Technical Hard chop: sitting on the chopping block
Discussion in 'Traditional Hot Rods' started by 65standard, Feb 21, 2024.
  1. RodStRace
    RodStRace
    One page.
    On a Budget? Ha, ha, (repeat until end of page).
    Tony Defeo did it though. He used to swing by here, last post was over 10 years ago.
    Outback likes this.
  2. 65standard
    65standard
    My un***embled Brookville doors are ready. I will go there and pick them up this Friday.
    I should be back on the chop next week.
    pprather, clem, 31chevymike and 10 others like this.
  3. Robdski
    Robdski
    Thanks for sharing your knowledge, the detail photos are excellent.
    31chevymike, 65standard and Outback like this.
  4. 65standard
    65standard
    1494F554-50F5-4612-99F7-EBCC135D1215.jpeg I picked up my un***embled doors. Kenny has all his stamping issues solved and these doors are available now.
  5. 65standard
    65standard
    T******* the left inner door to fit the body. C2685D01-D39D-4E58-8F30-B8F7E7DA9563.jpeg AD320A2A-ADB2-4BA0-91E6-56BB2AE96FC2.jpeg 92E8E79F-857A-4D4D-B0CE-4DBD992B24BA.jpeg FB515A1F-49CD-46F7-8253-0B1054B19F83.jpeg A817E3D3-FA04-4EC1-AECE-51E4812095AB.jpeg 158780B0-F201-4652-AEC9-56B759AAE960.jpeg FAD0440C-DB32-477C-A7B0-9260A3FDB358.jpeg 52937560-06D2-495E-ADBB-86A1CD37FEB6.jpeg B55F19D2-CD65-4FE9-B32F-13E3B7CCC90B.jpeg
    Fordors, Just Gary, Tim and 6 others like this.
  6. 65standard
    65standard
    Getting the hinges aligned and fitted to the inner door A645AA81-E5DA-4A56-8CD2-3E69D9EF8BED.jpeg FC931AA2-E5EA-451C-8BCB-93C9B9A982FF.jpeg EC78BBCF-DB83-4928-938D-E252F7A03548.jpeg 350CDB5D-84BF-4AB1-ADC5-C89AC97EC702.jpeg E1B681E1-DB63-4718-B273-8DC61588564A.jpeg 16826228-D138-4AC5-8501-9B05B6E8A949.jpeg 950D7048-A7A0-48A3-9B0A-C6AC3AE39C8C.jpeg
  7. patsurf
    patsurf
    31chevymike, Outback and porkshop like this.
  8. 65standard
    65standard
    3C85C3B8-6F74-4A74-AF23-563BE9386A80.jpeg 15572394-46DD-4A37-B632-E4C84E3E1502.jpeg 1D3B092E-B994-4422-940B-38690A2DD2A8.jpeg 61B275EA-B83C-46C5-A610-184670CFEDCC.jpeg Putting the door top back together with the laid back a-pillar. Next is weld this part up , then add the reinforcement structure at the a-pillar. The final piece will be putting the side gl*** track guide in.
    Fordors, impala4speed, Tim and 13 others like this.
  9. RodStRace
    RodStRace
    Judging from the work done, this is all well within your skill set. I just wondered if there were any parts that made you scratch your head or have to rethink things?
    porkshop and 31chevymike like this.
  10. flamedabone
    flamedabone
    I have been waiting for these doors with as much anticipation as you have.
    Nice work, -Abone.
    The37Kid, Outback, porkshop and 3 others like this.
  11. Happydaze
    Happydaze
    Great that the door supply issue has been resolved. Even better is that the door looks to be well on its way to fitting the door aperture nicely which wouldn't have been the case originally when the body was first set up, in whatever the thread was called thread! Finish line is in sight!
    Where are we going after this? Enjoying the ride and don't want to get off!
    Chris
  12. 65standard
    65standard
    F1F67751-6408-48DC-8557-7F0ED125AA5B.jpeg D06679DA-0F11-4986-95AD-C25E7EF64E28.jpeg C71DE65B-BBEF-43F5-B183-F2B057DD409C.jpeg EF0EB3AE-BA2A-47DA-AEF3-BA468B60FB2F.jpeg 1ADEB731-8C5C-4FB6-B89C-15F359E8DA97.jpeg I’ve only had two snags building this car.
    First was the A-pillar/front door jamb not fitting. A relief cut was made in the body to correct the alignment with the jamb.
