Technical full fendered Ford Model A: wheel recommendation needed
Discussion in 'Traditional Hot Rods' started by Phil Carracho, Oct 4, 2024.
  1. Phil Carracho
    Phil Carracho
    from Atlanta GA
    Hi guys,
    I fell in love with the full fender style you see below and I want to identify the wheel/rim combination they are running. It looks like the rims are 18" 1932.
    Any feedback is highly appreciated. Same for leads to find a set of rims.
    Thanks, Phil
    460047041_3787565478172276_6763499417625114336_n.jpg 461542095_505254172393631_3333462558189130231_n.jpg 461542095_505254172393631_3333462558189130231_n.jpg
    rattlecanrods likes this.
  2. dirt t
    dirt t
    What size wheels and tires?
  3. ClarkH
    ClarkH
    Yes, I think that's what he's asking. I believe these are example pics, not his car.
  4. 31Apickup
    31Apickup
    There are three versions of those wheels, 32 Ford 18”, 33-34 Ford 17” and 35 Ford 16”. The 16” were the most popular. The example photos look to be 17 or 18 inch. The only issue with those is available tire selection. 18” are pricey and limited selection with the stock rim being I believe 3.5” wide. Bigger selection for 16” tires.
  5. alchemy
    alchemy
    Yes, I agree those look like 32 18”.
  6. Hitchhiker
    Hitchhiker
    Looks like 5.50x18 7.00x18 tires to me
  7. 29Sleeper
    29Sleeper
    from SoCal
    The Tudor on the left has the straight spoke 1935 Ford 16" wheels. 5.50 front and 7.00 rear tires. The Coupe on the right has the 1936 Kelsey Hayes 16" 40 bent spoke wheels. with 6.50 Excelsior radials. The Tudor has a reverse eye front spring. The reverse eye spring for the Coupe is in the garage awaiting winter installation.
    Stan Back, CSPIDY, Mikko_ and 2 others like this.
  8. ALLDONE
    ALLDONE
    do you think they might be 17''s
    deadbeat likes this.
  9. ALLDONE
    ALLDONE
    those are both 32 fords....model b... I have a sedan, I put a 31 model A body on my deuce
  10. PotvinV8
    PotvinV8
    My '30 coupe before I sold it. Ford '35 wires with Excelsior rubber; 6.00x16s and 7.00x16s.
    [​IMG] [​IMG]
    Speccie likes this.
  11. ALLDONE
    ALLDONE
    I don't know much, but this...this 32 looks bad *** with the wheels and the model A body
    PONTNAK123 likes this.
  12. alchemy
    alchemy
    I think you are trying to be cute, right? It’s probably not helpful to be saying things like that to guys trying to learn what parts are what.
    To the OP, and anyone else new to the Model A world, that’s a 1930 with 1932 grille and wheels.
    bschwoeble likes this.
  13. ALLDONE
    ALLDONE
    pretty sure I said it was a model a... on a 32 grille...
  14. Phil Carracho
    Phil Carracho
    from Atlanta GA
    Thanks for all the quick replies!
  15. 1946caddy
    1946caddy
    from washington
    swifty and Outback like this.
  17. Outback
    Outback
    from NE Vic, Oz
    17's front 4.50 & 18's rear with 6.00/6.50's I believe
    rattlecanrods, CSPIDY, jet996 and 3 others like this.
  18. j ripper
    j ripper
    from napa ca.
    16 KH. 450/700
    CSPIDY likes this.
  19. FlatJan
    FlatJan
    in front is a motorcycle tire
  20. 29Sleeper
    29Sleeper
    from SoCal
    This car is perfection!
    Outback likes this.
  21. Outback
    Outback
    from NE Vic, Oz
    Yep, I wish I could say it was mine, not sure who owns it or where it's from
  22. dlc3
    dlc3
    from Illinois
    Phil,..It looks like to me to be 17's on front and 18's on the back of that car.
  23. 05snopro440
    05snopro440
    29Sleeper and Outback like this.
  24. synchro7
    synchro7
    I went with 16" Kelsey Hayes, 4" wide 5.10x16 in front and 4.5 wide 7.00x16 on the rear.
  25. Phil Carracho
    Phil Carracho
    from Atlanta GA
    I found info about the green 5W coupe:
    Really nice older resto car then decided to do full on traditional Hot rodRicky Bobbys rod shop did the transformationThe car was a really nice no rust ever car no patches or fillerBrand new build on a 49 flatty with a T5 to back it up cruises at 75 no issueselectric fan and aluminum radiator40 Lincoln brakes and rearSo cal shocks and beam32 Ford Wires with all new Coker tires39 ford column with banjo steering wheel32 deluxe grille shell with 32 commercial lightsNo expenses spared no junk all new partsCheck out Ricky Bobbys builds they are the real dealThis car is driven not just trailered around if you want a real deal driver this is your carFeel free to call me 615-504-9834Matt HooperHonestly if you are really interested its easier to call for all the info
    Outback likes this.
  26. Phil Carracho
    Phil Carracho
    from Atlanta GA
    isn`t that the perfect stance? Looks like 700-18 in the rear
