1952-59 Ford Oil pressure dummy light came on
Discussion in 'Off Topic Hot Rods & Customs' started by Rui, Sep 18, 2024.
  1. Rui
    Rui
    Hey guys.
    Hope all is well.
    I was driving the Ford to work this morning and the oil pressure dummy light came on. I dont have a pressure gauge.
    As I was only 1km away from home, I drove it back.
    Oil level is just bellow max, but that doesnt even matter because the light indicates lack of pressure, not oil volume.
    I'm thinking the likely culprits might be the oil pump or the pressure switch.
    Any other options?
    Thank you.
  2. Adriatic Machine
    Adriatic Machine
    You can test the circuit with a piece of wire. Disconnect the sender and tap the wire to ground. See how the light reacts. You can also test the sender itself with an ohmmeter. If those check out good then the next thing is to remove the sender and install an oil pressure gauge and run the engine briefly. Good luck
    Rui likes this.
  3. Rui
    Rui
    Thank you for your answer Adriatic Machine.
    danman55 and Adriatic Machine like this.
  4. Paul2748
    Paul2748
    If you able to drive the car some distance without any strange engine noises, take off a rocker cover and start the engine and check for oil at the rockers and overflow tube. If you see good oiling, then the problem is the sending unit.
    jimmy six and Rui like this.
  5. Rui
    Rui
    Thank you for your reply Paul.
  6. Rui
    Rui
    Good morning guys.
    Later I'll be picking up a pressure reading gauge from a friend and do a brief test to exclude a faulty switch.
    From what I've read, for this 223 I6 it should be 10 psi minimum per thousand rpms. So at 1000 rpm, not less than 10psi.
    Is this correct?
    I cannot find the specs values on the 50's Ford engine manual.
    Thank you again.
  7. Adriatic Machine
    Adriatic Machine
    That’s about right as a general rule more or less. I have the manual at home I can check when I get home. More importantly, the switch triggers at a specific psi I think around 5 and below.
    Rui likes this.
  8. Rui
    Rui
    Thank you. I do have the 50's car manual, but cannot find the specification in there.
  9. Rui
    Rui
    Found an old post at the Ford Barn regarding the hexagonal shaft at the bottom of the dizzy that would not drive the oil pump anymore, because it got worn and rounded. Another thing to check.
    1954 Ford 223-6 no oil to rockers - The Ford Barn
    Adriatic Machine likes this.
  10. Adriatic Machine
    Adriatic Machine
    Good call! I’ve used an old 1/4” Allen key wrench to replace them but I had to use a carbide drill to make the hole but ther are other ways to secure the shaft.
    Rui likes this.
  11. Rui
    Rui
    Yes, this Ford Barn member brazed it. Good thing I dont know if I would have remembered to look at that.
    Ill take care of it this coming weekend.
    Regards.
  12. Rui
    Rui
    Good morning.
    We've got about 3 Kg/cm2 at idle, about 40 psi, so I guess it is not bad. Gonna try another pressure switch.
    Thanks for the input guys.
  13. Adriatic Machine
    Adriatic Machine
    My 223 is very fresh with less than 10k miles and I’ve got about the same, maybe 45psi at cold idle. Glad to hear.
    down-the-road and Rui like this.
  14. Rui
    Rui
    I was trying to post a link to a youtube video, but its not working, so i took a screenshot (below).
    I think I made my conversion right. 3kg/cm2 = about 42 psi. Cold idle.
    Tomorrow I'm gonna test it more carefully (yesterday night I could not resist hookin it up in a hurry and firing the engine) and try an old pressure switch I have vs. this newer one that supposedly has gone bad.
    Have a good weekend guys and thanks for the input.
