Termites and Bowties- Early Chevy Group
Discussion in 'The Hokey Ass Message Board' started by 29bowtie, Jan 7, 2009.
  1. Six Ball
    Six Ball
    from Nevada
    I just p***ed on the video. I've got no skin in this game. I'm not cutting or boxing my frame.
    I didn't know you knew my grandmother! :D
  2. shanejgass
    shanejgass
    Following this thread, I have a 35 Chevy 1.5 ton truck. Anyone know an easy way to upgrade to juice brakes? I'm hoping to keep the original suspension, if possible.
    Shane
    31chevymike and Six Ball like this.
  3. snoop74
    snoop74
    I don’t have a ton of high quality pictures of the chop but here are some I found.
    imagejpeg_1.jpeg imagejpeg_0.jpeg imagejpeg_2.jpeg imagejpeg_2.jpeg imagejpeg_0.jpeg imagejpeg_0.jpeg imagejpeg_1.jpeg
  4. Six Ball
    Six Ball
    from Nevada
    Here is some axle information from Sid's. https://droppedaxles.com/chevy-dropped-axles-0 For the front you may be able to swap in a later front axle with juice brakes. That may work for the rear as well.
  5. Tim
    Tim
    from KCMO
    Thanks man! Those answer my questions :)
    you’ve really turned that into a great hotrod !
    31chevymike and snoop74 like this.
  6. Jay Altemus
    Jay Altemus
    Advice please.
    I’m fabricating the B pillar in steel. I’ll install bear claw door latches. The original B pillar face plate has areas that are only needed for the original style latch.
    Modifying the face plate by smoothing out a few areas will make fabrication of the B pillar easier. I’ve included pics of the original door latch to more clearly show how things were factory designed.
    IMG_7292.jpeg IMG_7319.jpeg IMG_7315.jpeg IMG_7298.jpeg IMG_7316.jpeg IMG_7317.jpeg IMG_7305.jpeg IMG_7307.jpeg
    Kreepea_1, 31chevymike, TFoch and 2 others like this.
  7. snoop74
    snoop74
    I’m not sure if these pictures will help at all jay, but I’m using bear jaw latches and most of the original inner door structure. My main concern was the body lines, I made sure those were good on the outside and then figured out where to put the sticker ect.. IMG_0035.jpeg IMG_0036.jpeg IMG_0037.jpeg IMG_0038.jpeg
  8. Doug G
    Doug G
    from Manheim Pa
    Recommend keeping alignment wedges and upper and lower rubber bumper recessed areas. Best choice for proper alignment of doors and avoid paint chipping issues in the future. This is what I did on my car and very happy with results.
  9. Jay Altemus
    Jay Altemus
    I think I found a source for the door wedge rubber pieces and new rubber door stops. Since those parts are available, I’m agreeing with keeping them intact.
    Cleaned up some stuff and took some inventory today. Found my original door wedges. These headlight buckets are kinda beat up. Are they 1934? I sure can’t tell.
    IMG_7333.jpeg IMG_7329.jpeg IMG_7331.jpeg IMG_7335.jpeg IMG_7338.jpeg IMG_7327.jpeg IMG_7326.jpeg IMG_7340.jpeg
    31chevymike likes this.
  10. Jay Altemus
    Jay Altemus
    Finished the initial mock up of the deck rain channel. My first attempt was a flop. This attempt taught me even more lessons but my results are satisfactory this time. VIDEO LINK HERE.
    IMG_7396.jpeg IMG_7397.jpeg IMG_7378.jpeg IMG_7377.jpeg IMG_7370.jpeg IMG_7368.jpeg IMG_7371.jpeg IMG_7352.jpeg IMG_7348.jpeg IMG_7349.jpeg
  11. tb33anda3rd
    tb33anda3rd
    I wouldn't weld that in till the body is all aligned. it will be easier to get the body aligned if that isn't holding its shape and consequently trying to get the body aligned after may put a twist in the frame and throw the lid alignment off.
    31chevymike, Six Ball and Jay Altemus like this.
  12. Jay Altemus
    Jay Altemus
    Totally agree. It’s sitting on the shelf waiting for the deck lid to be installed at a later time. Plenty of body work to do before I’ll touch it again.
    Six Ball and 31chevymike like this.
