Projects Rear/Mid Engine 1927 T Roadster
Discussion in 'The Hokey Ass Message Board' started by Noah*, Oct 4, 2024.
  1. Noah*
    Noah*
    Started on a new project with the high hopes of trying for the AMBR. 1927 rear engine T Roadster. 20240925_121652(0).jpg 20240928_155032.jpg 20240928_155422.jpg 20240925_072739.jpg
  2. flynbrian48
    flynbrian48
    I like this already. I was afraid there for a second you were going the GM 3.8 transverse transaxle thing, which would have lead to an early death here. ;)
    duecesteve, Outback and Deuces like this.
  3. Tim
    Tim
    from KCMO
    Love it
    Deuces likes this.
  4. Noah*
    Noah*
    If anybody has the panel above the decklid for a 26-27 roadster let me know
    Deuces and Outback like this.
  5. SEEKONK JIM
    SEEKONK JIM
    you need a quick change rear end....
  6. Noah*
    Noah*
    Yes I do. I am accepting donations if someone has a 201 to donate, haha
    pecker head, Apenaut, Outback and 4 others like this.
  7. pwschuh
    pwschuh
    I like where this is headed. Pick a color yet?
    Deuces likes this.
  8. Noah*
    Noah*
  9. pwschuh
    pwschuh
    So, pink?
    (I kid, I kid)
    RICH B and Noah* like this.
  10. Noah*
    Noah*
  11. Bearing Burner
    Bearing Burner
    from W. MA
    If you going to race it you'll need a roll cage plus a lot of other things. You will be in /RMR depending on your displacement.
  12. PotvinV8
    PotvinV8
    He stated the goal is AMBR, not racing.
    Space is gonna be tight putting that engine in front of the rearend and having sufficient room for the driver in the p***enger compartment.
    onetrickpony, Outback, Deuces and 2 others like this.
  13. Mike VV
    Mike VV
    from SoCal
    Build two...
    One for show, and a slightly cheaper copy for the...street !!
    Mike
    Okie Pete, Outback and greasemonkey54 like this.
  14. gimpyshotrods
    gimpyshotrods
    hrm2k, pwschuh, alanp561 and 4 others like this.
  15. Awesome build concept, I will be following along with interest. Will you have rear suspension or solid mounted? You will likely be familiar with Don Waite and Ray Brown roadsters they had a cradle setup
    Blah, blah... splitting hairs. Yes you are correct it is not a true "rear" engined roadster but under definitions & rules that these cars were built to in the 40s and 50s the definition is correct ie engine behind/rearward of driver. I will say and call this is a "Rear Modified Roadster". Often referred to rear engine roadster
    tb33anda3rd, HEMI32, Deuces and 7 others like this.
  16. mohr hp
    mohr hp
    from Georgia
    Cool! So, hard tail, or powertrain on a swing-arm? I'm guessing if it's strictly show, no need for suspension or pistons or unneeded stuff like that?
  17. 2OLD2FAST
    2OLD2FAST
    from illinois
    If you could find a corvair transaxle & a Crown V8 conversion kit , that would really simplify things in the driveline dept .
    GuyW and Just Gary like this.
  18. CSPIDY
    CSPIDY
    You have my attention
    and
    Very interesting indeed
    what will be under the the original hood?
    Stogy, Bandit Billy and Outback like this.
  19. Dedsoto
    Dedsoto
    from Australia
    Mostly legs by the looks, maybe some fuel too
  20. Noah*
    Noah*
    AMBR rules require it to run and drive. I drive my show cars
    pecker head, Stogy, SS327 and 7 others like this.
  21. Hutkikz
    Hutkikz
    It seems that would also imply that to qualify as a front engine that some or all of the engine be in front of the front axle centerline.
    2OLD2FAST, 49ratfink and Jay McDonald like this.
  22. Noah*
    Noah*
    It will have a cradle like Ray Browns car. I'm going to use the block as a structural component on mine Screenshot_20240818_091427_Chrome.jpg
    duecesteve, Stogy, Apenaut and 19 others like this.
  23. That is the rear setup is from Don Waite's, Ray used a V8-60. What ch***is will you be using? '32, Chev or tubular? Really looking forward to watching this come together
    Stogy, Okie Pete, Tim and 1 other person like this.
  24. Unkl Ian
    Unkl Ian
    Some Bonneville stuff runs without suspension.
    Works well on the real fast cars.
    Not ideal on slower stuff, but they do it.
  25. The37Kid
    The37Kid
    Good luck with the project, I'll look for sheet metal at Hershey. Bob
    alanp561, Stogy, Frenchie 1 and 6 others like this.
  26. Jay McDonald
    Jay McDonald
    ********, ever heard of a rear engine dragster?
  27. evintho
    evintho
    Outback likes this.
  28. gimpyshotrods
    gimpyshotrods
    You are arguing against an automotive industry standard term.
    Sure others misuse it, but that does not make it correct.
    Wrong does not equal right, just because ignorance is popular.
    Just Gary, chrisp, Thor1 and 3 others like this.
  29. gimpyshotrods
    gimpyshotrods
    Now you're getting it.
    If the engine is in-between the axle centerlines, it is a mid-engine.
    That's the definition. Words and phrases have defined meanings. That is what makes communication possible.
  30. PotvinV8
    PotvinV8
    You mean the Frunk? :D
    Toms Dogs and alanp561 like this.
