Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Work is the operative word there. So, with that, I got down to business. First, I trimmed the steering reinforcement plate. I have some fun ideas for the bolts and washers for final ***embly. IMG_4973.jpg
    Then, I broke out the Dremel and cut down the inner steering column tube to clear the Hudson wheel.
    This Dremel has been in my ****nal since about 2007; it's helped me with dozens of 1/25 scale model car projects. IMG_4977.jpg
    It's a perfect fit!
  2. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Next, I extracted the bushings from the steering box with the 11:07 p.m. Hammer (TM). IMG_4979.jpg
    Beat.
    With that, I called it a night.
    Time for a drive? Glad to see the taillight still works as it should. That's all for tonight. I have a couple of updates from today, but more on those later.
  3. 41 GMC K-18
    41 GMC K-18
    Quite the dramatic metamorphosis, from the "ROYAL STANDARD" laminated place mat, to its current state of nearing perfection !
  4. Tim
    Tim
    from KCMO
    Man putting stuff together is cool and all but seeing that tail light on! Hot damn!
  5. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thanks guys! We're moving right along.
    On Saturday, I had big things planned. I started off the day by cleaning up the steering shaft and getting it ready to drop in the box. Next, I cleaned the box one final time and got ready for ***embly. As I did, I realized that there was some pitting on the upper bearing race. IMG_4990.jpg
    I knew it wasn't going to work, and a quick conversation with David confirmed it. "Knock it out with a punch," he said. He suggested I find one with a foot on the end, because it's impossible to get at it with a straight punch. Well for the next hour I tried everything I could. I heated and bent an old screwdriver until it resembled a chopper kickstand, but that just bent more when I hit it. I then pulled out the only two punches in my ****nal. I ground down the smaller one to resemble a railroad spike. That seemed to do the trick. Many strategic hits later, the old race popped out. Success!
    Using a 23mm socket that also works for Triumph stem bolts, I tapped the new race into position.
  6. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Unfortunately that's as far as I got this weekend. I did, however, paint the box this morning and lay down some primer on the rest of the components. I'm waiting on my sector shaft bushings, which should be here by the end of the week.
    So there you have it. We're all caught up for now. I have some good stuff in the mail heading my way, but more on that later!
  7. wheeltramp brian
    wheeltramp brian
    Cool man, Hey, Joey, what is that taillight?
    J.Ukrop likes this.
  8. Tim
    Tim
    from KCMO
    Fun fact the upper race on a 37-48 ford cross steer box is also pressed in place and hasn’t been available for purchase new for about 12 years.
    thankfully a lot of the Minnesota shops that have the market cornered on nos parts have them.
    anyhow more to your actual box I have these two tips.
    1: if possible the next time you have to drive one out it’s pretty common to tack weld a strap across the race and then hit that with your drift and hammer.
    2: make sure that seat for the race is VERY and I mean VERY smooth. I went through more races than I wanted to with my build and I lost at least one to a burn that was almost to small to catch my finger nail. Had it most the way in with the press and crack! Get to start over.
    I think the race that ultimately ended up in the box came from a donor box and I band sawed the top off it so I could plink the race out with a drift super easy.
    Anyhow good update! Your drawing closer!
    J.Ukrop, Six Ball, Nobey and 2 others like this.
  9. RodStRace
    RodStRace
  10. Tim
    Tim
    from KCMO
    Man I think I know what it came off but it’s just off the edge of my memory. I’ll find it
    J.Ukrop, 41 GMC K-18 and Nobey like this.
  11. Nobey
    Nobey
    Look on page 22.....You're welcome.
    J.Ukrop likes this.
  12. Tim
    Tim
    from KCMO
    It’s a mid-to-late '50s Gaz M21 Volga decklid light
    IMG_6260.jpeg Ain’t nobody want to scroll back to page 22 man
  13. A Boner
    A Boner
    Ain’t nobody want to scroll back to page 22 man[/QUOTE]
    Sure!
  14. 41 GMC K-18
    41 GMC K-18
    Back in the day, "Graham" made some pretty cool turn signals as well, but super rare and super spendy if you ever see a pair for sale.
  15. Nobey
    Nobey
    That photo you just posted is from page 22, I don't understand what you meant by scroll back? Hit
    page one, then the right arrow 4 times and you're there, less then 5 seconds, done. I can't do photos
    at the moment or I would have posted that photo for you.....
    J.Ukrop, Irish Mike and Outback like this.