  13. tb33anda3rd
    tb33anda3rd
    regarding the door posts, I would leave the face plate as original as possible. run a square tube up the inside and leave the space for all the original rubbers and alignment parts. a full tube is not even needed if the face plate is welded to the outside , an inner plate welded from top to bottom and a rear plate welded to create a post. a triangle bracket from the back of the post, running along the belt line and up to the package tray area to reenforce the latch [simular to the original] really stiffens up the latch area
  14. snoop74
    snoop74
    I ran some square tubing from the top of the wheel well to the back of the structure to support it IMG_0064.jpeg IMG_0065.jpeg
    Six Ball, 31chevymike, TFoch and 2 others like this.
  15. mcgyver
    mcgyver
    My 37 was a 1.5 ton originally, it had juice brakes. I'd bet that the suspension is the same on the 35 as the 37. I bolted a front axle in it from a '52 1/2 ton, no modifications to it at all.
    It is pretty simple to run lines, the main thing I'd think you may run into is mounting a master cylinder. If you can find a donor truck, get the pedal and master cylinder ***embly as well as the axles.
  16. Jay Altemus
    Jay Altemus
    Cleaning up parts is very satisfying.
  17. Six Ball
    Six Ball
    from Nevada
    Those would be prime candidates for a citric acid bath. How did you do it?
    Jay Altemus and 31chevymike like this.
  18. My first guess would be that these parts were sandblasted in a cabinet. Nice work Jay!
    Jay Altemus and Six Ball like this.
  19. snoop74
    snoop74
    Finished the exhaust on the jalopy. It stopped at the frame and was blowing in the rear tail pan and coming through the louvers. IMG_0130.jpeg IMG_0131.jpeg IMG_0132.jpeg
    31chevymike, TFoch, Six Ball and 2 others like this.
  20. Jay Altemus
    Jay Altemus
    Nice work @snoop74.
    Correct. Media blasted those parts in my Skatblast cabinet.
    Today I did a lot of fabrication. Used 1.5” square tube 14 gauge to make a B pillar. Only half way done. Had to narrow the top 14” to 1.25” by cutting a kerf and then squeezing it closed until it was 1.25”. Then weld it. The top half is done but I’ll add more to the lower 20” later.
  21. TFoch
    TFoch
  22. snoop74
    snoop74
    Thanks, jay did you figure out how you’re going to brace that inner structure
    31chevymike and Jay Altemus like this.
  23. Jay Altemus
    Jay Altemus
    The B pillar will connect to the floor outer frame beam. That’s how it was done with wood and I have the original brackets for the A and B pillars. I must first finish the bottom of the B pillar.
    Tim, Six Ball and 31chevymike like this.
  24. X2 - you're doing a fine job Jay!
  25. Just a couple of pics to show some progress on my hemi install prep...
    Jay Altemus, Tim, tb33anda3rd and 3 others like this.
  26. snoop74
    snoop74
  27. Thanks brother! Now I can sit on my stool comfortably and begin to attach the trans adapter/spacer, torquing the bolts correctly. Replace the old seals and gaskets on the front pump and rear tail housing on my transmission. Slip the torque converter in place (3 clicks) and finally get that big *** hemi within my rails - we're talkin' a huge smile on my face for the ages!!!
    snoop74 and Jay Altemus like this.
  28. snoop74
    snoop74
    It’s a long time coming but excited for the progress being made on that thing. When do you plan on having it all back together? Also are you putting the body back on after that or what’s the next step
  29. My hopes on getting her back on the road is sometime next year, my 30th anniversary of ownership (purchased in 1995!) Crazy huh? Not going to place the body back on till I size up a new driveshaft, purchase the right electric fuel pump, bend hard lines for the fuel system, polish the entire center section of the Winters QCR (redo the brake lines on the rear as well), etc. Nice work on the rear exhaust system re-routing on your '35 - what's your next show that you plan to attend?
    Six Ball and TFoch like this.
  30. snoop74
    snoop74
    I bet parts were a lot cheaper back then haha. For some reason I thought you had all your lines ran. I thought the frame stuff was all good. I plan on polishing the intake on my car and replacing the valve covers. You polishing that section yourself? The exhaust was killing me lol. It wa blowing into the roll pan and the car was unbearable to drive. We have a local car show in my hometown Oct 26th then another smaller one the next town over. After November I plan on blowing the car apart and high build priming it and painting it. Then I’m going to finish up the interior. IMG_0141.jpeg IMG_0142.jpeg IMG_0148.jpeg IMG_0152.jpeg IMG_0124.jpeg
