Art & Inspiration Tech School Students Doing Good
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Nov 7, 2014.
  1. Auto tech students today IMG_2002.jpeg 64 292.
    Getting ready to fire it up.
    Basic ignition wiring and diagnostic skills.
    Compression and vacuum testing
    If it has good numbers, clean up, reseal and paint.
    Build a carb
  2. Fired right up
    rpm reading is off.
    Around 40psi just above normal idle.
    Gotta replace the fuel pump and we can let it warm up and see what it does
    No oil change yet
  3. chevy57dude
    chevy57dude
    Great stuff, Anthony. Gettin' greasy as a teen set the tone for my life. You're a good influence on them. Chevy57dudette is a high school teacher. Loves to teach, refers to the cl***es as ''her kids''. Youngsters really respond to the positive attention. Some don't have much of a home life, either. No doubt some will come back a few years from now and thank you.
  4. Some backwoods head work
    Students lapped valves for a 292 Chevy
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ The old power spin and seat method.
  6. I guess.
    We’re just cleaning em up and installing new seals.
    Older rebuild. Could use guides.
    Engine ran great on our stand and had very good comp numbers. 150-160
    40psi oil
    It’ll work for a truck that sees about 3/4k miles a year
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
  8. Yep. Put pressure on it from the valve side.
    Turned at a slow to medium speed
  9. chicken
    chicken
    from Kansas
    Hey, yer supposed to lap 'em by hand with the suction cup stick. Builds character! And a fancy pants cordless drill too....o_O :D
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Guilty of doing the same. Now let’s hear the nay sayer’s.
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
  12. mad mikey
    mad mikey
    I sincerely commend Professor Anthony for all the fine work he does with the yougins. I would run it!
  13. chicken
    chicken
    from Kansas
    :D Guilty of doing the same. Shhhhh.!
  14. I’ve never done that, but I damn well would have if I would’ve thought of it! Thanks for the tip!!!!
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Lube stem well, always keep lap compound wet, slow speed. Chatter solved.
  16. Purge with fire
    growing up, this was how we cleaned em
    Students bagged and tagged the important stuff
    Clean gasket mounting surfaces and a pressure wash next
  17. S**** yard 63 c10 door. Has the typical wrapped around the fender damage that was hacked up some time in the past. Filler around 3/8 thick and typical screw dent puller distortion
    we got it to this point and called it done. Welded up the holes.
  18. Valve springs had these shims
  19. guthriesmith
    guthriesmith
    Man, that is a familiar fix! Seems most of those trucks have that damage and ****py repairs.
  20. Final clean on these old valves to get the compound off. Pressure washed the head and cleaned gasket surfaces.
    The old ones are just keeping em from falling out
    one to go
  21. HOTRODPRIMER
    HOTRODPRIMER
    Anthony, you are teaching the next generation the art of working with metal, these kids are doing some amazing work and you are to be commended, I wish we had teachers like yourself when I was in high school. HRP
  22. Hillbilly leak check
    couple taps and it p***ed
    williebill, Jeff34, brEad and 8 others like this.
  23. Crusty Chevy
    Crusty Chevy
    Neat trick. Is that light oil or water, and how much air pressure do you use?
    Sharpone and anthony myrick like this.
  24. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Certainly less than what the valve spring rate is. :)
    clem, Sharpone and anthony myrick like this.
  25. Water and whatever the psi is at the regulator
    90-100
    But no where near that in the port
    Got a couple tiny bubbles on a couple exhaust valves. Flipped it over, set a piece of wood on top of the valve stem and banged it with a hammer.
    no more bubbles
  26. Two successes today. Froze bolt (short threaded screw) and a very rusty bearing race with no access from behind.
  27. 63 c10 door. The outside skin is good. The inner bottom isn’t.
    Students rough cut the inner then cut the spot welds for the skin.
    Then separated the hem joint. Those are tough when not removing the outer.
    the inner will be final trimmed after the new bottoms are bought.
    We’ll get that lip dollied amd the surface rust treated next.
    Squablow, williebill, brEad and 5 others like this.
  28. 1952henry
    1952henry
    Good for you Anthony!
  29. Got the rear main seal swapped out. Super EZ.
    Students primed thr 292 pieces
    old beat c10 hood. Has bullet holes. Using it to demonstrate basic metal work.
    young man was learning how to heat shrink.
    Okie Pete, brEad, williebill and 11 others like this.
  30. 110 pound young lady torquing 95 pounds
    Okie Pete, brEad, TA DAD and 15 others like this.