  16. NealinCA
    NealinCA
    The upper race is a Timken #6, which is readily available. I have purchased hundreds of them in the last 12 years. This race is used in all Ford boxes 1932-1960ish.
    I tack weld a 1/2" flat washer into the old race to knock them out. I have begun using a carbide in a die grinder to make two small reliefs, so the race can be knocked out in the future without much trouble.
  17. Tim
    Tim
    from KCMO
    Man I must have been looking in the wrong spots then lol. Good to know for the next one, because there is always a next one :)
    J.Ukrop, Outback and Six Ball like this.
  18. Jeff34
    Jeff34
    @NealinCA Got any pictures of this? I'm likely going to need to get that race out soon as well. Thx!
    J.Ukrop and Six Ball like this.
  19. warbird1
    warbird1
    Or just weld (carefully!) a couple of beads on the inside of the race. It'll shrink when they cool and just about fall out...
    SilverJimmy, 41 GMC K-18 and Six Ball like this.
  20. NealinCA
    NealinCA
    1/2" flatwasher welded into the race. Sometimes the weld is enough to shrink the race and they will fall out like stated above, but the washer gives something to tap with a punch if not
    And this shows where I grind a small notch to make future removal easier
  21. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thank you, everyone! I like that washer technique. I unfortunately don't have any way to weld it here at the house, but I'll keep that in mind for next time.
    It's been uncharacteristically warm here recently, which means perfect painting weather. Over the past two days, I laid down the semi-gloss black on the steering box, plus some extra on a few pieces of hardware.
    Also, I received a great care package from @Nobey with the eyelet we were looking for. Thank you again, Rich!
    Speaking of care packages, my friend Kerry sent me these incredible additions to my library. Honk! has been a perfect resource for all the little details that will be making their way on to the finished car. Thanks again, Kerry!
  22. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Last week, I figured I could pick some of the low-hanging fruit as other pieces came together. The lowest, I thought, were the radiator support rods. Due to the grille shell positioning, I need rods that are slightly longer than Model A. I found a set that measured 30.75 that I could trim and make work. Well, when I took them out of the packaging, I was disappointed to see that I was sent the wrong ones.
    With any luck, they'll send a new set and we'll be on our way. Time will tell.
  23. Tim
    Tim
    from KCMO
    Dang that’s frustrating on the support rods. Hopefully that’s an easy switch a roo.
    good deal on the painting weather, I finished up my outdoor painting for the season just in time for me to wake up to 43 deg this morning! Think those hot days are numbered.
    Six Ball likes this.
  24. 51504bat
    51504bat
    Triple digits here in inland SoCal. Won't cool down untill next Tuesday.:(
    Nobey, J.Ukrop and Six Ball like this.
  25. Six Ball
    Six Ball
    from Nevada
    Perfect weather here. I'm the problem. :(:rolleyes:
    Nobey, J.Ukrop and 51504bat like this.
  26. Jeff34
    Jeff34
    Great Progress, Joey! Can't wait to see this on the road...
    Driving through SF yesterday evening it was really warm, very unusual for the city any time of year.
  27. Six Ball
    Six Ball
    from Nevada
    Last week we had a storm blow through. On my way to Carson there was really thick fog. It reminded me of my years in Oakland. I thought of how I missed the fog. 2 miles later I was completely over it. :D
    Nobey, J.Ukrop and 41 GMC K-18 like this.
  28. LOVE IT MAN"
  29. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thanks everyone! The fog has its charm, but I couldn't be happier about the summer weather right now. Hopefully we'll have more developments on the radiator support status soon.
    Every time the Vern book says it'll be easy or quick, that's when I know I need to buckle up. I was happy to see my sector shaft bushings arrived a day early from Millworks. So, when work wound down, I got right to business. After a little bit of strategic hammer and socket work, I was able to get both bushings into position. When I went to test fit the sector shaft, it wasn't even close to working. For the rest of the night I sanded, cleaned, and test-fit. Sanded. Sanded. Sanded. Sanded. Test fit. Sanded. Sanded. Dremel. Test fit. Took a walk. Came back. Tried creative solutions. Eventually, progress was made. It may have taken a couple of hours, but I'm really happy with the way the sector shaft fits.
    Nothing on this car happens fast. That's okay, as long as the quality is good. Next time I'm in the garage, I'll start steering box ***embly.
  30. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    No photos from the garage tonight. How's this for a traditional article ***le?
