Projects 1957 Chevrolet "Low Life"
Discussion in 'Traditional Customs' started by Opel, May 29, 2019.
  1. ALLDONE
    ALLDONE
    amagine the balls the first guy to chop a top had.... then Amagine the heat he got from the preppy followers till it caught on...there's leaders and followers,.. then there's the ones that stay in the middle till it gets approval
    chryslerfan55 and patsurf like this.
  2. COCONUTS
    COCONUTS
    To me, the 55 to 57 Chevy era, just don't make good looking "full on" customs. It is far more easier to go the other way. With that being said, bring the rear up a few inches, weld up the front doors and enter and drive from the rear seat, with the engine push back under the dash. While I have "you all" upcoming negative comments, add a little of the stock stainless.
  3. Raising a car up is never the correct answer
    COCONUTS, Outback, jimmy959 and 8 others like this.
  4. Okie Pete
    Okie Pete
    It’s the car that He wants to rebuild and put back on the road. I for one will cheer him on and look forward to seeing his progress reports . If we all liked the same thing what a boring place this would be .
  5. 1pickup
    1pickup
    I'd love to drive that! Don't listen to these old guys telling you what to do with it, or how it was ruined. Nothing better than cutting up a "cl***ic" and ******* off the restorers.
    sunfighter, Outback, Squablow and 2 others like this.
  6. Opel
    Opel
    from Germany
    Before: Customizing with **** work and tons of filler.
  7. Opel
    Opel
    from Germany
    After: Metal work with good finish, some lead work required. 250308 (5) klein.jpg
    BigRRR, sunfighter, lucky and 24 others like this.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    cool, I enlarged the pic, always select "full image when posting pics.... great job man
  9. Baumi
    Baumi
    @Opel , where in Germany are you located? I read you´ll need to replace an inner rocker. I have a new one for a 55-57 Chevy , you can have it if you want. I´m about 80 km east of Munich.
  10. Opel
    Opel
    from Germany
    Before: Hood with 1 inch thick filler at the closed gun sight. 241115 (29) klein.jpg
  11. Opel
    Opel
    from Germany
    After: Metal finish. 241130 (3) klein.jpg
  12. AHotRod
    AHotRod
    Great job !
    Greenblade likes this.
  13. Opel
    Opel
    from Germany
    @Baumi, I`m living between Cologne and Düsseldorf. But I will be in Munich in April. The part you have, is it the complete rocker? With inner sill and outer panel?
  14. Okie Pete
    Okie Pete
  15. Baumi
    Baumi
    It´s only the inner rocker panel. I think it´s driver´s side. I´ll check and take a photo
    Outback, OG lil E and chryslerfan55 like this.
  16. Tickety Boo
    Tickety Boo
    from Wisconsin
    A steel top with the Buick rear window is a great idea, and a full-length door two-door conversion would smooth out the side view :rolleyes:
    Outback and chryslerfan55 like this.
  17. dcadwell
    dcadwell
    What astonishes me isn't that someone used body filler as sculpting clay, its that the slab of filler remained adhered to the hood apparently for decades.
  18. I've seen some Bondo hold that'd surprise you. Especially if there was rust underneath. Seen rust literally hold the filler on
    Okie Pete, dcadwell and chryslerfan55 like this.
  19. Baumi
    Baumi
  20. Opel
    Opel
    from Germany
    @Tickety Boo: I prefer the 4 door over the 2 door because I have family and the 2 door look is not better in my eyes.
    @Baumi: Thanks for the Kleinanzeigen ad heads up. I contacted him because I really could use the roof skin and it is close to my home.
  21. CruznArt
    CruznArt
    from Germany
    Okie Pete and chevy57dude like this.
  22. straykatkustoms
    straykatkustoms
    What a kool project. You are doing a great job saving her. Going to be a kool ride thank you for keeping us updated.
  23. Squablow
    Squablow
    I fully support this endeavor and am looking forward to seeing more updates.
  24. Opel
    Opel
    from Germany
    BigRRR, lucky ink, Outback and 11 others like this.
  25. Opel
    Opel
    from Germany
  26. CSPIDY
    CSPIDY
    Customizing a trifive Chevy and improving the look is no easy task
    I commend you for your efforts
    great work so far
  27. Opel
    Opel
    from Germany
    I replaced the die-cast bolt-on upper grille opening by a welded tube and steel panel construction to make it one-piece. 250615 (1).jpg
    BigRRR, Uncle Ronn, lucky and 16 others like this.
  28. SS327
    SS327
    The grille opening looks great! The headlights not so much. Like the 57 ford, it’s got that “I got kicked in the balls hard look”.
  29. 40FORDPU
    40FORDPU
    "making it your own"....that's what it's all about.
    Nice work, enjoy the journey.
    sunfighter likes this.
  30. swade41
    swade41
    from Buffalo,NY
    Nice work so far, for sure better than some of what was on there.
