For Sale: mid 1960s styled 1930 Model A Coupe. Engine • 1956 Chrysler 354 Hemi that is blown and injected. • Machine work and engine assembly by DC Racing Engines • Balanced 354 crank • Molinar H-beam rods • Arias Forged pistons 7.6:1 • Johnson Lifters • Manton adjustable push rods • Joe Hunt Magneto looking HEI distributor • Hot Heads blower intake, port injected by Nick Smithberg, Smithberg Racing • Original GMC 671 blower rebuilt by L & M Superchargers Hilborn 4 port fuel injection, converted to EFI (electronic fuel injection) by Smithberg Racing Tuned by Dave Cho, Colorado Speed and Chassis Currently 500 HP to the wheels @ 7 psi boost, capable of 15 psi Custom fuel rail plate by Smithberg Racing Custom crank trigger by Smithberg Racing Custom bell crank throttle linkage by Smithberg Racing Holley HP ECU MSD Box Rev limiter w/2 step • Hilborn scoop w/K/N style air filter • Original 354 heads also ported by Smithberg Racing. • Heads flow 100 cfm more than stock • Custom rocker stands by Smithberg Racing • Reinforced exhaust rockers by Rocker Arms Unlimited • GM Flex fuel sensor to detect ethanol % content • It will run on E85 or pump gas • Tuned to be able to run all the way to E100. Polished aluminum finned valve covers Custom Stainless steel 16 gal fuel tank by Wineland Rod and Custom Holley In-tank fuel pump Holley Transmission • Tremec TKX 5 speed manual • McLeod dual disk clutch. • Hydraulic slave cylinder Custom built driveshaft by Fast Shafts. Hurst shifter and handle Chassis • 9” Ford rear with Strange 35 spline axles Strange 3rd member with Detroit Locker and 3.73 gears. 1932 style frame SW Racing ladder bars QA1 coilover shocks Front end has a Super Bell chrome drilled and 4" dropped axle Chrome radius rods and shocks Radir 18”x3” 12 spoke spindle mount Front wheels on 18”x3.00" Duro Tires. Front disc brakes with solid rotors and Wilwood calipers Radir 15”x10" 5 Spoke rear wheels on MT 15”x10.00" Pie Crust Cheater slicks. Body mods: • 4” chop • Filled roof from inverted ribbed 58 Ford sedan • 1950 Chevy truck cowl vent added • Visor drilled and dimple dyed • Deck lid has 119 louvers Tail lights are 1950 Pontiac Bezels, with 1961 Chevy lenses Body work and Chrysler Mango Tango Paint by The Speed Shop, Bethany, MO Custom pinstriping and lettering by Good Girl (Kendra Bell), Littleton, CO Interior Custom Cream and orange interior done by CB Auto Trim, Aurora, CO. Engine turned solid copper dash insert Stewart Warner Black face gauges Wildwood brake and clutch pedal assembly 6 point roll bar with removable door bars Line Lock Orange Tinted windows for 1960’s vibe Removable kick panel for ECU access USB cable for laptop tuning capabilities Any more questions or pics feel free to pm me or contact me at (303) 905-3519 or aleeper614@gmail.com
