Technical Wheel Offset For Dummies Like Me (Up Date)
Discussion in 'The Hokey Ass Message Board' started by Johnny Gee, Sep 30, 2024.
  1. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Reading all the wording makes my head hurt. So, is my simple definition correct?
    Positive offset = Shallow face
    Zero offset = simple, dead nuts centered
    Negative offset = Deep face
    Thanks
    Lloyd's paint & glass and TRAVLR like this.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    positive offset means reversed or deep face. negative offset is the opposite, almost flat on the outside like a front wheel drive wheel on a late model car, best off using backspace for buying wheels.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Okie Pete, lo c dan, TRAVLR and 4 others like this.
  4. ramblin dan
    ramblin dan
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    hell maybe I have been wrong all these years.... I always thought pos offset was a reversed wheel....hmmmmm
    If you are shopping for Cragars for your 57, they made them 2 ways. standard and reversed. you will want standard offset on a 57
    427 sleeper, TRAVLR and Johnny Gee like this.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The problem is Back Space these day’s are to the outer edge of the wheels lip. Years ago it was at tires bead.
    jimmy six and TRAVLR like this.
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Yes, clearly stated in description.
    TRAVLR likes this.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    thanks for straightening me out on this, I have been thinking backwards about pos and neg offsets for a long time....
  9. evintho
    evintho
    I think I got this off the TireRack website. Looks like you're right Johnny Gee!
  10. Bandit Billy
    Bandit Billy
    Oh sorry @Moriarity, but that answer was incorrect.
    We were looking for "Reverse is a negative offset, negative offset".
    Congratulations to our reining champion @Johnny Gee.
    Thanks for playing and join us next time for another exciting round of
    HAMB trivia.
  11. RaginPin3Appl3
    RaginPin3Appl3
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    No contest here.
    This is Cragars over wording in my opinion vs the few words to say the same thing I opened this thread with. IMG_3141.jpeg
  13. mkubacak
    mkubacak
    Screw the offset ********!!! My brain works in terms of wheel width and backspacing. I don't care where they measure from, as long as I know where they measured from. Why would I care what the offset is? Most of that **** is stupid metric. Rear wheels need a little deeper dish since they should be wider. Because in most cases that just looks cooler.
    phat rat, 427 sleeper, TRAVLR and 3 others like this.
  14. lumpy 63
    lumpy 63
    That is also backwards from what I understand. I guess backspace is the only way to describe it now.
  15. squirrel
    I always use backspace, which has been from the edge of the backside of the wheel, to the mounting surface, for a long time...
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I agree. But as I mentioned earlier. I wanna know where the tire sets. I can’t do that with an outside of the lip back space measurement.
    TRAVLR and lumpy 63 like this.
  17. lumpy 63
    lumpy 63
    But now according to what Johnny posted it is measured to the outside lip....
  18. lumpy 63
    lumpy 63
    Which is stupid depending on the width of the lip
  19. DDDenny
    I like frontside/backside, sounds kinda dirty don't it!
  20. squirrel
    I edited my post.
    You can do all the math off the back spacing number. You'll probably end up calculating an offset, but since you are the one who figured out what it is, you can use your own definition of which direction it is. Just ignore the published offset number, since you don't really know what it means.
    (btw the modern definition of offset has to do with how far out the mounting surface sticks out from the center of the wheel--so a positive offset has less dish than a negative offset wheel)
    427 sleeper, Johnny Gee and lumpy 63 like this.
  21. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Exactly. Summit, Jegs, Cragar ect ect all use the outer edge of the lip. Years ago it was from the inside of the lip.
  22. DDDenny
    I don't recall ever having interference between a wheel lip and the wheel opening.
    The sidewall of the tire on the other hand................!
    427 sleeper and Johnny Gee like this.
  23. lumpy 63
    lumpy 63
    I get it Denny . but the measurement could change from say 3/8 to 3/4 depending on a steel wheel or an aluminum wheel...
  24. duecesteve
    duecesteve
    The offset is totally a newer confusing dimension. Backspace is always what we used to go by. Now all the new cars flush the rim out with no deep dish look any more. It's a stupid look.
  25. ALLDONE
    ALLDONE
    its because of the axel and bearing.... neg off set means more stress on the axel and bearing... positive means the wheel center is under the bearing and axel flange... pretty simple when you think why...
    Adriatic Machine and squirrel like this.
  26. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Like Jim is saying, I’ll come up with my own figures.
    Since Cragar uses metric numbers in their catalog which further complicates things I’m going this route.
    I’ll order my front wheels only first (still free shipping) then I’ll know exactly how wide the lip is and go from there with my math using just backspacing. Then order rears (still free shipping). Win, Win and Win.
    427 sleeper and duecesteve like this.
  27. ALLDONE
    ALLDONE
    I just use the online metric conversion...
  28. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Summit uses SAE and Cragar Metric. If you use online conversion, guess what? Someone is rounding off. So which measurement is correct???
  29. oldiron 440
    oldiron 440
    One thing to consider is when comparing wheels is the offset measured at the wheel bead, or the face of the tire bead. I once bought a new set of wheels replacing the wheels I already had. The new wheels were listed the same offset as the first set but they were 1/2” different and I had no room to spare with the old wheels. I started making calls and found out that the first set was measured from the bead, and the second side was measured from the outer edge of the wheel. Of course the tires were mounted prior to find this out so I own them.
    Johnny Gee likes this.
  30. ALLDONE
    ALLDONE
    ahhhh the ones that fit your car???? if you think you that .05mm will affect the set, you might just wanna go to a tire store and measure for yourself... or let them do it..
