Technical Fuel pump weep hole question.
Discussion in 'The Hokey Ass Message Board' started by wheeltramp brian, Sep 27, 2024.
  1. wheeltramp brian
    wheeltramp brian
    On my 55 Plymouth, with the 241 Poly motor I've had an oil leak coming from the fuel pump and finally pulled it off To find that there is a weap hole that oil is getting out of. This Hole goes directly into Nothing but atmosphere as there is not a seal or anything. I imagine when I'm getting on and off The throttle the pressure in the crank case is pushing oil out of this. I do have the engine vented 20240927_103706.jpg 20240927_103701.jpg correctly. I should be able to just put some epoxy In this And it should be fine, correct?
  2. Kevin Ardinger
    Kevin Ardinger
    Not if you want the pump to work. That hole provides a vent on the back side of the diaphragm. Otherwise the diaphragm will not work. Oil should not be in that cavity.
    alanp561, Mr48chev, loudbang and 2 others like this.
  3. leadsled
    leadsled
    How much oil? Is it a steady drip or you are finding residue?
  4. wheeltramp brian
    wheeltramp brian
    Well, oil is getting flung around off of the timing chain right there, so oil does get in the pump. Just pulled the bottom off of the new pump to check it out and sure enough it does what you say as a vent. Perhaps the old pump has a hole in the diaphragm. I'm gonna pull it apart now. You can see the paper clip tip in the photo that I stuck through the hole. 20240927_104958.jpg
  5. wheeltramp brian
    wheeltramp brian
    So I pulled the Old pump apart and there is a lot of oil inside of it. Perhaps I need to check my engine venting? 20240927_105823.jpg .
  6. wheeltramp brian
    wheeltramp brian
    Being that that hole does eventually vent into the crank case by way around the pivot. I imagine I could plug it. As it will still vent, but through the crank case.
    Johnny Gee likes this.
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The hole is actually there to let you know when the diaphragm let’s go. Look up marine fuel pumps. They press a small barb fitting in that area so a hose can be run to the air filter. In turn the engine either runs super fat or dies causing one to investigate what went wrong rather than a possible fire from raw fuel not being detected.
    19Eddy30, 427 sleeper and Driver50x like this.
  8. What about tightening up the opening around the arm with the gasket to act as a splash guard.
    Even my girls Studebaker didn't leak from the vent hole, but it sure leaked past the pivot pin on both sides.
  9. wheeltramp brian
    wheeltramp brian
    Well, I plugged the new one with a piece of rubber and tested it in a vise and it doesn't seem to pump as good, so perhaps there is a seal on the arm and on the old one that is letting the oil come through. I was.
    Thinking about making the gasket bigger also.
  10. Oneball
    Oneball
    There is an oil seal around the rod that connects the diaphragm to the lever. Looks like it’s failed or popped out.
    seb fontana and Kevin Ardinger like this.
  11. wheeltramp brian
    wheeltramp brian
    Thanks oneball. Gonna swap on this new pump in a little while today. And as far as the oil leaking out of it, I believe it was just barely coming out. But the air from the fan blew it all over the side of the engine and frame
    Oneball likes this.
  12. Oneball
    Oneball
    seb fontana, Driver50x and Beanscoot like this.
  13. alchemy
    alchemy
  14. Kevin Ardinger
    Kevin Ardinger
    But then, if that diaphragm ever ruptures, it’s going to fill the crank case full of gasoline.
    AHotRod and Beanscoot like this.
  15. wheeltramp brian
    wheeltramp brian
    You are correct, Kevin. I'm just going to install the new one and see what happens.
  16. 05snopro440
    05snopro440
    I've had pumps leak oil. Changed for a new pump, no oil leak. The fact that it's leaking oil is telling you that the pump needs to be replaced as it has experienced an internal seal failure.
    seb fontana and Algoma56 like this.
  17. wheeltramp brian
    wheeltramp brian
    Put the new pump on and went to rescue my girlfriend in her daily.her fuel pump went out.got her car back to my shop and piled in the Plymouth and made it a1000 feet .no fuel getting to the carb.turn on electric pump and still nothing. Pushed it back to the shop. No fuel getting to the engine. Got a ride home.now I gotta fix 2 fuel problems today
  18. jimmy six
    jimmy six
    PCV system helps if you don’t already have one!
    gimpyshotrods likes this.
  19. wheeltramp brian
    wheeltramp brian
    I do have a PCV system set up. So this morning, I took the fuel line that goes into the mechanical fuel pump off and turn on the electric pump and gas is coming out. No problem. So then I just hooked it straight to the fuel line after the mechanical pump and it runs fine. I tried to blow through the mechanical pump and nothing. This brand new pump is junk already. And I think I'll just end up using the electric pump from now on. As this is my third or fourth mechanical fuel pump in 8 months.lame
  20. garyf
    garyf
    The rubber in some fuel pumps don't like ethanol. Oil and filter change might be an idea. The ruptured pump diaphragm sometimes allows gas inside the engine.
  21. wheeltramp brian
    wheeltramp brian
    No gas in the oil. It almost seems like the arm isn't correct on the fuel pump itself as I can cycle it in a vise. But when it's on the motor it really doesn't do much.
  22. Oneball
    Oneball
    Daft question; you have got the new pump hooked up right? What happens if try to blow through the pump the wrong way?
  23. Budget36
    Budget36
    Dang, that’s some bad luck on fuel pumps.
  24. 2Blue2
    2Blue2
    +1
  25. I was going to make a comment about fuel pumps but didn't want to muddy the waters. Since you're having trouble with new pumps I can comment. I've had trouble the last few years with mechanical pumps (dying early, leaking or over pressurizing), I've resorted to finding old made in USA rebuildable Carter pumps and buy a quality rebuild kit for it. I even went so far as to buy an old 80s Carter catalog. I have an old Carter performance fuel pump from the late 80's (I bought new), that's been on at least 4 cars over the years and still works great. I'm stocking up on other pumps now.
    Studebakers have that problem with new Carter pumps, the arm isn't in the correct spot to get a full stroke from the eccentric.
    302GMC and The Shift Wizard like this.
  26. wheeltramp brian
    wheeltramp brian
    It seems like it's not getting a full stroke.
    Algoma56 likes this.
  27. Beanscoot
    Beanscoot
    Bad news, he's not around anymore.
  28. Found on a review on a Studebaker pump from Amazon. The "R" is the stock pump and the "C" is the new "made in China" Carter.
    Driver50x and Johnny Gee like this.
  29. wheeltramp brian
    wheeltramp brian
    Sounds like I need to find an nos one.just drove home on the electric pump after I byp***ed the stock pump
  30. Driver50x
    Driver50x
    where do you get a quality rebuild kit for these pumps?
