Projects spray on, rinse off rust remover????
Discussion in 'The Hokey Ass Message Board' started by 2FORCEFULL, Oct 2, 2024.
  1. ALLDONE
    ALLDONE
    I remember some 40-50 years ago using a spray on rinse off rust/ metal cleaner that worked....metal would look new....forgot what it was though... is it the same stuff used to clean aluminum??? anyway, figured there has to be something out that actually works like the sales videos.....
    this 58 has the whole roof rusted.... I wanna wash the rust off, **** brick it and paint it..not gonna use any sanders or grinders or sand blasters of any sort, I'll just **** brick it so it stays smooth and only removes the rust,...
    as always, thanks for any and all replies... I'm gonna **** brick the whole car, and my bet is there's rust on top of the fenders under the primer... IMG_3547[9100].jpg IMG_3548[9101].jpg
  2. DDDenny
  3. porkshop
    porkshop
    from Clovis Ca
    real super clean will work. spray it on let it sit for about an hour. If it dries, reapply and get after it with a pressure washer... Purple power and the other copy cats will not do it though....And Navel Jelly is what you are probably thinking of from years ago. And it is not like it used to be....
    Tow Truck Tom likes this.
  4. 51 mercules
    51 mercules
  5. I'm not sure what is best.
    I just wanted to reply so I could say "**** brick". :rolleyes:
    VF-1, jet996, Crusty Chevy and 6 others like this.
  6. twenty8
    twenty8
    Ok, I've just done a HAMB search on the term "**** brick" and it looks like you are the only person to have used it.
    I don't know a lot about body work so this might be a stupid question, but what the hell is "**** bricking"???:confused:
    It seems like it might be something not to do. Sounds rough.........
    If someone said they were going to **** brick my car, I think I would be ****ting bricks.:D
    VF-1, Jibs, Nostrebor and 15 others like this.
  7. DDDenny
    If you've "**** a brick" you would remember it!:eek:
    VF-1, SS327, 2devilles and 7 others like this.
  8. big bird
    big bird
    Does "**** Bricking" involve painting it Porta-Potty color?
    Or possibly subs***uting Kitty litter for Metal Flake?
    Enquiring minds are afraid to know...
    VF-1, SS327, tractorguy and 5 others like this.
  9. HSF
    HSF
    from Lodi CA
    Stink block. Terrible smelling porous block used for hand blocking. I haven't seen one used since the early 90's when I started doing body and paint.
  10. Rich796
    Rich796
    Sounds like a great term for a Bondo Queen or spray polyester job ? ? ?
    Are you thinking about the phosphoric acid based concrete cleaners ? You used to be able to buy at hardware stores. At least in my area, I'm pretty sure they've pulled them.
    2FORCEFULL and Tow Truck Tom like this.
  11. Jack E/NJ
    Jack E/NJ
    from NJ
    Yes. Often used for polishing turds.
    klleetrucking and Tow Truck Tom like this.
  12. pirate
    pirate
    from Alabama
    Ospho will change surface rust to iron phosphate. If it is heavy rust will require sanding then Ospho. Ospho is available from local Ace Hardware or on line through Amazon
    jazz1 and Tow Truck Tom like this.
  13. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    It is like when my wife answered the phone one day, and a fellow asked for me,
    claiming that I had bought his car.:mad:
    At the time I had four in a two car bit of a driveway, and one on the street.
    :mad:
  14. oneratfink57
    oneratfink57
    from Wisconsin
    Can’t speak to **** brick, but Metal conditioner works well, just need to be very cautious to rinse off thoroughly and quickly, otherwise it can cause adhesion issues later. I also not sure what effect it has on painted surfaces, so I’ll double down on the clean it well and clean it fast!
    I’ve even used basic kitchen “iron out” on soda machines and such. Works within seconds!
    :cool:
  15. ALLDONE
    ALLDONE
    correct, used to get it autobody paint suppliers, also correct I used it in the 90 as I painted a lot of black and red cars.... that had to be flawless, or do over... they used to sell it 2' x 2' x 3'' thick.. then you cut it to the size you need.. great for 30's and 40's cars to clean up all the reviles and funny shapes, I also hand block with it to find damage caused by power sanders when I strip a car as it will only attack the paint and not grind the metal away,... I also used featherfill , another thing you don't hear much about with the new high fill primers out now
    and it smells like beer egg farts so it was call **** brick... but was made for restaurant use to clean grills cause it cleaned every thing off without damaging the metal...
    SS327, tractorguy, williebill and 2 others like this.
  16. ALLDONE
    ALLDONE
    I **** a brick ever time I see someone stripping paint off a car with a belt sander or side grinder...
    SS327, williebill and Tow Truck Tom like this.
  17. ALLDONE
    ALLDONE
    I don't get it??????????????
    hotrodharry2 likes this.
  18. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Niether did she.
    Sorry to hijack,, but the term had already broken your stride.:D
    Nice looking Chevy. Hope you get to that bare metal that you need.
    What's going under the hood?
    2FORCEFULL likes this.
  19. ALLDONE
    ALLDONE
    now I get it... she **** a brick hearing that you bought another car,
    the 58 has a vette 365 hp 327/ 4/ speed
    VF-1, hotrodharry2, SS327 and 2 others like this.
  20. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
  21. dwollam
    dwollam
    Grill bricks. Yes, they really stink!
    Maybe try a restaurant supply place?
    Dave
  22. ALLDONE
    ALLDONE
    I found some on amazon, they're small 4x8 bricks...3'' thick
    SS327 likes this.
  23. SDS
    SDS
    51 mercules likes this.
  24. ALLDONE
    ALLDONE
    I looked this up and the reviews were great... exactly what I was looking for, spray on and leave it to do it's work then wash off... perfect...
  25. ALLDONE
    ALLDONE
  26. 51 mercules
    51 mercules
  27. Bandit Billy
    Bandit Billy
    I just used rust mort on a tail gate, my daughters truck she and I are restoring. The 40 year old truck had one coat of factory applied black paint and it was so thin it did nothing to stop the rust sadly. A few coats of the mort and it looks pretty good. Don't get it on your garage floor.
  28. abe lugo
    abe lugo
    I would say what ever you try make sure not to get it on your gl*** or trim pieces as it might etch stuff, I think Evaporust is the only one safe for that.
  29. ALLDONE
    ALLDONE
    you won't get rust out of trunks, inside doors ,floor boards , wheel wells... ect..
    Texas57 likes this.
  30. 1971BB427
    1971BB427
    from Oregon
    I've used Evaporust by putting it in a weed sprayer. Need something like that with a larger nozzle to spray it and ensure the metal is well wetted.
