Projects 32 Ford 3 window door hinges
Discussion in 'Traditional Hot Rods' started by HankAz, Sep 26, 2024.
  1. HankAz
    HankAz
    Could someone give the measurements for the door hinges say from the bottom of the door or body to the centers please?
    Thanks Hank
  2. deathrowdave
    deathrowdave
    from NKy
    I’ll get you tomorrow . If you don’t hear back please PM a reminder . I’m covered up preparing for cold to arrive .
  3. Bcap55
    Bcap55
    from PA, USA
    Here are the measurements from my Brookville coupe.
  4. HankAz
    HankAz
    Thank You Bcap55
  5. ekimneirbo
    ekimneirbo
    from Brooks Ky
    If you have the door...........wouldn't it be better to attach the hinges to the door and see where they fit the body? Its more important that the hinges fit the door properly and make the adjustments at the body. I'm saying that because if the pivots don't align properly the door will bind as it opens and closes. Also its a long way from the back of the door to the front of the door. Minor misalignment at the rear could result in a larger misalignment at the front. Car bodies and doors also vary some. I think its more about getting the correct fit than a specific dimension. Best of luck getting the doors located well.:)
  6. HankAz
    HankAz
    Yeah, I have hidden hinges and want to put outside hinges on my body.
    Thanks
    Bandit Billy likes this.
  7. HankAz
    HankAz
    But definitely using Bandit Billy's idea. Just need to see where they should be.
  8. Bandit Billy
    Bandit Billy
    Does that make me an internet influencer? :cool:
    Happydaze likes this.
