Projects Disc conversion
Discussion in 'The Hokey Ass Message Board' started by IowaTom, Sep 20, 2024.
  1. IowaTom
    IowaTom
    Guys - I'm doing a front disc conversion on a '52 Willys Aero, using a kit meant for early AMC cars. It's an almost perfect fit, except a steering arm is the direct path of a caliper bolt. After trying a few things, the only way this is going to work is if I flip the caliper adapter over, which means the caliper will be in front of the spindle, instead of behind it. My dumb question is; will this make a difference in braking (safety)? Thanks!
    Unkl Ian and bobss396 like this.
  2. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    No, But, there will be arguing
  3. Mike VV
    Mike VV
    from SoCal
    As long as the bleed screw is pointing, mostly..."up"...no, no problem at all. That will be fine.
    Mike
  4. MAD MIKE
    MAD MIKE
    from 94577
    Just verify at full lock and compression the caliper does not come in contact with anything on the frame/suspension/etc.
    alanp561, Just Gary and Tow Truck Tom like this.
  5. On a cruiser or dd? Nope. I've seen arguments saying otherwise but they seemed purely hypothetical
    VANDENPLAS and Tow Truck Tom like this.
  6. gene-koning
    gene-koning
    The only issue I can see may be related to the position of the bleeder screw and possible interference with something else. As long as the system can be bled, and the re positioned caliper doesn't interfere with anything else, all should be good.
    Tow Truck Tom likes this.
  7. pprather
    pprather
    Be sure the flex hose is not tight at left and right steering lock.
    alanp561 and Tow Truck Tom like this.
  8. inthweedz
    inthweedz
    It won't make any difference to the braking, but if you want both sides to look the same, do the same to the other mount bracket (mount it out front) and swap calipers L to R to get the bleeder on top, many factory cars have calipers out front..
  9. gimpyshotrods
    gimpyshotrods
    There is no engineering justification, other than materials conservation, for one caliper position, or another, so long as the bleeder is on top.
    Calipers and brackets are dumb pieces of metal.
    They have no idea what side they belong on.
  10. IowaTom
    IowaTom
    You guys are the best!
    Thanks so much for the great advice!
    VANDENPLAS likes this.
  11. chevrolet50steve
    chevrolet50steve
    You can always unbolt caliper,clamp piston in and hold caliper up and bleed with nipple pointing up.
  12. MOONRNR
    MOONRNR
    - THE H.A.M.Bone EVER EXCITING - 'WILLY STOP' BRAKE TECH -
  13. Ebbsspeed
    Ebbsspeed
    Or take the much simpler route. Mount the right caliper on the left side and vice versa, and Bob's yer uncle!
    You do realize that in most cases the right and left calipers are mirror images of each other, right?
    gimpyshotrods likes this.
  14. gimpyshotrods
    gimpyshotrods
    Uh, Bob IS my uncle!
  15. ^^^^ And mine too!
  16. saltflats
    saltflats
    from Missouri
    I had an uncle Bob also.
    Funny story. Fresh out of high school I went to a auto tech school in Grandview MO. We went to school at night and worked during the day. The school would find us jobs in the automotive industry. My first job was working at Taylor cable Co. It was an assembly line type of work and I hated it a would bug the counselor daily to get me a job somewhere else. Finally they got me a job at one of the Midas muffler shops. On my first day on the job all the guys were around this one car working on the front brakes. I ask what was going on, they said the replaced the calipers and couldn't bleed them out. I took one look and said you have the calipers on the wrong side with the bleeders pointing down. I was never very popular after that. Guess they didn't like some young kit showing them up. It wasn't long that they moved to the Midas shop down at 30th and Troost in KC.
  17. twenty8
    twenty8
    The usual helpful, friendly post:rolleyes:..... just like the last time. You could try the delivery without the attitude.
    INVISIBLEKID and 57 Fargo like this.
  18. I have to comment to one up.....not only did I have an uncle Bob I also had a grandpa Bob lol
    saltflats likes this.
  19. Ebbsspeed
    Ebbsspeed
    Ha, I AM Uncle Bob to 9 nieces and nephews, hence "Bob's yer uncle" is my favorite UK idiom! And my dad is Bob too! Dad and I 15 years ago.
  20. Budget36
    Budget36
    Well, not an uncle or blood relative, but my ex father-in-law was a Bob
    I’m out now.
  21. Does it count that I came very close to being named after Grandpa Bob? Lol. Oh yeah my step moms nickname was Bobby
  22. MOONRNR
    MOONRNR
    Have you actually taken the time to read through some of these brake theory threads?
  23. Unkl Ian
    Unkl Ian
    Is it close enough, that you can just bend the steering arm ?
    If not, move the caliper.
    As long a the bleeder is on top, no problem.
    57Fury440 likes this.
  24. twenty8
    twenty8
    Yes, I have. But I seem to get put off with all the drama and move on......
    Your quoted stuff at the end of your posts is a good example of why I lose interest.....
    "BJR POSTED – 24JUL2024"
    "The pads do not retract, they are knocked back a few thousands by the rotor runout."
    Not necessary, not cool.;)
  25. MOONRNR
    MOONRNR
    Did you actually read and understand what he posted? That is the type of incorrect info that is passed onto others and is why no one can seem to understand correct braking theory.
    And then he/she/whatever tells me to move on?
    I could post dozens of examples.
    But in all actuality, I get a big chuckle out of some of the stuff posted here.
    OH, BTW ... There is an IGNORE OPTION you can use here to block my posts out. No sense in drawing your BVD's up. I have no interest in trying to BE COOL, whatever that is ...
  26. twenty8
    twenty8
    Yes, I read what he said, and it was not correct. Still not a reason for the response he got.
    And, man, I have no need to ignore you, no matter how tempting it is. That would be rude......:rolleyes:
  27. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    You guy's duke it out while we all watch! Ding Ding! Rotor Runout?= LMFAO!:rolleyes:
  28. MOONRNR
    MOONRNR
    What about the response I got from him? What am I, chopped liver?
    ... hmmpf ...
    When did you start being concerned about being rude?
    You just found JESUS?
  29. twenty8
    twenty8
    Yeah, sorry. Very insensitive of me. I should have been aware of your feelings too.:D;)
