Technical ***September 2024 Banger Meet Thread - First BER Month ***
Discussion in 'Traditional Hot Rods' started by Jiminy, Sep 2, 2024.
  1. I wish I would have seen your Post when you posted it the other day.
    Well I guess I will shoot for next year since I am pretty sure my '19 Hupmobile on the model A ch***is will be done-ish by then. This model A banger stuff is a lot more fun then I would have ever thought when I was a kid.
    Outback, winduptoy and jnaki like this.
  2. That curve is because the car went so fast it pulled the axle back.
    Being serious how does that happen. You would have to bend one side hitting a curb or parked car and then still drive the car and do the exact same thing to the other side.
    jet996 likes this.
  3. It's been towed, or more likely winched to a trailer in the middle of the beam.
  4. iwanaflattie
    iwanaflattie
    This will be a dumb questions but the only place I can see that I can add oil is this little cap here by the oil dipstick..
    It's a 32 model b engine..
    Tía
    Outback likes this.
  5. jet996
    jet996
    from WY
    ARA -At first I thought it was all the hard landings from the wheelies ...
    @hotrodfil -I think you're right, it even pushes out to the front a little. Fortunately the previous owner replaced everything on it before I bought it bearings,brakes, tierods, kingpins etc... All that transfers over to a dropped axle I've been pondering which project to use on.
    Outback and winduptoy like this.
  6. 62pan
    62pan
    That's it. Looks like the T water pump interferes with the original fill tube so that was their fix.
    jet996, Outback and winduptoy like this.
  7. iwanaflattie
    iwanaflattie
    Thank you
    winduptoy likes this.
  8. Fabber McGee
    Fabber McGee
  9. Star 351
    Star 351
    Thats the original oil fill location, male sure that oil cap is capable of ventilation, if it it sealed your engine will push oil out of every orifice it can, you may have problems with oil coming out of that filler setup with it being so short
    jet996 and Outback like this.
  10. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    Anyone have a recommendation on a throttle pedal setup for a crossflow head (carbs on driver's side)? I don't want to use a cable, or something billet... I want a typical mechanical linkage. All of the swing-style pedals I can find seem to be made for cables, and I can't get my head around how to make one work with rods.
    I think the old Ford s**** pedals will have too much offset towards the p***enger side to work correctly?
    Even just seeing photos of cars with this type of setup would be helpful.
    4BangerDean, Outback and 4bangerbob like this.
  11. Outback
    Outback
    from NE Vic, Oz
    The Aussie RHD A's have the carbs on the drivers side on a stock pedal, maybe something like that could be utilized? Will see if I can dig up a photo? Otherwise I'll grab a pic of my car when I can get a chance
  12. 62pan
    62pan
    I modified a s**** setup.
  13. Outback
    Outback
    from NE Vic, Oz
    IMG_20240217_125600193_HDR.jpg Will try to get a better pic
    jet996 and 40 Olds like this.
  14. jim1932
    jim1932
    Took me minute to orient myself. Of course "Drivers side" is the US p***enger side. The header pipes running towards the radiator threw me for a bit.
    Outback likes this.
  15. Outback
    Outback
    from NE Vic, Oz
    Yes those pipes loop forward to miss the steering box.
  16. 4bangerbob
    4bangerbob
    from AB, Canada
    What size of Winfield's are you running?
  17. 62pan
    62pan
    Winfields are CC throttle bodies with C float bowls.
    40 Olds and Outback like this.
  18. 4bangerbob
    4bangerbob
    from AB, Canada
    Thanks for the quick reply. Does it run well and accelerate well with these two carb's?
    Outback likes this.
  19. That is probably the most logical answer now that being said that car must have been chained down or something, 30s and 40s Fords aren't real heavy it would have to be one heck of a mud hole to yank an axle into a U shape.
    jet996 likes this.
  20. 62pan
    62pan
    On the Winfields, I had stumbling issues but once I got the floats set where the carbs were happy they work well. That took some time plus research.
  21. Burning the late night whatever it’s called? Got the engine wired up, hoping to fire it off tomorrow! No spark at the plugs so I’ll have to check out the points.
    Now to mate these two Kong pieces together…
    mvee33, jet996, Outback and 1 other person like this.
  22. jim1932
    jim1932
    I need information for Carb tuning a banger. I am thinking of getting a wideband set up, but I don't know what to do with the data even if I get it. Mine is a simple set up with a mild cam and dual 81's. It runs and is drivable, but is not great, it bogs at bottom of shift to 2nd or 3rd. I know back in the day they didn't have all this technology. What was the guidence on setting up a dual 81 or similar set up?
  23. Kevin Pharis
    Kevin Pharis
    from Califunny
    I went with a AFR gage kit similar to this one on my T;
    https://www.summitracing.com/parts/avm-30-0300?rrec=true
    The gage provides a real time feedback with no data processing required. Simply watch the gage under regular driving and adjust as necessary. I wired mine in with alligator clips and tucked the gage in the corner of the seat cushion for an authentically temporary feel. Found that my Akron-Hed equipped T engine likes about 12-12.5:1 ratio, any closer to the ideal 14.1 and it pops and sputters sumpin fierce!
    Outback and 4BangerDean like this.
  24. Dan from Oakland
    Dan from Oakland
    Charlie Yap has (had) a nice article on Stromberg carbs in the last issue of Secrets. Lots of good info there.
    Outback likes this.
  25. 41blueoval
    41blueoval
    I bought one of those AEM gauges to tune my 31. Gauge fried immediately, got a replacement it also acted up. RF interference from the stock ignition was the cause. I went with modern cap and suppression wires to make the F/A gauge work.
    Outback likes this.
  26. Kevin Pharis
    Kevin Pharis
    from Califunny
    Did I miss the posts about how awesome (or lame) the Signal Hill event was last weekend…? Did anyone go?
    Outback likes this.
  27. Dan from Oakland
    Dan from Oakland
    Wondered about that- someone must have gone from SoCal-----------------------?
    Outback likes this.
  28. Hmm
    Just been crickets here
    We did ElMirage and set record in V4F gas mod roadster
  29. Stan Back
    Stan Back
    And what is the record for the Vintage 4-cyl. Flathead / Gas Modified Roadster?
    . . . and a picture, please.
    . . . and who was driving?
    Outback likes this.
