Projects 62 409 20 Day to Great Bend KS
Discussion in 'The Hokey Ass Message Board' started by saltflats, Sep 6, 2014.
  1. saltflats
    saltflats
    from Missouri
    Got a good start on the new raised trunk floor.
    Need to spend some time on the bead roller now.
  2. Stock Racer
    Stock Racer
    Paint the fronts gray
  3. flynbrian48
    flynbrian48
    Deuces, mad mikey and saltflats like this.
  4. saltflats
    saltflats
    from Missouri
    I can live with this.
    61Cruiser, das858, Baron and 10 others like this.
  5. saltflats
    saltflats
    from Missouri
  6. That's some great bead rolling. I like the thinner beads over the stock profile. Also, custom made panels just look stronger.
  7. saltflats
    saltflats
    from Missouri
    I thought it turned out pretty good. Got some prep work before final fitting.
    mad mikey likes this.
  8. saltflats
    saltflats
    from Missouri
    Starting to get happy with it. Had a little oil canning when I first screwed it down. With a little work with the shrinker and two beads from the other direction on each side.
    61Cruiser, Baron, Deuces and 8 others like this.
  9. saltflats
    saltflats
    from Missouri
  10. saltflats likes this.
  11. saltflats
    saltflats
    from Missouri
    Outlet for the fuel cell.
    Tickety Boo, Deuces and osage orange like this.
  12. Tickety Boo
    Tickety Boo
    from Wisconsin
    x 2
  13. saltflats
    saltflats
    from Missouri
    This weekend is the 10 year anniversary of this car going down the track with me.
    And I'm still working on it. o_O
    SS327, loudbang, Stock Racer and 3 others like this.
  14. mad mikey
    mad mikey
    Happy 10 years James's, A milestone of you racing that fine 409.:)
  15. saltflats
    saltflats
    from Missouri
    Thanks Mikey, it has been a ride. It is nice to get back on this car and make it safe.
  16. saltflats
    saltflats
    from Missouri
    Not a lot of progress as we had rain for a few days. I did get the fuel cell sump pan welded in. I was going to weld the whole pan in then decided not to so it would be easier to build and attach the outer wheel wells.
  17. saltflats
    saltflats
    from Missouri
    Got the package tray cover made, need to pick up some more sheet metal to cover the seat back area.
  18. saltflats
    saltflats
    from Missouri
    Got a start on sealing off the outer wheel well.
  19. saltflats
    saltflats
    from Missouri
    Wow! 6 year anniversary of the last time this car went down the track.
    61Cruiser, SS327, Deuces and 7 others like this.
  20. saltflats
    saltflats
    from Missouri
    Worked on the panel a little more for a better fit. Had to change my approach to get a better results.
  21. Zoom soon!
  22. flynbrian48
    flynbrian48
    I dig your raised trunk floor. I'm going to (kinda) copy that when I remove the spare tire well from the floor of our '52 DeSoto wagon. The gas tank is a weird shape to wrap around the spare well, it's very shallow with raised portion like the letter "L" laid 5701D66E-4DA2-43DA-9D2B-BB9A85FC8008.jpeg on it's side. The fuel pump and sending unit are the tall section, it only holds 18 gallons, and because the sending unit is also in the tall portion, it reads wrong.
    I'm going to use an early 90's Chevy van tank, which holds 30 gallons, has the same length and width, filler hole in the same spot so I can use the same sender and fuel pump. I can throw a spare on the floor behind the rear seat when we travel, I'll have 500+ range. We don't carry a spare now.
  23. impala4speed
    impala4speed
    I didn’t carry a spare or jack for quite some time. Never had an issue but I decided not to push my luck any further and have them now.
    Love your wagon.
    flynbrian48 likes this.
  24. saltflats
    saltflats
    from Missouri
    Piece by piece, hope to keep the tire smoke out of the car.
  25. mad mikey
    mad mikey
    I think that should work James. Are you going to seam seal as well?
    SS327, 427 sleeper and saltflats like this.
  26. saltflats
    saltflats
    from Missouri
    My plan is to silicone the pieces to the quarter and run a bead between the patch and the original wheel well then screw them on.
  27. saltflats
    saltflats
    from Missouri
    Getting closer to end on this side.
    SS327, Tickety Boo, mad mikey and 6 others like this.
  28. mad mikey
    mad mikey
    Looking good James. Keep going.;):)
  29. saltflats
    saltflats
    from Missouri
    Thanks Mikey. Heading out of town tomorrow to help my buddy with his car in Iowa. Have a bunch of 349/409 guys having a race at Tri State Raceway. Have a feeling I should stay home.
  30. saltflats
    saltflats
    from Missouri
    Guess sometimes it's better to be lucky than good. On new years day I was on Facebook and seen the registration had opened for the Fall Out Drags so I sent in my registration. The car count is for 200 cars and the registration filled up in 36 hours. I got my conformation email today that I made it in. :)
    This is the event that I last raced this car in a little over 6 years ago.
    61Cruiser, SS327, 427 sleeper and 7 others like this.
