Projects 1930 Oliver Roadster Build
Discussion in 'The Hokey Ass Message Board' started by oliver westlund, Dec 22, 2021.
  1. oliver westlund
    oliver westlund
    Idk, I wasnt worried about keeping it clean, body will be engine block color, interior white. I think what Im after is a slightly used look on this one. Something that could be 60 yrs old. Not really patina but not show rod either
    dwollam and chryslerfan55 like this.
  2. oliver westlund
    oliver westlund
  3. Six Ball
    Six Ball
    from Nevada
    Now we're gettin' somewhere!
  4. oliver westlund
    oliver westlund
    Another shop day underway. Brakes plumbed in, torque arm finished up, hopefully a handful of other odds and ends by the end of the day! 20241005_171623.jpg
    bchctybob, brEad, scotts52 and 3 others like this.
  5. oliver westlund
    oliver westlund
    End of the day. After chasing down 10 leaks and a lot of bleeding both of the brakes and my fingers...the car has a pedal! Going to leave the body off for a day or 2 and clean up a few other things then it goes back on and the fuel tank gets hooked up! Then wiring... next friday I pick up the front tires. The list between me and driving this thing is getting shorter and shorter!
  6. You’ve come a long way baby !
  7. oliver westlund
    oliver westlund
    Its really neat seeing something so born in my head materialize into reality
  8. Six Ball
    Six Ball
    from Nevada
    Neat for us too!
  9. oliver westlund
    oliver westlund
    While the body is off, I decided to tackle some of the basic bodywork that needs done sooner rather than later 20241017_160522.jpg
    I fixed the bottom of the drivers side all the way back and then I fixed the wheel well. Neither is going to get blocked and worked all too much before some primer goes on but I wanted to rough things out better 20241017_160524.jpg
    The progress looks good so far
  10. oliver westlund
    oliver westlund
    Well...it looks like its all one car....on one side haha
    Seat riser goes in tomorrow, then body gets set back on. Will attack the other side another time. Right now I need my shop back (this thing takes up a ton of room blown apart)
  11. oliver westlund
    oliver westlund
    Home stretch....need to finish up the tank mounts, slosh the tank and install, design and make a shifter, front floors, parking brake and wire the car!
    Of course after that comes bodywork, paint, finish the rad shell and make a custom insert...
    bchctybob, Tim, alanp561 and 11 others like this.
  12. dwollam
    dwollam
    Lookin good Oliver!
    Dave
  13. oliver westlund
    oliver westlund
    Thanks Dave!
    chryslerfan55 and Tow Truck Tom like this.
  14. oliver westlund
    oliver westlund
    Cranked out a lil column drop out of br***, just need to tig up the corners Screenshot_20241025_125350_Gallery.jpg
    Also finally started getting the new used rubber on the front! Lovin the look!
  15. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Yeah You got "The Look"
  16. Six Ball
    Six Ball
    from Nevada
    You have to be feeling good!
    Stogy, oliver westlund and scotts52 like this.
  17. oliver westlund
    oliver westlund
    Either high beam or ign indicator. Old gl*** lens, has "the look"
    bchctybob, Six Ball, brEad and 8 others like this.
  18. cfmvw
    cfmvw
    You should get a license plate frame that says Oliver, and a vanity plate that says Twist!
    Stogy, brEad, Six Ball and 2 others like this.
  19. oliver westlund
    oliver westlund
    Thatd be funny! Its actually getting ***led as a 49 so itll be wearing the 1949 plates thatre on it! Its been a really fun build. Cant wait to drive it!
  20. oliver westlund
    oliver westlund
    Okay, wiring is happening! Little of this
    Little of that...
    Screenshot_20250309_211443_Gallery.jpg 20250309_213820.jpg 20250309_163125.jpg 20250309_163117.jpg
    Put ignition on the left, switch for headlights on the right.
    As of now going to wire the switch to two relays, headlight low beams and rear running lights/license plate light. I can readdress later for high beams if I feel I need em. 1 relay for a horn if I add one... not much to it, no heater, no radio... some voltage reducers for guages I spose. Have a jeweled light in the column drop, might use that as a lights on indicator... I'll stay after it. Hardly an expert at this electrical stuff... using this cheap amazon fuse and relay panel up under the dash. Wouldnt do it this way again if I had it to do over. 20250309_211525.jpg
    There's a great video on puddin creeks youtube channel that shows how to build a nice looking traditional fuse panel. I'll do that next time!
  21. oliver westlund
    oliver westlund
  22. Stogy
    Stogy
    Congrats on that big milestone Oliver...2025 is going to be a biggie for you!!
  23. Papas32
    Papas32
    from No.Ia.
    Good for you. one of my favorite threads!
    Russ B, Six Ball and oliver westlund like this.
  24. oliver westlund
    oliver westlund
    Thanks! Theres a cruise in 2 months, Im hoping to be in it!
    Thanks! Glad to hear it!
    chryslerfan55, Stogy and scotts52 like this.
  25. oliver westlund
    oliver westlund
    Did a little finish work on the grill shell then made a placeholder insert out of fencing as a visual aid...diggin it
  26. Six Ball
    Six Ball
    from Nevada
    Looks cool like what the old track racers did to keep the mud & spare parts out of the radiator.
    oliver westlund likes this.
  27. oliver westlund
    oliver westlund
    Itll get a stainless insert made before long. This will work for a bit
    dwollam, Six Ball, brEad and 2 others like this.
  28. oliver westlund
    oliver westlund
    Made a shifter yesterday out of a cpl of model a mechanical brake pivots and the old locking bar off of our gate haha
    Catches all the detents and doesnt hit the dash or the seat. I am thinking about adding a guide plate with additional detents to keep it from falling out of gear or getting easily bumped
  29. oliver westlund
    oliver westlund
    Made the guide plate today, solved the problem
  30. oliver westlund
    oliver westlund
    bchctybob, brEad, shanejgass and 4 others like this.
