    brigrat
    from Wa.St.
    "57 Chevy, 150, Utility, BBC 396 671 blower, ETlll rear wheels, looking for appropriate skinny fronts. '57 seamless frame, '57 truck axle, 9" Ford rear. Muncey 4 speed, Hurst linkage, Ansen Tri5 ****ter Shield. Hoping to pull the front off the ground, no Moon gas tank in front of grill! Tilt front Sheetmetal. Taking the BBC blown 396 out of my Sanger V-Drive. Saved parts for a long time for this!
  22. TRAVLR
    TRAVLR
    He can't take it down the dragstrip... If he hasn't built it yet.
    That would be like calling his kid a flunky, if it hasn't been born yet.
  23. Budget36
    Budget36
    I may have under estimated the HP;)
  24. TRAVLR
    TRAVLR
    I did the same thing. Took me 12 years to build mine. Collecting parts, planning the build, and priorities in life were the reason it took so long. Plus, I keep what I build... So I make it right the first time.
  25. brigrat
    brigrat
    from Wa.St.
    I have the makings of a couple 301-302's SBC, but think the last build should be "go big", I know 396 isn't big buts it's a start, anything after that should be a BBC bolt in if needed.
    427 sleeper, swade41 and TRAVLR like this.
  26. brigrat
    brigrat
    from Wa.St.
    I need me some kidney Bean's![​IMG]
  27. TRAVLR
    TRAVLR
    I was going to use my spare 396 block for my build... Found a 4 bolt 427 block before I was ready to build my engine. Again... I took my time. Glad to see you are building your dream car.
  28. brigrat
    brigrat
    from Wa.St.
    Times is not on my side BUT everything else is!
    Here's a 4 bolt 427 long block BUT maybe for later.....................
    427 sleeper and TRAVLR like this.
  29. TRAVLR
    TRAVLR
    In reference to your original question... Have you considered a tube axle kit? I went with a 4 inch drop tube so I could set my own caster and space the leaf springs where I didn't have to butcher the frame, and not have to use a periscope to see over the hood scoop.
    If you are dead set on the beam axle look, I totally understand. Just spitballing an idea for your track width issue.
  30. TRAVLR
    TRAVLR
    That intake is wicked looking! Me like very much!