    Second was the fuel filler hose and the roll bar pipe interference. Easy fix. Making a roll bar to fit and keep all the wood inner structure was well planned out. But the fuel hose from the flip top cap to the tank needed a little tweak.
    the car is going together great. The build could have been a little easier if I had an original 3-window to do side by side comparisons. I’ve been lucky to have many H.A.M.B. members help me with their knowledge. Much appreciated guys.
  13. Tim
    Tim
    from KCMO
    Looks great
    31chevymike and porkshop like this.
  14. Outback
    Outback
    from NE Vic, Oz
    Certainly does!:D
    31chevymike likes this.
  15. 65standard
    65standard
    52D6B8AF-C042-48D1-AF26-B95CB178A5D3.jpeg 3D253617-8858-46E0-B8B9-20CA53FA05EE.jpeg ADF9738B-B021-4755-B688-D8FF7F63C09E.jpeg 03E1BCC0-C8F1-48D1-8E33-1ED136952626.jpeg A88327EB-8F39-47C3-81B0-1C5B8DC24CAD.jpeg 837DBE48-EE79-4D12-AA42-FBB76A9633D8.jpeg 1B2CBC71-828A-4088-977E-535B428F0AC8.jpeg 58ADCD71-1692-42BA-AAE1-0F17D436185C.jpeg E3C75E56-76BF-468C-AF93-48159D3BDC65.jpeg EC53BB10-FC8B-4F54-B603-336755E67FA4.jpeg The left inner door is fitted and finished. I will fabricate an X-brace and get the gl*** channel, regulator, and gl*** template made and working before I fit the door skin.
    Fordors, Outback, teach'm and 14 others like this.
  16. Dedsoto
    Dedsoto
    from Australia
    Do you plan on putting in a secondary locking/latching mechanism?
  17. 65standard
    65standard
    I have the Brookville dead bolt system but I may just use a hook and eye latch as my safety. Would seem more period correct to me. I’m not sure I need anything since my frame is boxed and X-braced, plus the roll cage should prevent body twist popping my doors open. B3516564-2803-4D58-B355-0BE347F58F30.jpeg
    Fordors, Outback, 31chevymike and 6 others like this.
  18. oj
    oj
    I like that, kinda simple, did I miss the door check strap?
    Outback and 31chevymike like this.
  19. pprather
    pprather
    You might think about installing the door gl*** before skinning it???
    Can you get your gl*** template installed if skin is in place?
    Just a thought.
  20. RodStRace
    RodStRace
    He's on it.
  21. 65standard
    65standard
    A0D2812E-C2D0-4069-B4F5-D94690485DE2.jpeg F0906B67-3E96-48C6-ADD4-3B482D82EE81.jpeg 03A25BF8-3B82-44E8-A415-91FD71B072AD.jpeg 2D34DA6F-19F8-4EB4-840B-3EC592D0ECD5.jpeg I have the inner door finished. I made X-bracing for the insides. This really strengthened the door, but added weight. I’m going to drill 47 holes in the brace to lighten the door.
    31chevymike, j hansen and Motorwrxs like this.
  22. 65standard
    65standard
  23. Motorwrxs
    Motorwrxs
    Awesome work.
  24. flamedabone
    flamedabone
    Those doors are going to shut like a new Cadillac.
    -Abone.
  25. Happydaze
    Happydaze
    I spy spacers between the inner skin and the window mech. New one on me. What's that about? I haven't got those and my winders seem mysteriously stiff. Hhmmm. Really interested in finding out your why!
    I also see your door bracing is made of steel channel. No wonder it's heavy? Nascar side bars??
    Chris
  26. 65standard
    65standard
    No spacers on the regulator. That is how they are designed to clear the clock spring. Those are mounting studs. Mystery solved.
    The channel is 1/2 x 2 x 1/8 thick. It’s 1.33 lbs per foot. What would you recommend I use?
    31chevymike, Happydaze and Outback like this.
  27. alchemy
    alchemy
    Bobby Walden makes his inner braces from sheet metal. Turns edges for strength.
  28. Happydaze
    Happydaze
    Thanks. Not sure mine (Vintique) has those standoffs. Will check!
    No suggestion on material use, just an observation in a good way, no criticism intended!
    Chris
  29. 65standard
    65standard
    The sheet metal braces sounds like a good idea. I could have brake formed a channel out of 16ga and used that.
    My regulators are united pacific.
  30. alchemy
    alchemy
    A lot of extra weight on a door with 33% less hinges sounds like it could be a problem. If it were mine I’d probably be bracing the backside of the B pillar more than the internal of the door just to hold the door up.
    31chevymike and Fogger like this.
