Technical ***September 2024 Banger Meet Thread - First BER Month ***
Discussion in 'Traditional Hot Rods' started by Jiminy, Sep 2, 2024.
  1. trikejunkie
    trikejunkie
    from Scotland
    I`m still here , had a busy time of late-racing at Pendine (no better than last year speed) and racing at Santa Pod in the flathead meltdown .I havent broken the car despite flat to the floor throttle so roll on next year!
    4BangerDean and jet996 like this.
  2. No pictures
    Too much covering head and pistons in cert
    Old record 133.1
    Set 133.8 yeah not much but with a banger just finishing a p*** is a win
    Typical CREE and Nelson entry
    Owen drove
    Damn teenager
    J
  3. trikejunkie
    trikejunkie
    from Scotland
    As I was no faster at Pending a cam is on my shopping list! Anyone recommend one for a B 4 banger? even a supplier of one would be great .
  4. Here's a few screengrabs from my video of the RPM Nationals. It was quite the event! I'm motivated to get my coupe ready to race for next years event, we'll see what happens! [​IMG][​IMG][​IMG][​IMG]
  5. burl
    burl
    from Minnesota
    Kevin,
    Curious where you mounted the sensor in the exhaust and how much difference it makes. On my car it made quick time of figuring out what main jets to run.
  6. Kevin Pharis
    Kevin Pharis
    from Califunny
    Sensor placement does matter… but I put mine in a convenient, and more importantly hidden, location. I’m no expert, but I’m told that too close to the header collector and the sensor will read erratic due to pulses. I run an iron manifold and the sensor is a couple feet away. Workin great so far.
    burl and Outback like this.
  7. So my understanding is that the sensor needs to be far enough away from the port or ex valve to reduce the temperature
    But also far enough away from the open end of tailpipe to not read reverberation air drawn from outside
    J
    burl, Outback and Crazydaddyo like this.
  8. Outback
    Outback
    from NE Vic, Oz
    Will done, a record is a record!
    & Don't worry he won't be a teenager for long :D
    johnneilson likes this.
  9. Stan Back
    Stan Back
    Give my congratulations to Owen on his first of one, I imagine, many records.
    johnneilson and Outback like this.
  10. iwanaflattie
    iwanaflattie
    Thank you...
    No wonder there's a leak after every drive I take and yes,the oil seems to be coming put of every possible place....
    The cap is short and it's not ventilated....
    Can't think of a solution.
  11. Vent the valve cover plate
    J
    Star 351 likes this.
  12. Dan from Oakland
    Dan from Oakland
  13. Fabber McGee
    Fabber McGee
    Might as well add oil through the valve cover too.
    Outback likes this.
  14. Savage Coupe
    Savage Coupe
    from Washington
    Had to unload and drive the hot rod through the Chandelier Tree on the way home from RPM Nationals.
    jet996, Outback, BeaverMatt and 3 others like this.
  15. chlsnk
    chlsnk
    Does anyone have any advice on installing a model B distributor in an A engine. After some reading I realized the B engine has the timing pin in a different location than an A engine. I would ***ume I just need to get #1 to TDC and point the rotor to #1 on the cap. Probably over thinking things.
  16. BeaverMatt
    BeaverMatt
    Savage Coupe likes this.
  17. Dan from Oakland
    Dan from Oakland
    chlsnk and Outback like this.
  18. Lättähattu
    Lättähattu
    from Finland
    I found this timing tip somewhere, i don't remember where. Not really accurate, but this is how i did it:
    - Find the TDC with timing pin and model A timing cover
    - Turn distributor rotator so that it is NOT centered to distributor cap #1 cylinder lead, but rotators trailing end is meeting #1 lead. This should give you about 19deg advance
    As i said, not really accurate. Works for me pretty good. After running engine, i retard timing just little, cause starter had hard time to turn engine when hot.
    This is my set up: Model B engine, Head milled to about 5.2:1 compression, Lightened flywheel (about 14 pounds lighter than stock model B), Dual Stromber 81s and Model A timing cover (cause i did not have anything else!)
    chlsnk and 4BangerDean like this.
  19. chlsnk
    chlsnk
    I appreciate the response.
    4BangerDean likes this.
  20. 4BangerDean
    4BangerDean
    It seems difficult to find someone who is capable or willing to build a full pressure insert bearing B engine. Any recommendations?
    Airborne34 likes this.
  21. jet996
    jet996
    from WY
    @trikejunkie -I can recommend Bill Stipe's cams. I've got an RR340 in my pickup and it runs real good. I've also got an Isky 1007b in my roadster that @Pete1 ground and it goes really well in my light roadster. Plus it's lopey so that's cool heheh.
    trikejunkie likes this.
  22. Outback
    Outback
    from NE Vic, Oz
    Any video of them running?
    jet996 and 4BangerDean like this.
  23. 282doorUK
    282doorUK
  24. jet996
    jet996
    from WY
    @Outback -There's a couple of my roadster at the HotRod Hillclimb on IG. I can't remember if I have any of my p/up.
    @turnpikecruiser31
    Outback likes this.
  25. Star 351
    Star 351
    Stipe 340 in a burtz
    Jukenut13, Outback, jet996 and 3 others like this.
  26. Star 351
    Star 351
    Couple of things you could do, fabricate a longer filler tube that clears and add a vented cap, vent the valve cover, the best solution (but does require a bit or work) is the add a pcv above the running oil level in the valve cover and add a vented cap to the oil fill tube you have to keep the crankcase in a vacuum, will help to keep the oil clean for longer and reduce fumes inside the car if done correctly
    Outback and jet996 like this.
  27. 4BangerDean
    4BangerDean
    It’ll be here Tuesday. I figured it was the best way moving forward not being a machinist or knowing one.
    I still would be interested in having a B engine built. I have 2 blocks that p***ed a 30# pressure test and more than a couple “C” cranks.
  28. 282doorUK
    282doorUK
    I decided on a Burtz after all the sneaky cracks in my B block made them selves known, being over here I reckon it's probably the cheapest and most reliable option.
    Just spent a few happy hours on a friends big old lathe hacking the flywheel down to around 35 pounds.
    It was a bit of a hand full after my little Atlas lathe!
  29. Outback
    Outback
    from NE Vic, Oz
    Thanks I'll have a look, I got kicked off IG for no reason, but should still be able to watch a vid?
    When a lathe makes a flywheel look small you know it's a biggin!
    thanks, that sounds great, looks good too.
  30. Jiminy
    Jiminy
