Technical Cured My Flathead’s Occasional Overheating (The Hard Way)!. Updated 1-30
Discussion in 'The Hokey Ass Message Board' started by hotrodA, May 28, 2022.
Which project?
Poll closed Jun 17, 2022.
  1. 40 coupe: Replace blown flathead with on hand 283 and all the parts. Drive by Aug.
    42 vote(s)
    68.9%
  2. 41 pickup: Get back on Desoto hemi powered pickup and let coupe sit. Drive by ???
    11 vote(s)
    18.0%
  3. Have a pre-estate sale and take up model railroading.
    8 vote(s)
    13.1%
  1. wheeltramp brian
    wheeltramp brian
    Can't wait to see it on the road.
  2. hotrodA
    hotrodA
    Thanks! It’s been a long row to hoe.
  3. saltflats
    saltflats
    from Missouri
    Did you have a sleeve inside your doughnut gasket?
  4. TomT
    TomT
    All the sweeter when it’s finally on the road!
  5. hotrodA
    hotrodA
    @saltflats
    No. Is that recommended? Does it improve the seal? Who has them?
  6. saltflats
    saltflats
    from Missouri
    Yes it will help support the doughnut. Walker used to sell them.
  7. hotrodA
    hotrodA
    Thanks for the tip. I’ll check it out.
  8. hotrodA
    hotrodA
    Well, SOB!! It’s never ending. :mad:
    Lift cylinder started leaking AGAIN! Rebuild lasted all of six months.:mad:
    Of course the car is on it, raised up. Should be able to get it on the ground and finish it up.
    Stay tooned, as @Hamtown Al (RIP) used to say. More opportunities.. Sigh.
  9. hotrodA
    hotrodA
  10. Tim
    Tim
    from KCMO
    Looks like what I have on mine.
    saltflats likes this.
  11. saltflats
    saltflats
    from Missouri
    Yes that is it.
    hotrodA likes this.
  12. hotrodA
    hotrodA
    @saltflats Thank you!
    Driveshaft is back in!
    Hopefully the last thing needed underneath, since the lift cylinder has started leaking AGAIN!!
    I need to lower the car/lift to put the radiator back in and fire it off. If I do that it may or may not go back up.
    I think I will get it running, pull it OFF the lift, and then try to raise the lift enough to lock it down and pull the cylinder.
    Bandit Billy and saltflats like this.
  13. saltflats
    saltflats
    from Missouri
    Your welcome.
    I had to replace the seals in my two post lift earlier this year.
  14. hotrodA
    hotrodA
    While putting the driveshaft back in I saw something that needs correcting, but I had forgotten about.
    Maybe dodge a problem down the road.
    Think these U-bolts are way too long?:rolleyes:
    One side is longer than the other! Why?
    Because there are two different thickness lowering blocks!
    I’m figuring rear frame is tweaked:eek:
    Car is level so it’s going to stay. Just trim them off with the Sawzall.
    Right side
    Left side
  15. TomT
    TomT
    You are using the same rear spring as I am. So far with the new air shocks the ride us great- looking good!
  16. hotrodA
    hotrodA
    @TomT
    No problem with the ride as long as I’ve had it.
    Those blocks should be the same, not an inch different in height.
    Something’s off with the frame.
  17. TomT
    TomT
    Are the u-bolts the same length? I know - silly question ……
  18. hotrodA
    hotrodA
    @TomT Yes, they are.
    Rear end of frame apparently has a twist, high on the left at the rear shackle. The 1” difference in the blocks levels the body off. It measures the same side to side.
    I was just concerned about a flat on the RR and those bolts hitting the pavement.
    T******* them down.
  19. hotrodA
    hotrodA
    Mo better!
    At least I can get a deep socket on them now.
    Bandit Billy likes this.
  20. Mart
    Mart
    --The lock stop is normally fitted at the rear of the axle. If you can't fit it at the rear because of the disc brake adaptor, and have to fit it at the front you might find the wheels will turn too far. You can fix it by using a bigger nut on the lockstop, (I have used a lugnut) or tacking a piece of metal to the spindle to contact the lock stop.
  21. hotrodA
    hotrodA
    Thanks! It’s a Ford stop nut, so I’ll try it first, and adjust from there. At least it’s easy to access.
    All that was on there was a hex nut. Found the rub spot on the p***enger inner fender panel.
  22. hotrodA
    hotrodA
    Put it on the ground today, hopefully with everything completed underneath!
    Next: See if it will turn over, check voltage and continuity in under dash wiring,
    install fan, radiator and shroud, add coolant, hook up gas to fuel pump and fire it off.
    Have I missed anything?
    TomT likes this.
  23. TomT
    TomT
    Piece a cake!
  24. 1946caddy
    1946caddy
    from washington
    Anyhow, today I got the tube shortened and the replacement shaft with new bushings from Dale at Weedeter (@Weedburner 40) put together.
    Does the Weedert steering upgrade require the shortening of the steering tube because it moves the steering box?
  25. Weedburner 40
    Weedburner 40
    No, it doesn't move the box. The tube needs to be shortened to accommodate the U-joint and new 525 box.
  26. hotrodA
    hotrodA
    Checked out electrical circuits today, but accidentally shorted out my ignition switch :mad:
    The MIDI/AMI main fuse I had put in line blew. I hadn’t bought any spares yet, so ran all over town looking for some. Not one parts store carried them. Not my local guy, AZ, ADV, nor NAPA. Not the electrical supply nor the hardwares. Finally found them at a car stereo install shop, in every amperage:D Promptly ordered some spares on line for my kit.
    Anyway, everything works. Hi-Lo Headlights, brake, turn, interior. Went to turn it over and ZIP!
    Nothing thru the new Ford solenoid I added before the Chevy starter. I’m hoping just no ground through paint on firewall. Find out tomorrow.
  27. wheeltramp brian
    wheeltramp brian
    If using the gm "mini" starter they dont like the Ford solenoid.
  28. hotrodA
    hotrodA
    @wheeltramp brian
    Thanks! Good to know. Please expand.
    Do you mean that it won’t work with that setup, or it damages the mini starter?
    Is it even needed in your experience?
  29. wheeltramp brian
    wheeltramp brian
    On my daily driver 64 El Camino I had a standard 3510 style starter. But then as it got tired and went out, I put the GM mini starter on it as I do with all my customers' rides and it wouldn't start with my Ford solenoid. For whatever reason, the starter doesn't like to be hooked up that way. So I byp***ed the solenoid and all is great. Happened 2 more times on customer rides with the solenoid and I had to buy p*** it.dont need the solenoid on the mini starter
    hotrodA likes this.
  30. hotrodA
    hotrodA
    Good to know! I’ll try connecting direct.
    Thanks !
